    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 01-29-2013, 03:45 PM   #4861
What's the difference between the 521-01 arms, WC arms and the NCG arms (yes I know the drop down..)
I run a FS2 SP and DB1, so have plenty of rear arms.
Schumacher - RW Racing - RudeBits - TORCH
mikeyscott is offline   Reply With Quote
Old 01-29-2013, 05:32 PM   #4862
steam's Avatar
The 01 has 1 hole that is in the middle of where the 2 holes are on the normal arm
Yokomo YZ-2, Kyosho Ultima SC-R, RT5, Airtronics M12
steam is offline   Reply With Quote
Old 01-29-2013, 05:39 PM   #4863
gelshocker's Avatar
It is common practice to run 521 arms with the narrow holders, and 521-01 arms with wide holders? I'm assuming the one hole 521-01 is needed to offset the wider holders, so I can run the same shock ball ends, whenever one runs the outer hole on the 521 with narrow holders?
Any situations where I need 521 with wide, or 521-01 with narrow? Thanks,
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 01-29-2013, 09:14 PM   #4864
Trader Rating: 27 (100%+)
I need some blue .5 Hubs.. Pm me if you have some I can buy
Kyosho, Lunsford Racing, Express Motorsports, Dibrino Designs.
C_Money is offline   Reply With Quote
Old 01-29-2013, 09:17 PM   #4865
ben73's Avatar
Trader Rating: 40 (100%+)
Finished up the build of my RB6. Superb. The first 1/10 K car I have built after running AE for as long as I can remember. The shocks are even better than my Tki3. Lunsford turnbuckles and Ti screws throughout. just waiting on the carbon battery braces to finish it off
First run will be when I get to the USA in 10 days
ben73 is offline   Reply With Quote
Old 01-29-2013, 09:18 PM   #4866
Trader Rating: 29 (100%+)
I have a set of 1 deg blue hubs I would sell..
Yzlvr is offline   Reply With Quote
Old 01-29-2013, 09:49 PM   #4867
BranVita's Avatar
Trader Rating: 39 (100%+)
Matt has exactly what you need for a GREAT price!
http://www.rctech.net/forum/r-c-item...5-rt5-scr.html
Branden V.
Kyosho Rb6 | Orion R10 Pro | SchuurSpeed 17.5 | Savox 1257
Kyosho SC-R SP | Orion R10 Pro | SchuurSpeed 17.5 | Savox 1258
BranVita is offline   Reply With Quote
Old 01-29-2013, 09:58 PM   #4868
Seen those.. They look a little beat though
Old 01-30-2013, 06:22 AM   #4869
Default Ti screws
Ben73 - very clean looking build, nice! Curious what titanium screw kit you used and where to purchase in the states?
flybyublue is offline   Reply With Quote
Old 01-30-2013, 06:50 AM   #4870
ben73's Avatar
I buy all my titanium in bulk through
http://www.titaniumscrews.net
I got on to them last year because I wanted to kit my Tki3 all Ti - the price is really good. And the quality is amazing. The only issue is its usually min 50 pieces per size. But when you are doing 4 1/8th cars per year to add a couple of 1/10th makes it cost effective.
Old 01-30-2013, 07:55 AM   #4871
jwood7's Avatar
Either arm can be used with either the wide or narrow holders. These r just different tuning options. The 521 arm has 2 holes and the 521-01 has one hole. The first page has a good explanation of the difference between the narrow and wide holders
jwood7 is offline   Reply With Quote
Old 01-30-2013, 09:13 AM   #4872
fullsyzz's Avatar
Trader Rating: 102 (100%+)
What's the part number for the crush tube that goes between the two bearings in the rear hubs? Not finding it in my manual.
fullsyzz is offline   Reply With Quote
Old 01-30-2013, 09:14 AM   #4873
jackcarter3's Avatar
KYOFU666
Hahahah
jackcarter3 is offline   Reply With Quote
Old 01-30-2013, 09:14 AM   #4874
function>form's Avatar
Trader Rating: 43 (100%+)
Anybody know where to get the wide rear suspension hangers in aluminum? Seem to be on backorder everywhere
Josh Medina
Bumps and Jumps rc
function>form is offline   Reply With Quote
Old 01-30-2013, 09:17 AM   #4875
Rfury's Avatar
Send a message via AIM to Rfury Send a message via Yahoo to Rfury
LA253
Always check the exploded diagrams for all the various part numbers. Much easier to find them on that than the full parts list.
Kyosho RB6
Kyosho ZX6
Kyosho MP9e TKI
Rfury is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
