    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree16Likes
Old 01-27-2013, 07:21 AM   #4756
Trader Rating: 38 (100%+)
AT THE REEDY RACE - from what I can tell when I was watching Tebo and Hara run yesterday, Tebo car much more stable than Hara and I was sitting right on the straight away inspecting both buggies very carefully through the heat. The slipper pads Hara were running were kind of "cooper color". He did say to me they are an upgrade and not part of the AVID kit. Hope this helps, I am all new to the buggy scene.
noworries is offline   Reply With Quote
Old 01-27-2013, 07:25 AM   #4757
Originally Posted by killa B View Post
Sorry if this has already been asked but is there a better shock tool for rb6 like alum i keep stripping the plastic ones thanks
I got the shock tool from Tom Eper. It works great.
Old 01-27-2013, 08:47 AM   #4758
fastestwon's Avatar
Trader Rating: 15 (94%+)
Originally Posted by Just1More View Post
I run the Avid slipper with no issues.. double checked just now for marks on the inside of the gear cover and there isn't a scratch. Did you assemble it properly? There's a spacer you leave out when you use it on a Kyosho, but use on the B4.1.. I did notice my Avid spur and Robinson aluminum pinion starting to make noise.. so i have a new spur here soaking in a cup of water overnight before i install(recommendation from Avid to make the gear quieter). We'll see how well that works.
i had same issues i soaked them in a sealed Ziploc bag for three days and my car has been whisper quite .
i got to race my car with the new sideways short pack modification. just when i thought it could not get any better . i was wrong it is way better with some changes i made if anyone is interested pm me .
will have the race video up later
fastestwon is offline   Reply With Quote
Old 01-27-2013, 08:51 AM   #4759
Trader Rating: 72 (100%+)
What did you notice in handling differences?
b121774 is offline   Reply With Quote
Old 01-27-2013, 08:57 AM   #4760
ryanpatrickgore's Avatar
Trader Rating: 14 (94%+)
Do any if you guys run saddles with the rear motor config? Seems like it would work similar to the shorty?
ryanpatrickgore is offline   Reply With Quote
Old 01-27-2013, 10:28 AM   #4761
I never heard about soaking the spur gear in water ... might have to try it, although my stuff is pretty smooth and quite as it is.
So there are upgrade avid slipper pads?? I just looked on Avid's website and didn't see any "upgraded" drive pads or slipper pads ....
ChadBlanton is offline   Reply With Quote
Old 01-27-2013, 10:54 AM   #4762
teeforb's Avatar
Trader Rating: 94 (100%+)
Send a message via Yahoo to teeforb
Anyone has a setup that gives you the most steering? This is for the 17.5 blinky mode. Thx
$$ Team High Budget $$
17.5 stock buggy fb page
https://www.facebook.com/groups/17.5stockbuggy/
teeforb is offline   Reply With Quote
Old 01-27-2013, 11:20 AM   #4763
t0p_sh0tta's Avatar
Trader Rating: 35 (100%+)
I finally got to race the car yesterday, and it was pretty good. I started out with the kit setup, and really liked it. I wanted to tame turn in, so went with the +2 inserts, added another .5mm washer on the inner stud, and matched my best lap time with my 4.1.
I added .5 washer in the rear for the main, and quickly realized that was a change for the worse. I wasn't on the ideal tire, but still managed to qualify and finish in 2nd.
Is anybody else happy running the kit springs?
edit: Almost forgot, I also went to the 1mm anti-squat shim. Time to make a setup sheet.
I've met some of the strangest people while playing with my toy cars...
t0p_sh0tta is offline   Reply With Quote
Old 01-27-2013, 11:37 AM   #4764
my chassis just got the sent under the transmission, anyone else recently have this issue? did kyosho replace it
kompressor is offline   Reply With Quote
Old 01-27-2013, 11:50 AM   #4765
seth556's Avatar
Trader Rating: 42 (100%+)
I ran Tebo's CRCRC setup yesterday and it felt good, only thing I have different is .5* hubs since I wasn't on a super traction track. Car is easy to drive and consistent. I like it a lot, I feel much more relaxed with it than a B4.
seth556 is offline   Reply With Quote
Old 01-27-2013, 11:52 AM   #4766
Just1More's Avatar
Originally Posted by t8rtot View Post
K ok it's possible I have it spaced too far out, which spacer isn't to be included?
Thanks in advance
Found this:
Special Assembly Instructions:
Keep kit supplied gold Kyosho topshaft spacer. In instruction procedure, do not use AVID thick topshaft spacer (black). Replace the thick AVID spacer with the included gold kyosho spacer followed by 1 thin centering washer which will keep the inner slipper plate centered on the topshaft. Otherwise, assemble per instructions and use the included M3 slipper nut (5.5mm hex).
The Triad itself comes with an instructions card...and the Kyosho topshaft you bought from them came with another instruction card, find that one and you're golden. I keep mine in my pit box for this very reason.
Mark Clark
RB6
B44.1
TC6.1
Just1More is offline   Reply With Quote
Old 01-27-2013, 12:11 PM   #4767
t0p_sh0tta's Avatar
Speaking of hubs... I have a set of Kyosho gunmetal .5* hubs that I'd be willing to trade for gunmetal 0*.
Old 01-27-2013, 12:26 PM   #4768
Trader Rating: 18 (100%+)
The "team drivers Japan" setup on petit rc is very steering aggressive and would probably be a good starting point.
Ctimrun is offline   Reply With Quote
Old 01-27-2013, 01:09 PM   #4769
teeforb's Avatar
U have a link? I would love to try it
Old 01-27-2013, 01:14 PM   #4770
mof
http://www.petitrc.com/setup/kyosho/...UltimaRB6.html
mof is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22970 10-17-2017 05:10 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
