    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree16Likes
Old 01-23-2013, 01:46 PM   #4636
joeymdz's Avatar
Send a message via MSN to joeymdz
^^ that's what i meant by length... i didn't want to ask how long is your shaft length on a public forum^^
RC Plus*McKune Designs*NW Hobbies*Premier RC Raceways*Daves Tracks
joeymdz is offline   Reply With Quote
Old 01-23-2013, 02:00 PM   #4637
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 01-23-2013, 02:37 PM   #4638
t8rtot's Avatar
Trader Rating: 14 (94%+)
sorry guys if i'm blunt.. just my personality, i guess.. i probably spend way too much time on here so when i see questions like "this doesn't fit, what should i do?" or my favorite "i know this was asked 100x's but XYZ". most of the time i search (on here and google) before i even touch the post reply button. i built my first kit, broke in my first Picco and restored my 1979 monte carlo at 22 by google and searching various car forums.
idk seems simple enough to me. i like to help as much as the next guy but i don't like those that dont even try do the research on there own. #Rant Over.
On a lighter note, i'll provide feedback of my own about the slipper tonight/tomorrow as well as the -1 arms and fitment of various exotek parts. i'm going to play with ball stud heights as well.
Sfida
t8rtot is offline   Reply With Quote
Old 01-23-2013, 02:56 PM   #4639
Super Moderator
new info for all you new RB6 buyers on post #1.
- RCSpecialties -
Old 01-23-2013, 02:58 PM   #4640
offroad dude's Avatar
Trader Rating: 25 (100%+)
Dude you are the MAN!
offroad dude is offline   Reply With Quote
Old 01-23-2013, 03:16 PM   #4641
Rfury's Avatar
Send a message via AIM to Rfury Send a message via Yahoo to Rfury
Hey Cap. The 22 does not use a 2.6:1 transmission ratio. It is 2.43:1. So, 22 gearing would not be the same as a B4, RB5 or RB6.
Kyosho RB6
Kyosho ZX6
Kyosho MP9e TKI
Rfury is offline   Reply With Quote
Old 01-23-2013, 03:24 PM   #4642
Super Moderator
- RCSpecialties -
Old 01-23-2013, 03:32 PM   #4643
Trader Rating: 18 (100%+)
fixed
Ctimrun is offline   Reply With Quote
Old 01-23-2013, 04:51 PM   #4644
ben73's Avatar
Trader Rating: 40 (100%+)
Originally Posted by SAMCRO View Post
http://www.petitrc.com/setup/kyosho/...CRC2013011213/
The setup above calls for an RB5 front axle. Just wondering what the difference is... Yes, I bought some kyosho wheels today...
from what I could determine form reading and searching through dozens of pages was that the RB6 hex in thinner than the RB5 one and when the whole assemble is on the car with a JC front or other wheel there was the chance that there could be some slight binding.
I am about to build up my RB6 so I was planning on installing the RB5 mod from the start.
ben73 is offline   Reply With Quote
Old 01-23-2013, 06:05 PM   #4645
I had a 22 and i'm pretty sure it had a 2.6 transmission ratio.
shark2288 is offline   Reply With Quote
Old 01-23-2013, 06:07 PM   #4646
Negative Losi has a 2.43 ratio for their trannys.
Gitsum is offline   Reply With Quote
Old 01-23-2013, 06:32 PM   #4647
Originally Posted by HalfManHalfGod View Post
I've read most of that but i'm not sure how to translate that to the setup sheet. For example ackerman:
More
(Bigger difference in steering angle
between the two font wheels) More Ackermann makes the steering more consistent, and smoother.
It just feels right, also at low speeds and in tight turns.
Less
(Smaller, or no difference in steering
angle between the two font wheels) Less Ackermann makes the steering more agressive at high speeds.
The car turns in more agressively.
It doesn't work well when either traction or cornering speeds are low.
Would putting shims on the ballstuds that attach to the ackerman give me more or less ackermann
My track I would consider small with high traction clay that has 3 180degree hairpin turns. I want to be able to make as tight as a turn as I can and carry as much speed as possible.
Another stupid question: What is the easiest way to detach the turnbuckles from the ballstuds? I know i'm doing it completely wrong.
I'm wondering the same thing about adding shims to the ballstuds on the steering rack? I see Tebo added 1mm to his latest setup.
Old 01-23-2013, 07:47 PM   #4648
savageboy69's Avatar
Trader Rating: 88 (100%+)
one thing that i started doing awhile back that helped alot was try whatever adjustment you are wondering about but exagerate it, so like how you are asking about shims, rather than adding one shim and possibly not noticing anything add 3 or 4, then you get it stuck in your head what is accomplished by adding shims, or even shock position, if you are thinking of laying a shock in one hole, go all the way, if its too much back it off a hole, but at least you know for future reference what changes will do what,
Xray|Rc America|Hudy|FX engines|Tekin|SOR graphics|LFR|Ogio|SRT servos|
XB8 2016
XB8-E 2016
XB4 2017
savageboy69 is offline   Reply With Quote
Old 01-23-2013, 07:55 PM   #4649
Rfury's Avatar
Yeap. Losi always has used the 2.43:1. I have no idea why when everyone else is 2.6:1. They see an advantage in it somewhere.
Kyosho RB6
Kyosho ZX6
Kyosho MP9e TKI
Old 01-23-2013, 08:51 PM   #4650
RShockley's Avatar
22 has a 2.43 gear ratio
Richard Shockley
Kyosho RB6 / Kyosho RT5
Mike's Hobby Shop......Carrollton, TX
Kalgard / Epic Cameras / SMX Optics / Heavenly Hobbies
RShockley is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22970 Today 05:10 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
albertv78
