    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree25Likes
Old 01-23-2013, 10:17 PM   #4651
gelshocker's Avatar
Originally Posted by savageboy69 View Post
one thing that i started doing awhile back that helped alot was try whatever adjustment you are wondering about but exagerate it, so like how you are asking about shims, rather than adding one shim and possibly not noticing anything add 3 or 4, then you get it stuck in your head what is accomplished by adding shims, or even shock position, if you are thinking of laying a shock in one hole, go all the way, if its too much back it off a hole, but at least you know for future reference what changes will do what,
I think that's a good tip. Not everyone runs on perfect indoor bluegroove TC tracks . Adding 0.5 shim under the sus block is gonna make one iota of a difference on a loamy blown out dirt track
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 01-23-2013, 10:22 PM   #4652
Trader Rating: 74 (100%+)
Yea, I unintentionally tried a drastic change. I went from the 0 caster inserts to the 4 inserts looking for a calmer feel but accidently put them in backwards which was actually -4. Holy twitchy!
b121774 is offline   Reply With Quote
Old 01-23-2013, 10:33 PM   #4653
savageboy69's Avatar
Trader Rating: 88 (100%+)
lol yea, but like i was saying now you know the effects of changing your caster and you can refer back to that if need be. you see a lot of people that will just copy a setup go run there buggy and it may be drivable or it may completely suck, the fact is that everyone drives different and whats different things from there cars, you have to know what changes to make to get the desired results
Xray|Rc America|Hudy|FX engines|Tekin|SOR graphics|LFR|Ogio|SRT servos|
XB8 2016
XB8-E 2016
XB4 2017
savageboy69 is offline   Reply With Quote
Old 01-24-2013, 06:22 AM   #4654
t0p_sh0tta's Avatar
Trader Rating: 35 (100%+)
How do you go about changing the front track width? Are there different width front suspension blocks?
I'll assume there are wide and narrow king pin braces too.
Does the RB6 come with the wide or narrow option, and which of the RB5s comes with the other?
edit: The manual refers to the suspension block as "standard," so am I correct in assuming the the RB6 comes with the more narrow block?
I've met some of the strangest people while playing with my toy cars...
t0p_sh0tta is offline   Reply With Quote
Old 01-24-2013, 08:10 AM   #4655
Trader Rating: 29 (100%+)
You change the track width by putting the 0-4 caster inserts in or out. In is narrow out is wide..
Yzlvr is offline   Reply With Quote
Old 01-24-2013, 08:15 AM   #4656
Trader Rating: 23 (100%+)
The caster block uses an insert with an offset hole which can be inserted from the front or back of the caster block to adjust width i think 2mm per side and is also used to adjust caster up to +/- 4* from 0.
Mike Coreia
Bumps & Jumps
www.bumpsandjumpsrc.com
Mike C is offline   Reply With Quote
Old 01-24-2013, 08:31 AM   #4657
t0p_sh0tta's Avatar
Ah, okay. Just flip them. Thanks.
Old 01-24-2013, 08:37 AM   #4658
eper's Avatar
Trader Rating: 14 (100%+)
if you are trying to run the narrow front set up you need to exchange the right and left hand side inserts. be sure you dont put them in upside down or the car will be twitchy as you will be removing caster. also top shotta i recommend putting them in just like the manual suggests until you figure out what you want from the car. then play with that
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 01-24-2013, 09:58 AM   #4659
pekow91's Avatar
Trader Rating: 45 (100%+)
My track just announced that they are going to ban the D3.5 motor (http://www.roarracing.com/?p=1842) in our blinky 17.5T class. Which renders my brand new Fantom D3.5 obsolete. You guys have any suggestions on another motor? I know this really isnt thread specific but I wanted to see what you guys were running in your RB6s since its a little heftier than other buggies.
Kyosho RB6 | Kyosho MP9 TKI3E | Xray XB4
pekow91 is offline   Reply With Quote
Old 01-24-2013, 10:02 AM   #4660
The Reedy Sonic seems to be the next fast 17.5. What track banned them? Norcal?
Old 01-24-2013, 10:10 AM   #4661
pekow91's Avatar
Yeah they just announced it last night. They are going to let everyone use it for the rest of the winter buggy series and then ban it. Which kind of sucks because they sold a good amount of them too.
Old 01-24-2013, 10:21 AM   #4662
offroad dude's Avatar
Trader Rating: 25 (100%+)
That is a great IDEA or METHOD to the madness. Because I don't care where you are or when it was, you will remember that exact date and time when your car sucked....lol
offroad dude is offline   Reply With Quote
Old 01-24-2013, 10:27 AM   #4663
Trevor Williams's Avatar
Trader Rating: 195 (100%+)
If I were going to buy a 17.5 it would be a Schuur Speed.....hands down.
RC10-B6d | RC10-B64d
SmacTrac
#WeAreAE #ReedyPower #AE4Life
Trevor Williams is offline   Reply With Quote
Old 01-24-2013, 10:32 AM   #4664
I own the d3.5, the Sonic and the schuurspeed. I could never get the schuurspeed to be as fast as the other to. I tried all different gearing and timing. The Sonic with it timed to the silver cap screw and geared at 29/72 is dam fast, just as much as the d3.5.
Old 01-24-2013, 10:50 AM   #4665
Kooz's Avatar
+1 ON THIS HELPFUL ADVICE!
Kooz is offline   Reply With Quote
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15027 11-22-2017 09:29 AM
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22984 11-21-2017 10:14 AM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 09:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 05:30 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
