    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree15Likes
Old 01-16-2013, 01:40 PM   #4366
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by t0p_sh0tta View Post
Has anybody successfully replaced the pins on the stock CVDs? I think I remember somebody saying that they were able to do it with the Hudy tool.
I heard it can be done as well.. but where to get the pins? how much is the tool? I know nada.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 01-16-2013, 01:48 PM   #4367
aloksatoor's Avatar
Trader Rating: 42 (100%+)
99 bucks. I have the tool and it does NOT work. Pins are too wide its designed to remove 1/8 size pins. The xray xb4 has 1/8 size pins in 1/10, thats the only car it will work for.
People use chain breakers but I do not have one myself. Anyone know when the MIP shafts are coming?
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 01-16-2013, 01:53 PM   #4368
Trader Rating: 18 (100%+)
Originally Posted by sir_thomas View Post
How about trying it off the kyosho pit mat and on something solid?? Would like to see if that makes a difference.
I was wondering the same thing so I also weighed it on our concrete floor and it made no difference, the picture looked way better on the K mat.
Ctimrun is offline   Reply With Quote
Old 01-16-2013, 01:56 PM   #4369
Gayosaka's Avatar
I recently changed all the pins on my Kyosho cars (FS2 & RB5) using a hammer, a pinion (to let the pin come out as you hammer it) and an old 1.5mm wrench.
Take your time and work with protective glasses, on a hard floor, it's not that hard to do.
RedWorkShop RZ6R / Kyosho RB6.6 / Kyosho ZX6.6 / Nosram power / Some MiniZ
www.rustidesign.com - Awesome custom stickers and cool stuff
Gayosaka is offline   Reply With Quote
Old 01-16-2013, 02:00 PM   #4370
aloksatoor's Avatar
Nice what size pins did you put back. I am scared of doing it that way might break a hand (I have sanded off chunks off my fingers with a belt sander once).
Old 01-16-2013, 02:03 PM   #4371
t0p_sh0tta's Avatar
Trader Rating: 35 (100%+)
And where did you find the pins?
I've met some of the strangest people while playing with my toy cars...
t0p_sh0tta is offline   Reply With Quote
Old 01-16-2013, 02:06 PM   #4372
B00t13g's Avatar
Put the exotek rack and bell cranks on. If you use the Kyosho metal servo horn you'll have to grind on one of the bell cranks as well as the horn.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 01-16-2013, 02:14 PM   #4373
Originally Posted by b121774 View Post
WTH? How did you get it that low? I did everything I could and still am at 1529. Slipper eliminator, no gear cover, small bore shocks, low pro servo, titanium everything. Lets see a pic without the body on.
Spektrum S6070 low profile servo, transponder, small Airtronics RX, Tekin RS Pro ESC, Fantom shorty pack, Fantom 17.5 motor. I wired the ESC with TQ 13 gauge wire and kept them as short as possible. The car also has an Avid Triad top shaft and slipper (entire Avid setup 7 grams lighter than stock setup with AE spur). It has diggity designs battery braces with Kyosho aluminum posts and RB5 carbon strap cut smaller. When it was weighed in the photo it had the three Exotek steering parts and the Exotek rear U-brace. I also have 14 grams of weight taped to the servo in that pic.
I originally had an Orion R10 Pro ESC in it but wanted to redo the wiring so I took it out and thought I would weigh it compared to the Tekin. Orion with wire was at 70 grams and the Tekin with wire was 44 grams if I remember correctly so that's 26 grams right there. My multi colored airbrushed body you see in the pic is quite a bit lighter than my all white spray canned special. A one color airbrushed body would prob save quite a bit of weight. The aluminum rear hubs with the bigger bearings weigh almost 20 grams more than the plastic which I have yet to break with some pretty good crashes. Some ideas......I think I could probably get it in the low 1480's or maybe even the 1470's if I really took the time to do it, but I don't have the time so I won't.
Old 01-16-2013, 02:22 PM   #4374
Yes I have replaced the pins on my 1/10 & 1/8th shafts. Got the pins from McMaster-Carr online ,50 for around 10 bucks,Very cheap. Just used a punch and hammer to remove and install with alittle CA, Never had one come out.
Lou Colmo/Tekno EB48.3, SL & SCT410.3/ Tekno R/C,Tekin / Reedy Batteries / Savox /AKA / Futaba 4PKs
Blaze R/C,St.Louis DirtBurners,SMAC Trac
X God is offline   Reply With Quote
Old 01-16-2013, 02:23 PM   #4375
Originally Posted by corky_rc View Post
Question - Do any of the pro Kyosho driver (Tebo, King), ever get on here to help answer questions from us mear mortals??
I know that pro's from other manufacturers like Durango, AE, Losi, cant do enough to help out.
Dont get me wrong, im Kyosho through & through, but to me some of the top Kyosho guys seem a little quiet.
I have seen a couple of the K drivers get on here but its not as much as we would all like.
Ive seen a few non paid drivers like Zack rogers (been awhile) Jayson Pang, Josh Mitchell on here. Its not that often though.
sdnspecial is offline   Reply With Quote
Old 01-16-2013, 02:51 PM   #4376
aloksatoor's Avatar
If you have the part number handy can you post it? I like the xray method of outdrive and pin. They make the pin really soft so the outdrive stays pristine and you can refresh your cars very cheaply. So I will try to find that size pin in a xray part. Mcmaster I believe sells different hardness as well.
ALso I like the pinion idea very much will try it on the busted shafts I got tonight .
Old 01-16-2013, 03:30 PM   #4377
Default questions?
So if you could ask a kyosho pro....what kind of questions would you ask? I'm in Portland and usually see kyosho's team manager at the track. I could ask a list of questions and see what he says.
What would be your guy's top 5 questions?
sir_thomas is offline   Reply With Quote
Old 01-16-2013, 03:50 PM   #4378
McMaster-Carr part # 91595A026 alloy steel dowel pin 2mmx10mm Breaking strength 700lbs $7.36 for a bag of 50
Old 01-16-2013, 03:55 PM   #4379
aloksatoor's Avatar
Thanks!!
Old 01-16-2013, 04:29 PM   #4380
Gayosaka's Avatar
KYO97018-098 is the part number, A-Main carries them.
Dimensions seem to be 2x9.8mm.
http://www.amainhobbies.com/product_...o-2x98mm-Pin-5
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22968 Today 04:05 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
hairymuffin
