    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 01-21-2013, 07:56 PM   #4546
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by joeymdz View Post
(Thank you Brandon for your help and ideas)
Lookin good! And you're very welcome
Originally Posted by HalfManHalfGod View Post
Is there a guide on how to read the setup sheets? I understand how to setup my car following the sheet but what effect will it do? Like what would 1mm shims on the ackerman do? Shims under ball studs etc.
This is your new bible:
http://users.telenet.be/elvo/
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 01-21-2013, 07:58 PM   #4547
Super Moderator
Originally Posted by seth556 View Post
Hey guys, I just got the RB6 and it drives well but it's like I have to drive it very carefully as it wants to drive all from the front. Going into the corners it feels good but then wants to pivot on the front way too much. It seems very characteristic of rb6's. Plenty of forward grip, just need it to be more lazy in the middle of the corner. It's fast, just feels like it always wants to kill me in the middle of the corner.
You either have a glaring setup issue, a static weight issue, or a tire/insert issue. Without looking at your car, tires and inserts, its impossible to tell. Post your complete setup, and make sure everything is true, even, measured, and accurate based on the setup sheet first. Then trade tire with another rb6 on the track to make sure you don't have a tire problem.
- RCSpecialties -
Old 01-21-2013, 08:19 PM   #4548
t8rtot's Avatar
Trader Rating: 14 (94%+)
When the weight transfers to the rear?
There are a few ways to fix this, it could come down to putting closed cell foams up front. This really tamed down the car for me.
Or making changes to your setup.
Give us more info, then we'll be glad to help you out.
Sfida
t8rtot is offline   Reply With Quote
Old 01-21-2013, 08:27 PM   #4549
I've read most of that but i'm not sure how to translate that to the setup sheet. For example ackerman:
More
(Bigger difference in steering angle
between the two font wheels) More Ackermann makes the steering more consistent, and smoother.
It just feels right, also at low speeds and in tight turns.
Less
(Smaller, or no difference in steering
angle between the two font wheels) Less Ackermann makes the steering more agressive at high speeds.
The car turns in more agressively.
It doesn't work well when either traction or cornering speeds are low.
Would putting shims on the ballstuds that attach to the ackerman give me more or less ackermann?
My track I would consider small with high traction clay that has 3 180degree hairpin turns. I want to be able to make as tight as a turn as I can and carry as much speed as possible.
Another stupid question: What is the easiest way to detach the turnbuckles from the ballstuds? I know i'm doing it completely wrong.
HalfManHalfGod is offline   Reply With Quote
Old 01-21-2013, 08:44 PM   #4550
Just1More's Avatar
Originally Posted by teeforb View Post
so the losi 22 servo horn fits with zero issue or hacks?
Originally Posted by Trevor Williams View Post
my kyosho gunmetal servo horn fit perfect with no issues.....
why TLR?
The losi is similar in color and is all aluminum, no plastic inserts. I had to drill the threads to fit the Kyo ballstud(I used a body reamer and just enlarged both sides), i put a 1mm shim behind the ballstud to make it very very close to OEM Kyosho offset and a nut on the backside. I know someone will ask so i'll post a pic asap
On a side note i won the A main tonight, but broke a ballcup off in a qualifier. It broke right where the turnbuckle ends inside it.
Mark Clark
RB6
B44.1
TC6.1
Just1More is offline   Reply With Quote
Old 01-21-2013, 08:59 PM   #4551
joeymdz's Avatar
Send a message via MSN to joeymdz
Well worth the money!!!
http://www.teamassociated.com/news/l...ts_iPhone_App_
RC Plus*McKune Designs*NW Hobbies*Premier RC Raceways*Daves Tracks
joeymdz is offline   Reply With Quote
Old 01-21-2013, 09:31 PM   #4552
Jtipsy's Avatar
Guys to let you know Diggity Designs has some new carbon fiber parts for the Rb6 car.
http://www.diggitydesigns.com/ is a link to his site. Great guy to deal with also.
Joseph Tuepker
Jtipsy is offline   Reply With Quote
Old 01-21-2013, 09:52 PM   #4553
seth556's Avatar
Trader Rating: 42 (100%+)
Originally Posted by K_King View Post
Setup and track type?
It's the new Tebo CRCRC setup. During the day I put on the .5 hubs and it was only a little better, still the same main tendency to want to slide mid corner. Track is indoor, decent traction, and small.
seth556 is offline   Reply With Quote
Old 01-21-2013, 10:00 PM   #4554
t8rtot's Avatar
There's your issue, put the kit setup on it and let us know what you think.
And definately take out the limiter and put long ball ends on the rear and med. on the front shocks.
Sfida
Old 01-21-2013, 10:04 PM   #4555
joeymdz's Avatar
Is it exactly tebos set up? Remember that track has tons of traction and it was huge! May e you should look at a different set up.. Brandon has a great one!! (shameless plug)
Old 01-21-2013, 10:05 PM   #4556
teeforb's Avatar
Trader Rating: 94 (100%+)
Send a message via Yahoo to teeforb
I've been using the for a while now. Handy app
$$ Team High Budget $$
17.5 stock buggy fb page
https://www.facebook.com/groups/17.5stockbuggy/
teeforb is offline   Reply With Quote
Old 01-21-2013, 10:19 PM   #4557
fullsyzz's Avatar
Trader Rating: 102 (100%+)
Why does the Cody Turner setup call for um510-02 axles? I understand they are a different length but what's the reasoning behind using them?
fullsyzz is offline   Reply With Quote
Old 01-21-2013, 10:22 PM   #4558
Trader Rating: 101 (99%+)
That seems the defeat the purpose. The plastic that fits on the servo is the 1st to give.
I have had the same one on my RB5 WC & RB6, with another on my RT5 without any problems...
~ Richard Watchorn ~
* Team Associated/Reedy Electronics * OCRC Raceway *
* Schelle Racing * CBuilt Designs * Complex Ink *
desertracerdad is offline   Reply With Quote
Old 01-21-2013, 10:40 PM   #4559
B00t13g's Avatar
They still have the same parts posted that they've had for a good while...
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 01-22-2013, 01:04 AM   #4560
Hi fullsyzz,
The reason we're using these axles is because we are using the narrow suspension arm mounts (UMW511+UMW512), using these mounts narrows the rear end of the car by about 2mm, in order to counter act that we use the longer axle (UM510-02) with a 1mm axle washer(W0149GM) between the hub and the wheel hex.
Hope that helps.
Jason Dias
Team Kyosho
Jason.Dias is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
sho yoshida
