    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 01-28-2013, 02:48 PM   #4816
Why does Tebo use the RB5 front axles?
Dale.0 is offline   Reply With Quote
Old 01-28-2013, 02:58 PM   #4817
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
He runs wider axles, but then runs the narrow front track width. From what I figure, he uses it to lower his roll center in front using the lower control arm. The RB5 axles/hexes allows him to keep the same track width. (roughly)
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 01-28-2013, 03:04 PM   #4818
mdowney's Avatar
Trader Rating: 21 (100%+)
So is he running the SP2 caster block or the SP2 WC caster block? And is he also running the older arms?
Mike Downey
I try all of the RC kits and usually race at Tacoma RC Raceway
mdowney is offline   Reply With Quote
Old 01-28-2013, 03:07 PM   #4819
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
He is running the RB6 caster blocks.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 01-28-2013, 03:48 PM   #4820
mdowney's Avatar
Yeah, I see that on the CRCRC setup sheet. So what is Brandon talking about with the narrow track width. I thought that could only be changed through the caster block...
Mike Downey
Old 01-28-2013, 03:57 PM   #4821
i dont like that Tebo uses all those rb5 parts on his rb6 it makes me think my box stock rb6 aint right
hollywood7 is offline   Reply With Quote
Old 01-28-2013, 04:03 PM   #4822
mdowney's Avatar
I'm pretty sure the only non-stock RB6 parts he's running are the front axles and the rear arms. Just consider those to be tuning aids. It shouldn't worry you at all.
I actually see it as a huge benefit that we can still use RB5 parts on this new kit. When Losi dropped the 22 there was almost zero interchangeability with the old XXX series.
Mike Downey
Old 01-28-2013, 04:04 PM   #4823
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Haha Tebo's setup is not the end all for highest speed. Its the fastest setup for his style of driving. There are a tonne of other pro setups which don't use any rb5 parts. Pros will often try those things out. Just drive the car stock and get a feel for it before ya get bummed out.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 01-28-2013, 04:36 PM   #4824
dont wory i love the rb6 it tough as nails it just makes me think it could be even better!!
Old 01-28-2013, 04:44 PM   #4825
t8rtot's Avatar
Trader Rating: 14 (94%+)
+10 drive a stock 6 and tell me it's not heads above the cars out there. They say the 5 arms free the car up in the rear but they every setup I've seen they're adding more toe to lock it back down. I bought the -1 arms but I'm so in love with how it handles now I won't make the change any any soon.
Sfida
t8rtot is offline   Reply With Quote
Old 01-28-2013, 05:15 PM   #4826
aloksatoor's Avatar
This is the only car where I think 10 times before changing setups from my baseline setup. The car has gotten so quick so fast that it seems pointless . I have narrow RF RR holders, the rb5 spares and springs and all but really pointless to argue with lap times .
Only things I change are the tires, between m4 hole shot(low traction cold weather or in mornings for qual) or green 3ds/bar codes (for when the groove sets in or practice days right after they run nitro and the tracks oiled in) for the rears. The front worn in suburbs m4 work the best for me (tried hole shot m4 fronts did not like the steering too inconsistent for me).
Old 01-28-2013, 05:48 PM   #4827
Trader Rating: 72 (100%+)
Just saw this, sorry if already posted http://www.amainhobbies.com/product_...n-Plate-Type-B
b121774 is offline   Reply With Quote
Old 01-28-2013, 06:28 PM   #4828
Kooz's Avatar
Nope. You're the first. thanks!
Kooz is offline   Reply With Quote
Old 01-28-2013, 06:51 PM   #4829
Super Moderator
Kraig's Avatar
When you flip the inserts around, hole closest to then center of the car it moves the caster blocks out. Flipping the insert moves the caster block the other way. So Tebo is running the hole farthest from the center of the car which narrows the front end but he is running the RB5 axles in the front with the wider hex than the stock piece so he is pushing the wheels back out. I am not a suspension genus so I can't tell you what it does.
Old 01-28-2013, 06:58 PM   #4830
I accidentally bought this one rather the regular um720 part. Whats the difference between this and the stock part? I just took a look and it appears they are the same size.
HalfManHalfGod is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
