    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 01-16-2013, 09:11 AM   #4351
t8rtot's Avatar
Trader Rating: 14 (94%+)
Originally Posted by Cpt.America View Post
Nah, forget teh 5 amrs. If your rear end really is THAT planted, and you are looking for more corner speed, the first thing I would do is switch to 2.5 degrees of rear toe instead of 3. Will be money!
Tried that, but I didn't like the traction it gave up. It felt like it wouldn't lock in when I exited. Since I run stock 17.5 there us a fine line that I'm balancing on. The car is so good right now but now I want more, maybe what I'm looking for isn't obtainable.. But I have to keep searching
Sfida
t8rtot is offline   Reply With Quote
Old 01-16-2013, 09:12 AM   #4352
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by t0p_sh0tta View Post
The K car needs nothing. The shocks are the cream of the crop, the turnbuckles are indestructible, the ball diff is one of the best in the business, and I have local parts support.
You know what you need to do You will smack yourself for not doing it sooner. And don't forget, you can always keep your AE gear/roller for a month or so just to make sure you actually prefer the 6. If not, you can always sell the 6 and go back.
but you wont
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 01-16-2013, 09:31 AM   #4353
Trader Rating: 38 (100%+)
From what I've read, the MR has the lower end shocks, and gear diff. I can live with the shocks, but having to mail order everything and "upgrade" to a ball diff is damn near a deal breaker. There aren't even enough people running it to get a good feel for what breaks/wears prematurely and what doesn't.
I couldn't agree more. Shocks are cream of the crop. I don't understand why people are changing things out so much. I would go completely crazy....
noworries is offline   Reply With Quote
Old 01-16-2013, 10:18 AM   #4354
aloksatoor's Avatar
Trader Rating: 42 (100%+)
tr8tot are you running with shorty all the way forward. My style is similar to yours and found that I like shorty best with it all the way forward (base I started with epers setup on petit). I started tuning my setup from that and all thats left now is a little corner push to tune out, which can be fixed with holeshot fronts I think .
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 01-16-2013, 10:22 AM   #4355
How do I figure out how to get the different rear toe combinations? In other words what blocks are needed to get 2.5/3/3.5 etc in rear toe on the 6?
Gitsum is offline   Reply With Quote
Old 01-16-2013, 10:44 AM   #4356
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
I believe the toe is fixed at 3 degree's. This means you can't change them at the block. If you need to change the toe then you need to purchase the hubs and install them as needed.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 01-16-2013, 10:48 AM   #4357
Super Moderator
Inboard toe is fixed at 3 degrees. You can only change outboard toe on this car, and it's done with the hubs. Because inboard is 3 degrees, you get:
0 degree hubs = 3
.5 degree hubs = 3.5
1 degree hubs = 4
.5 degree hubs backwards = 2.5
1 degree hubs backwards = 2
- RCSpecialties -
Old 01-16-2013, 11:19 AM   #4358
0 degree hubs = 3
1 degree hubs = 4
That would be good to add to your new first post!!
ChadBlanton is offline   Reply With Quote
Old 01-16-2013, 11:20 AM   #4359
anyone tried the MIP Super Diff for the RB6? I'm thinking about having a built up diff in the tool box ready to go ... for 40 bucks it seems like a good option
Old 01-16-2013, 11:29 AM   #4360
aloksatoor's Avatar
I think the stock kyosho outdrives wear out a lot faster. So the MIP might be a good option. Right now I have 1 spare diff fresh after that will get the MIP. Let us know your wear rate on the mips.
Old 01-16-2013, 11:39 AM   #4361
0 degree hubs = 3
1 degree hubs = 4
Ok so regardless if you use the wide or narrow hangers its still 3* fixed. Good to know thanks!
Old 01-16-2013, 11:39 AM   #4362
Super Moderator
I am keeping my eye on the MIP stuff (have been for a year). Currently, I see no reason to move to the MIP Diff, unless the outdrives wear considerably slower. What I am waiting for, are MIP's swing shafts, in hopes they wear a lot slower than the kyosho swing shafts (the pins where they wear on the outdrives). If there is a noticeable improvement in wear, I will change diffs and axle/swingshafts to MIPs. The stock Kyosho pieces just wear too quickly.
The one thing i am not sure about, is the fact that the MIP diff is imperial/standard, and not metric. What does that mean for the outdrive bearings? I assume that part of the diff is metric. Has anybody tried it yet?
- RCSpecialties -
Old 01-16-2013, 11:54 AM   #4363
corky_rc's Avatar
Question - Do any of the pro Kyosho driver (Tebo, King), ever get on here to help answer questions from us mear mortals??
I know that pro's from other manufacturers like Durango, AE, Losi, cant do enough to help out.
Dont get me wrong, im Kyosho through & through, but to me some of the top Kyosho guys seem a little quiet.
* Kyosho TKI3 - Alpha - Futaba - AT Racing - Beta Tyres.
* Kyosho TKI2e - Futaba - Tekin - Pro Amps Batteries - Beta Tyres.
* Kyosho RB6 - Futaba - Tekin.
* Bodies By Scott's RC Designz.
* Beta Tyres www.wprcracing.com * Pro Amps International.
corky_rc is offline   Reply With Quote
Old 01-16-2013, 12:30 PM   #4364
Super Moderator
They ARE quiet.. and it's been a topic of discussion more places than just RCtech. The only K Team driver I have seen hop on here and help out, is one of my buddies from T.R.C.R, team driver Ryan Matesa... He's not a pro (paid to drive), but even non-pro team drivers input can be pretty valuable... And Ryan is brutally fast. Iv only seen him come on a few times. Where you at, Ryan?
- RCSpecialties -
Old 01-16-2013, 01:36 PM   #4365
t0p_sh0tta's Avatar
Trader Rating: 35 (100%+)
The AE guys are fairly quiet as well. I know that they share the majority of their info on Facebook, but I believe that's Team Driver to Team Driver.
Has anybody successfully replaced the pins on the stock CVDs? I think I remember somebody saying that they were able to do it with the Hudy tool.
I've met some of the strangest people while playing with my toy cars...
t0p_sh0tta is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
