    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree25Likes
Old 01-26-2013, 12:41 PM   #4741
lbckevin's Avatar
Trader Rating: 91 (99%+)
another:
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 01-26-2013, 12:43 PM   #4742
lbckevin's Avatar
Cody Turner's RB6
Kevin Smith
Old 01-26-2013, 12:44 PM   #4743
lbckevin's Avatar
Tebo's new batter strap
Kevin Smith
Old 01-26-2013, 01:05 PM   #4744
Is possible for someone who is at the Reedy Race to ask the team drivers why they went back to a full size servo...is it because they now use shorties?
nitroargi is offline   Reply With Quote
Old 01-26-2013, 01:13 PM   #4745
lbckevin's Avatar
The shorty servos are having problems with stripping gears and not enough torque. I tried ( as well as alot of other locals at West Coast) the KO shorty servo and they all stripped the gears. I went back to a RSX response servo and its great.
Kevin Smith
Old 01-26-2013, 02:02 PM   #4746
Hey Kevin,
I am running Sanwa SRG-BLS since I updated to the RB6 with no issues...my questions is because the new car is a little front heavy in the air, I thought that with the full size servo the added weight will only make it to dive more
Maybe I have to try and see for myself...
Old 01-26-2013, 03:20 PM   #4747
Originally Posted by nitroargi View Post
They suppose to give you a little more traction that the RB6 rear arms...the question is, do you have to adjust the length of the rear shocks when you make the switch and if so what is the better way...I am guessing by changing the ball ends with the medium ones?
I was told the opposite. I believe they free up the rear and allow it to rotate better.
shark2288 is offline   Reply With Quote
Old 01-26-2013, 08:57 PM   #4748
killa B's Avatar
Sorry if this has already been asked but is there a better shock tool for rb6 like alum i keep stripping the plastic ones thanks
killa B is offline   Reply With Quote
Old 01-26-2013, 09:15 PM   #4749
BranVita's Avatar
Trader Rating: 39 (100%+)
theres a user "eper" who makes a alum version and sells them, as of the moment, its the only one available on the market I believe. I saw AVID coming out with one aswell.
Branden V.
Kyosho Rb6 | Orion R10 Pro | SchuurSpeed 17.5 | Savox 1257
Kyosho SC-R SP | Orion R10 Pro | SchuurSpeed 17.5 | Savox 1258
BranVita is offline   Reply With Quote
Old 01-26-2013, 09:46 PM   #4750
Mahak2137's Avatar
GMK Supply is coming out with a very nice set with holders for the shock top and body as well. I've seen the prototype set a while back and it works awesome. Top notch like all the GMK stuff!
Chris Maghakian
Team Associated | Reedy | Schelle Racing Innovations | AKA | TQ Wire | HRP | Upgrade RC
Mahak2137 is offline   Reply With Quote
Old 01-26-2013, 09:49 PM   #4751
t8rtot's Avatar
Trader Rating: 14 (94%+)
Hey Kevin,
If your car is front heavy something is wrong. What is your layout/setup like?
I have one of EPER's tools, works great, and is good quality.
Now on to my question, I put on the avid slipper setup and it rubs the gear cover bad. I tried heating the cover and pushing it out but there isn't enough material. Any solutions? Optional gear covers?
Sfida
t8rtot is offline   Reply With Quote
Old 01-26-2013, 10:08 PM   #4752
Just1More's Avatar
I run the Avid slipper with no issues.. double checked just now for marks on the inside of the gear cover and there isn't a scratch. Did you assemble it properly? There's a spacer you leave out when you use it on a Kyosho, but use on the B4.1.. I did notice my Avid spur and Robinson aluminum pinion starting to make noise.. so i have a new spur here soaking in a cup of water overnight before i install(recommendation from Avid to make the gear quieter). We'll see how well that works.
Mark Clark
RB6
B44.1
TC6.1
Just1More is offline   Reply With Quote
Old 01-26-2013, 10:21 PM   #4753
Hey t8rtot,
My base setup is based on the Japan Team sheet since I mainly running on dirt...I use saddles for the same reason...first time out with the RB6 the car was slightly nose diving in jumps...that't why I thought team drivers used the low profile servo so I never tested a normal size one!
On the Avid I have to also report that I used it too and there are no issues with the gear cover...
Old 01-27-2013, 07:16 AM   #4754
t8rtot's Avatar
I would dbl check ride height and rebound, I ran that for a few weeks and it was balanced for me with a full sized servo in front. I used a shorty lipo however. Mmm
K ok it's possible I have it spaced too far out, which spacer isn't to be included?
Thanks in advance
Sfida
Old 01-27-2013, 08:07 AM   #4755
Trader Rating: 38 (100%+)
Originally Posted by t8rtot View Post
Hope there weren't any doubters of HARA. It doesn't matter the class, he's a man amongst children. He's the reason my first rc was an HPI. You don't win WC in different classes and be on the podium for the last three 1/8th buggy worlds on accident.
As soon as I saw that rb6 in his livery I got chills. Looks like he's on to something with that MM.
Can't wait to see that setup.
I was at the Reedy race yesterday. Spoke with Hara and inspected his RB6 very closely. He has the AVID setup and he suggested also on dirt/clay to run the upgraded slipper pads from AVID. He was super nice and I found Tebo, Cody and Hara very helpful.
noworries is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22982 Today 01:26 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15026 11-02-2017 04:19 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 09:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 05:30 PM
