    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 01-22-2013, 01:33 AM   #4561
OMG23RC's Avatar
Trader Rating: 21 (100%+)
Anyone know a trusted shop where they have both aluminium wide rf and rr suspension holders in stock? It seems as though they are out of stock everywhere (amain,stormer,speedtech,mammoth etc)
www.sydneyrc.com - Sydney's best off road track.
Kyosho|Associated|Viper|Schuur Speed|Savox|Sanwa.
RB5 SP2 WC|Viper vtx10 B.E|Schuur Speed 17.5|Savox 1257tg|Sanwa MT-4
SC-R|Turnigy Trackstar Turbo|Reedy sonic 10.5|BMS-616DMG|Sanwa MT-4
B44.2|Viper vtx10r|Viper 8.5|Savox 1258tg|Sanwa MT-4
OMG23RC is offline   Reply With Quote
Old 01-22-2013, 08:40 AM   #4562
fullsyzz's Avatar
Trader Rating: 102 (100%+)
Originally Posted by Jason.Dias View Post
Hi fullsyzz,
The reason we're using these axles is because we are using the narrow suspension arm mounts (UMW511+UMW512), using these mounts narrows the rear end of the car by about 2mm, in order to counter act that we use the longer axle (UM510-02) with a 1mm axle washer(W0149GM) between the hub and the wheel hex.
Hope that helps.
Jason Dias
Team Kyosho
Perfect. Thanks!
fullsyzz is offline   Reply With Quote
Old 01-22-2013, 09:20 AM   #4563
Hi fullsyzz,
Hope that helps.
Jason Dias
Team Kyosho
Are you using the RB-6 gull wing a-arm or the rb5 sp2 one hole a-arm with narrow hinge pin holders? Currently I went back to the rb5 sp2 one hole a-arm with the wide hinge pin holder(UM514GM & UM515GM) with good results.
Turbo
Turbo911 is offline   Reply With Quote
Old 01-22-2013, 09:38 AM   #4564
Kooz's Avatar
Originally Posted by HalfManHalfGod View Post
Is there a guide on how to read the setup sheets? I understand how to setup my car following the sheet but what effect will it do? Like what would 1mm shims on the ackerman do? Shims under ball studs etc.
http://www.xxxmain.com/bookz.shtml
Well worth the money! Even though it is written for TC it still applies to off road.
Has a very helpful decription of what every adjustment does for entering, mid and exiting corners. Weight transfer!
How to fix...
Entering Push (Off-Power)
Entering Loose (Off-Power)
Mid-Corner Push (Neutral Power)
Mid-Corner Loose (Neutral Power)
Exiting Push (On-Power)
Exiting Loose (On-Power)
In other words... If you can tell the book what your car is doing wrong, it can tell you how to fix it.
Kooz is offline   Reply With Quote
Old 01-22-2013, 09:48 AM   #4565
fullsyzz's Avatar
Turbo
The Cody Turner setup I was looking at was using the stock 6 arms, but with the arms flipped using the one hole side.
Old 01-22-2013, 10:21 AM   #4566
aloksatoor's Avatar
Trader Rating: 42 (100%+)
ebay japan, I got mine in 10 days. Rating was 99% for that trader. Not exactly what you want but other option is to buy used or hunt in LHS.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 01-22-2013, 10:25 AM   #4567
B00t13g's Avatar
I'm very happy with my car for medium traction a good mix of technical with a handful of jumps. Ill get the setup posted tonight.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 01-22-2013, 10:29 AM   #4568
Coach Townsend's Avatar
JESUS CHRIST, KYOSHO AMERICA, BYRON FUEL, PEAK RACING, ORION
Did forget to mention my JOB!!!DAMN THEM TOO!!!
Coach Townsend is offline   Reply With Quote
Old 01-22-2013, 10:35 AM   #4569
How to fix...
Thanks everyone for your input! I'll pick this one up.
Is push equal to understeer and loose is oversteer? I'm more used to on-road terminology.
HalfManHalfGod is offline   Reply With Quote
Old 01-22-2013, 10:48 AM   #4570
B00t13g's Avatar
For tuning guides check out of the hudy offload guides and the x ray setup guide for the t3.
Mackenzie Meyercord
Old 01-22-2013, 10:48 AM   #4571
aloksatoor's Avatar
Yep spot on.
Old 01-22-2013, 11:15 AM   #4572
Another stupid question: What is the easiest way to pop off the turnbuckle from the ball stud? I'm having a hell of a time trying to pry these things off which I know i'm doing completely wrong.
Old 01-22-2013, 11:20 AM   #4573
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
These terms are equally used in on-road.. but yes, understeer means it pushes, and oversteer means the rear end kicks around too easily.
I use a pair of normal pliers, and I "roll" the ballcup forward or backward until it comes off.
Make sure you center BOTH ballcups onto the ball studs so once popped back on, the entire link can rotate/twist both directions equally. You don't want a bind.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 01-22-2013, 11:25 AM   #4574
corky_rc's Avatar
Originally Posted by Coach Townsend View Post
Dudes serious, even has his car under 24hr surveillance,
* Kyosho TKI3 - Alpha - Futaba - AT Racing - Beta Tyres.
* Kyosho TKI2e - Futaba - Tekin - Pro Amps Batteries - Beta Tyres.
* Kyosho RB6 - Futaba - Tekin.
* Bodies By Scott's RC Designz.
* Beta Tyres www.wprcracing.com * Pro Amps International.
corky_rc is offline   Reply With Quote
Old 01-22-2013, 11:30 AM   #4575
Turbo
I am still using the RB6 arms flipped to the one hole side, I like the feel of that a little more on the current layout, Drew Moller and a few others like the flat arms better. But with a fresh layout for Reedy we will have to see which feels better.
Jason Dias
http://www.facebook.com/jasondiasrc
Team Kyosho - AKA - KO PROPO - Hobbywing - Schuur Speed - Schelle Racing - OCRC Raceway - Tuning Haus
Jason.Dias is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
