    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree17Likes
Old 01-27-2013, 01:17 PM   #4771
Trader Rating: 18 (100%+)
Originally Posted by teeforb View Post
U have a link? I would love to try it
Here you go...... http://www.petitrc.com/setup/kyosho/...SetupSheet.pdf
Set it up just like the sheet says but for even more steering use 0 degree caster blocks, try 1 or 2 degrees of toe out, and don't add any bump steer spacers. Also don't add any extra weight anywhere on the car because your running 17.5. Should have quite a bit of steering (probably too much, but you can take it out slowly till you like it) just as long as your running the right tires for the surface you run on.
Ctimrun is offline   Reply With Quote
Old 01-27-2013, 01:21 PM   #4772
teeforb's Avatar
Trader Rating: 94 (100%+)
Send a message via Yahoo to teeforb
Set it up just like the sheet says but use 0 degree caster blocks, don't add any bump steer spacers, and don't add any extra weight anywhere on the car because your running 17.5. Should have quite a bit of steering as long as your running the right tires for the surface you run on.
Which are the defaulted blocks on the kit?
$$ Team High Budget $$
17.5 stock buggy fb page
https://www.facebook.com/groups/17.5stockbuggy/
teeforb is offline   Reply With Quote
Old 01-27-2013, 01:40 PM   #4773
Trevor Williams's Avatar
Trader Rating: 195 (100%+)
picure is somewhat low quality....o' well
RC10-B6d | RC10-B64d
SmacTrac
#WeAreAE #ReedyPower #AE4Life
Trevor Williams is offline   Reply With Quote
Old 01-27-2013, 01:41 PM   #4774
t0p_sh0tta's Avatar
Trader Rating: 35 (100%+)
Zero
I've met some of the strangest people while playing with my toy cars...
t0p_sh0tta is offline   Reply With Quote
Old 01-27-2013, 01:48 PM   #4775
teeforb's Avatar
For the caster (um721), how do you choose 25 or 30 deg? I bought the car used, so not for sure. Which option gives more steering?
Old 01-27-2013, 02:03 PM   #4776
t0p_sh0tta's Avatar
The block that the front inner hinge pins go through can be reversed. Put in in one way and you've got 25* put it in the other and you've got 30*. Have you looked at a manual?
The orientation of the block depends on where you want steering. I'd start with the 25* orientation, and start changing caster inserts on the hubs to suit.
Old 01-27-2013, 02:25 PM   #4777
teeforb's Avatar
One again, new to the buggy. What are the inserts in the hubs?
Old 01-27-2013, 02:33 PM   #4778
jordy-15's Avatar
Trader Rating: 17 (100%+)
kit setup calls for 0 in to give a narrow track 4 in gives you a wide track
cheers
:: Proline :: XRAY :: Muchmore::HEI ::
www.nbhc.com.au
www.rchobbyland.com
www.sydneyrc.com
jordy-15 is offline   Reply With Quote
Old 01-27-2013, 02:38 PM   #4779
Trader Rating: 72 (100%+)
Kit comes with 0, 2 and 4 degree caster inserts. all of them can be put switched to a narrow or wider insert. Kit setup is narrow 0. Be careful cause you can actually put them in wrong and go -2 and -4.
b121774 is offline   Reply With Quote
Old 01-27-2013, 02:59 PM   #4780
teeforb's Avatar
My car has 30 deg front bulk head and RF rear blocks. Is this why don't have a lot of steering?
Old 01-27-2013, 03:01 PM   #4781
t0p_sh0tta's Avatar
New or not, you should at the very least look through the manual. It'll answer just about everything you've asked thus far.
Aside from the hub inserts it's about the same as any other recent K car. I just wish they'd come up with an easier way to change anti-squat. I hate sliding those spacers in there.
Lower caster generally makes initial steering more responsive. Where are you looking for steering? On power? Entering a turn? Middle? Exiting? Have you compared your setup to any others? What surface? What tires? What length rod-ends are you running on the shocks?
Old 01-27-2013, 03:04 PM   #4782
fastestwon's Avatar
Trader Rating: 15 (94%+)
Originally Posted by b121774 View Post
What did you notice in handling differences?
the car is planted feels like a cross from RM to MM . it is lighter but feels heavy and rotates very nice . i let some other guys drive it and and they all loved how well it powers out of the corner and still has a lot of turn in as well . my car was 1653 grams after the mods it is 1521 grams
fastestwon is offline   Reply With Quote
Old 01-27-2013, 03:07 PM   #4783
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Cut out part of the hole so you can then just loosen the screws a little bit and then slide the piece in between the chassis and the rear block. Does that make sense?
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 01-27-2013, 03:24 PM   #4784
I imagine its rolling more and putting more weight on the outside wheels providing more exit steering. Hmmm, might have to try that..
Old 01-27-2013, 03:27 PM   #4785
teeforb's Avatar
Anyone want to trade my rear alum RF for alum RF2?
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22971 Today 08:14 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
