    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0°/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree17Likes
Old 01-19-2013, 07:10 PM   #4456
MrHistory's Avatar
Originally Posted by SAMCRO View Post
If you guys run slicks then try the hot bodies pink compound when traction reduces. I have had the best luck with those. I tried losi pink and my car would bobble more.
We use barcodes and sand off the tread. The pro drivers at the track all use them with great results. I only run chassis screws for the rear position. I will try removing those and test. I shortened the wheelbase but didn't notice a major change.
Irwin RC 1/8th Pan Car Specialists - www.irwinrc.com
SPM Competition, WRC Racing, MIP, Novarossi
MrHistory is offline   Reply With Quote
Old 01-19-2013, 08:27 PM   #4457
SAMCRO's Avatar
Out track is like that as well. There aren't many chassis adjustments you can make. A lot of times it comes down to being smoother when you get on the gas
SAMCRO is offline   Reply With Quote
Old 01-19-2013, 10:57 PM   #4458
B00t13g's Avatar
I use a Eurus with 409s receiver. I just bought a RSX One-10 Servo. I use an Orion R10 ESC and 13.5 motor.
The servo worked immediately but it wiggles all the time slightly. As it sits on the bench you can hear the servo working and it shakes. Is this a voltage issue?
I was told to install a glitch buster in the extra Rx port and it didn't help at all.
Take your transponder off of it. Didn't see someone said that already. It did what you described on my sedan and that was the fix.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 01-20-2013, 01:31 AM   #4459
Just1More's Avatar
I stripped a servo horn today(all aluminum rack and XP servo) resulting in a DNF.. Turns out a losi 22 aluminum horn fits and has the proper angle. I had to drill the hole a little bigger with a body reamer though(it's threaded but the wrong threads). Also added a 1mm shim to bring it to almost exactly the same position as the OEM one, and put a nut on the back with loc-tite. Just a heads up for you guys
This one for Futaba
Also, anyone have tips for increasing rear grip? Running standard camber link positions with 1mm under both inner and outer ballstuds. Assuming tires are ok, any suggestions? 3 screws are out of side pods, battery can't move, rear gold springs and pink front(try white rear?).. feel free to toss ideas out there, Thanks
Re-edit: Anyone know how much rear Anti squat the RB6 has stock? say no shims under the front suspension hanger.
Mark Clark
RB6
B44.1
TC6.1
Just1More is offline   Reply With Quote
Old 01-20-2013, 03:36 AM   #4460
gelshocker's Avatar
Would placing the AMB on top of the lipo cause spiking? Thx
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 01-20-2013, 04:52 AM   #4461
Our track is clay with lots of traction but is described as not high bite like OCRC so our setup is really different. Everyone is running slicks now and its very fast. When the traction goes down a bit the rear end gets loose and spins out easily. What is the first adjustment I should make to fix this? I currently run a shorty battery fully back in car with a low pro servo. Is there too much weight in the rear? If I move the battery forward what will happen? Less traction I assume...
hey i notice you are from ny. where do you race? thanks.
glenng is offline   Reply With Quote
Old 01-20-2013, 07:17 AM   #4462
eper's Avatar
Trader Rating: 14 (100%+)
Check out my set up on petit rc it has tons of rear traction. Its under base setups and the name tom epting.
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 01-20-2013, 08:12 AM   #4463
t0p_sh0tta's Avatar
Trader Rating: 35 (100%+)
Do the AE slipper plates fit without issue? Having a brain fart over here.
I've met some of the strangest people while playing with my toy cars...
t0p_sh0tta is offline   Reply With Quote
Old 01-20-2013, 08:20 AM   #4464
Trevor Williams's Avatar
Trader Rating: 195 (100%+)
Big shout out to Zach Phillips for the help with my new car....thanks bro
ran the rb6 for the first time yesterday....best time with rb5 sp2 on current layout was 18-5:06.......yesterday in rd3 I got 19-5:16 with my new car....put me in the Bmain....got one of the bumps from the B into the A(19-5:04 in the Bmain).....Amain was stacked with some of the midwests' top drivers, I started 10th on the grid and finished 8th....was up to 5th at one point and didnt stay with it, this is my first season running mod and I LOVE IT.....rb6 is so good it's crazy! I was running cut green barcodes front and rear....I did pull a ball stud out of front left caster block...repalced with longer ones.
Im using all of Tebo's CRCRC camber link locations and ballstud spacers, shock locations, Im using stock 6 rear arms/hubs, narrow blocks....stock pistons with 35/30r TLR fluid, pink front/red rear springs.....I dont have any doubt whatsoever that the car will get better!
RC10-B6d | RC10-B64d
SmacTrac
#WeAreAE #ReedyPower #AE4Life
Trevor Williams is offline   Reply With Quote
Old 01-20-2013, 08:40 AM   #4465
JohnWinn's Avatar
Default Quick Questions
Cpt.America,
Can you provide closer shots on how you wired your ESC in your car? How and where did you route the wires?
To anyone:
Does a AE 1015 servo fit in the car?
Where can I get the "slipper eliminator"?
I will be ordering my car soon, much appreciated for the information. Thanks!
“We live in an age when unnecessary things are our only necessities.”
JohnWinn is offline   Reply With Quote
Old 01-20-2013, 08:47 AM   #4466
Trader Rating: 72 (100%+)
Originally Posted by JohnWinn View Post
Cpt.America,
To anyone:
Here for the slipper eliminator http://www.speedysracingparts.com/As...eliminator.htm
b121774 is offline   Reply With Quote
Old 01-20-2013, 08:59 AM   #4467
K_King's Avatar
Trader Rating: 39 (100%+)
Send a message via AIM to K_King
I was tweaking on th car last night with a new setup compared to what I had. Car felt really good even though it looked like it was crazy lol. Of course after this was taken the track hooked up a big more and was running really fast. But anyway.
http://www.youtube.com/watch?v=-wEP8COSVt8
https://dl.dropbox.com/u/18166464/SD..._Arm_Setup.jpg
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 01-20-2013, 09:20 AM   #4468
eper's Avatar
plates are a no pads you can run
new milford ct,
Old 01-20-2013, 09:27 AM   #4469
JohnWinn's Avatar
Originally Posted by b121774 View Post
thanks, I assume the B4 one?
Old 01-20-2013, 11:40 AM   #4470
MrHistory's Avatar
Thanks for all the feedback. Some of you mentioned the solution-transponder interference. I had the transponder on the back of the servo. I unplugged the trans and the servo went quiet. So now I have the trans on top of the servo and its fine. The RSX One-10 does make a little noise even without a trans in the car but works great.
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22971 10-20-2017 08:14 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
