    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree15Likes
Old 08-19-2012, 07:25 PM   #436
Z00M's Avatar
Trader Rating: 15 (100%+)
Looking at the pics from the supernationals, it looks as though we now have the option to run the rear shocks on the front or rear of the arm like with the Lazer.
Supernationals picture:
Press release picture:
My blog: http://mikesrc.wordpress.com
XRAY XB4
## NOSRAM ## XRAY ## KO ##
www.nbhc.com.au - www.teamxray.com
Z00M is offline   Reply With Quote
Old 08-19-2012, 08:02 PM   #437
Trader Rating: 91 (100%+)
Press release pic is mid motor, supernats pic is rear.
Eric Tomczyk is offline   Reply With Quote
Old 08-19-2012, 08:15 PM   #438
gelshocker's Avatar
Originally Posted by asc6000 View Post
not true, same for most top level cars. Even puds like me can build a car out of the box at a big race and finish 2nd to Kinwald. I can also change so much stuff I get my car so out of tune I can barely run mid pack locally sometimes. Done both.
Pick up one of the latest RB5 setup sheets, and you'll need to dremel the original front tower to free up the big bores and build a +13mm chassis. Body is not Kyosho it is Proline bulldog. Not to mention the NCG arms will set you back a fair coin, whereas RB6 comes with gull wing arms stock. Though RB5 parts will be in ample supply I expect RB6 setup development going forward.
I never said you can't run the car box stock either, more power to you
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 08-19-2012, 08:22 PM   #439
Z00M's Avatar
Good work, I'm not as observant as I thought! ha ha
XRAY XB4
Old 08-20-2012, 08:52 AM   #440
Was tebo running the SP2 or the WC front hinge pin holder on the RB6? I know it was blue, as shown in the previous pics, but it is hard to tell which one it is. In the manual, it appears the hinge pin holder and the bulkhead have new part numbers. Anyone know if they are different? Or which version he was using?
Also did he have red or pink springs in the rear? The color was hard to decipher.
Entr0phy is offline   Reply With Quote
Old 08-20-2012, 09:32 AM   #441
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
He was running red rear, and pink front.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 08-20-2012, 09:33 AM   #442
Afun's Avatar
Trader Rating: 19 (95%+)
Questions for the Ultima Gurus....
Ride height for RB6 or RB5
Any toe or Camber angles
Gearing 48 pitch on these cars
Saddle packs or Single Layout
What is the mm of the wheel hexes
This may be my next build... May retire the b4.1
Afun is offline   Reply With Quote
Old 08-20-2012, 09:43 AM   #443
Moderator
Posvar's Avatar
Trader Rating: 462 (100%+)
Ride height varies but you can start with front arms level and rear bones level, toe varies as well but I run 1 degree negative camber front and rear and no toe. 48p gears. Single stIck or shorty pack and 12 mm hexes all around.
Having fun with my 9 year old and running Kyosho cars!
Posvar is offline   Reply With Quote
Old 08-20-2012, 10:56 AM   #444
Afun's Avatar
Got it. You think your height is equal front and rear about 25mm
Old 08-20-2012, 11:09 AM   #445
Moderator
Posvar's Avatar
Close. 23-25 is about right. That is just me....the other guys may have better info.
Old 08-20-2012, 11:39 AM   #446
mdowney's Avatar
Trader Rating: 21 (100%+)
24mm front, 23.5mm rear is pretty standard to start with, then tune to the track conditions.
Mike Downey
I try all of the RC kits and usually race at Tacoma RC Raceway
mdowney is offline   Reply With Quote
Old 08-20-2012, 05:36 PM   #447
Afun's Avatar
Thanks Guys... I might just get into this build in September
Old 08-20-2012, 06:38 PM   #448
yodace's Avatar
R/C Tech Charter Subscriber
Will the rb5 pitbull body work on rb6?
yodace is offline   Reply With Quote
Old 08-20-2012, 07:16 PM   #449
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
With the way the chassis is laid out and with the increase in length it obviously won't be a direct fit. If you put it on there I expect it to distort the body into something that just won't work as good as the stock body.
This is all speculation on my part though. When I decide to get one I won't be using the body off of my RB5.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 08-20-2012, 07:44 PM   #450
mdowney's Avatar
Yeah, the chassis on the RB6 is significantly more narrow. I wouldn't expect an RB5 body to be usable on an RB6.
Mike Downey
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22968 Today 04:05 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
05PSD
