    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 01-29-2013, 08:14 AM   #4846
jackcarter3's Avatar
Originally Posted by t8rtot View Post
giving them as charity to the RB5 owners...
Nice. That's what I figured. Mine just came off back order from a main so I will have a few to give away.
jackcarter3 is offline   Reply With Quote
Old 01-29-2013, 08:28 AM   #4847
fullsyzz's Avatar
Trader Rating: 102 (100%+)
Make sure you get the RB5 rear outter hinge pins if you run the 521-1 arms. The Rb6 pins have a nut on both ends and go all the way through the 6 arms. Where the 521-1 arms use a shorter outer pin that is captured by the arm on one end and a small screw on the other end. You can make the Rb6 hinge pins work if you have to...if you want to drill the arm and have the hinge pin sticking out too far.
fullsyzz is offline   Reply With Quote
Old 01-29-2013, 08:30 AM   #4848
fullsyzz's Avatar
LA229 are the hinge pins you want to run with the 521-1 arms.
Old 01-29-2013, 08:49 AM   #4849
Thanks sy. I will add that to the order. Are you running the standard arms or the rb5 arms?
Old 01-29-2013, 08:52 AM   #4850
fullsyzz's Avatar
I went back to the Rb6 arms for now.
Old 01-29-2013, 08:54 AM   #4851
Did you notice a difference? Our track generally has good bite so I would think it wouldn't be much of an issue.
Old 01-29-2013, 09:09 AM   #4852
Kooz's Avatar
Originally Posted by HalfManHalfGod View Post
I accidentally bought this one rather the regular um720 part. Whats the difference between this and the stock part? I just took a look and it appears they are the same size.
The original part bends really easy and at something like $14.00 it is a tough pill to swallow! Looks like Kyosho redesigned it to fix this issue. No more pliers to bend back hopefully! LOL
On a side note. After one too many Donkey Flips my bumper deformed causing this hinge plate to slip off the hinge pins CONSTANTLY. I used a heat gun, headed up the bumper and exagerated the original bend in the bumper. This has worked out perfect and alleviated the problem this far.
Kooz is offline   Reply With Quote
Old 01-29-2013, 09:09 AM   #4853
seth556's Avatar
Trader Rating: 42 (100%+)
I just reamed out the part that captures the pin a tad and the regular pin fits, just use a 2mm shim on either side and it works perfect.
seth556 is offline   Reply With Quote
Old 01-29-2013, 09:14 AM   #4854
fullsyzz's Avatar
The different arms have a different feel, but I'm not sold one is better than the other.
Old 01-29-2013, 09:38 AM   #4855
ChadB.'s Avatar
Trader Rating: 21 (100%+)
Can someone tell me if the M566 WC rear arms are the same as the 521-1 arms?
Chad Burdick
*Mugen Seiki*Flashpoint Racing Products*9th Annual Timezone Grand Prix July 13th-16th 2017*Unique Air Design*TimezoneRacing*RoseCityScaleRacers* Daves RC Track
ChadB. is online now   Reply With Quote
Old 01-29-2013, 10:06 AM   #4856
Originally Posted by K_King View Post
RB5 arms actually give the rear end more grip.
+1 I agree. Anytime I was on the trigger, the car felt more locked in. Acceleration was much better and more predictable. Also, the 5 arms felt less dumpy in the rear.
sir_thomas is offline   Reply With Quote
Old 01-29-2013, 10:51 AM   #4857
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Originally Posted by BranVita View Post
Originally Posted by Cpt.America View Post
Interesting.. he's running the short front track width, but is running the wide hexes.
Maybe it is just me but doesn't it look like he is running the front axles off of the SCR-SP instead of the 5? The car front axles has the hex area machined into it from what I remember.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 01-29-2013, 11:05 AM   #4858
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
hhnm.. im not sure what you mean, i guess i didn't realize there was a difference.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 01-29-2013, 11:07 AM   #4859
Rfury's Avatar
Send a message via AIM to Rfury Send a message via Yahoo to Rfury
You are thinking about the SP2 WC. It has the same axle as the RB6. The old SP2 and previous had the setup Tebo is running.
Kyosho RB6
Kyosho ZX6
Kyosho MP9e TKI
Rfury is offline   Reply With Quote
Old 01-29-2013, 03:19 PM   #4860
Trader Rating: 38 (100%+)
Nope.. you change front track width of the rb6, with the rb6 caster block inserts. Hole to the outside, or hole to the inside. Have to make sure you orient them so that you don't also flip your caster affect though... a +2 caster insert can also be a -2 if put in the wrong way.
So Tebo is running the narrow front track width, but wide front hexes. Since roll center is measured out to the center of the tire contact patch... im not sure what this will accomplish, except maybe let him run a different offset front wheel without drastically changing his track... just a guess.
I love this hobby and I love my RB6. I can't get too technical as it will fry my brain. I tell you what though. Seeing Tebo, Cavalieri and all the guys at Reedy Race - now that is cool. WOW. I wish my fellow club racers hand the same driver etiquet.
noworries is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22953 Today 12:29 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
