    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree16Likes
Old 01-14-2013, 11:34 PM   #4306
Originally Posted by MrHistory View Post
Be sure to use a shorter ball end on your rear shocks with the RB5 arms. I first had the long ones on and the spring adjuster was backed out all the way. I use the short ball end. Have not tried the medium.
Gitsum is offline   Reply With Quote
Old 01-15-2013, 12:54 AM   #4307
Lonestar's Avatar
Hey Guys
I lost the front metal arm brace saturday during the race... the setscrews that hold the front arm axles backed out the axles moved back and voila the brace flew off, never to be found again
as I was browsing amain for replacement and I typed "RB6 brace" or sthing in the "search" box, I came upon all these 4 parts.
http://www.amainhobbies.com/product_...Brace-Gunmetal
http://www.amainhobbies.com/product_...unmetal-RB5-WC
http://www.amainhobbies.com/product_...inge-Pin-Brace
http://www.amainhobbies.com/product_...n-Plate-Type-B
The instructions reference UM720... the last link - note it's the more expensive one.... Are the first 3 really a direct fit on the RB6? Why so many references? Are we being fooled?
Other than that, the car works really, really well. I finally got the diff sorted out after a good rebuild, but that bit is way more sensitive than my B4's....
Cheers
Paul
PS: Brandon, Schuey received???
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 01-15-2013, 01:13 AM   #4308
mdowney's Avatar
Trader Rating: 21 (100%+)
UM720 is the correct part. The other two are different widths and were made for the RB5 SP2 and RB5 SP2 WC kits. If you use the other braces you have to run a different suspension block and front arms.
Beware that this part bends easily. I'm not 100% sure but I think Kyosho may be revising the part soon to make it more sturdy.
Mike Downey
I try all of the RC kits and usually race at Tacoma RC Raceway
mdowney is offline   Reply With Quote
Old 01-15-2013, 01:21 AM   #4309
K_King's Avatar
Trader Rating: 39 (100%+)
Send a message via AIM to K_King
Yeah I think they are making it strong which is nice, it bends way too easy as thick as it is.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 01-15-2013, 01:22 AM   #4310
Just1More's Avatar
KYOUMW519GM is too wide for the RB6, KYOUM720 is the correct part number for that piece!
Mark Clark
RB6
B44.1
TC6.1
Just1More is offline   Reply With Quote
Old 01-15-2013, 01:22 AM   #4311
Lonestar's Avatar
Thank you both
My next run is end-feb (yup... I don't get much wheel time ) - any idea if the revised bit would be released before then?
thank you!
Paul
Edit- thanks to you three, Just1more posted right at the same time as me... not sure about the part now tho :P
Old 01-15-2013, 01:26 AM   #4312
mdowney's Avatar
Originally Posted by Turbo911 View Post
What are the part numbers for the shock ends. Short, medium and long.
S = W5015
M = 97038
L = LA43
Mike Downey
Old 01-15-2013, 01:29 AM   #4313
mdowney's Avatar
Originally Posted by Just1More View Post
KYOUMW519GM is the exact same, perfect fit. I bought one as a spare and have test fitted it on my RB6, so it's a guarantee.(I checked my Amain history to verify part number). Good luck
You might want to examine those very closely. My understanding is that they are just slightly different in size. You have to put them back to back and run a suspension rod through them to be sure.
Mike Downey
Old 01-15-2013, 01:37 AM   #4314
Just1More's Avatar
You're right, it's too long by a few mm's. KYOUM720 must be the right part number then. Thanks for letting me know, i'll edit my post(can you do the same?) to reflect the right number
Mark Clark
RB6
B44.1
TC6.1
Old 01-15-2013, 03:05 AM   #4315
Originally Posted by mdowney View Post
S = W5015
M = 97038
L = LA43
Thank you,
Turbo
Turbo911 is offline   Reply With Quote
Old 01-15-2013, 03:14 AM   #4316
Andy63's Avatar
Kyosho Rb6 1st and 2nd at Petit race in norway this weekend! Congrats Christoffer Svensson for 2nd and David Ronnefalk for 1st!
www.andrefossto.wordpress.com|HOBBYWING |YOKOMO |HBracing |MIBOSPORT.COM |Reservdelsrc.com |Jockeli-Painting |
Andy63 is offline   Reply With Quote
Old 01-15-2013, 08:02 AM   #4317
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
hah!! Hey Paul! Not yet, amigo! I missed a registered mail delivery yesterday and have to go to the post office today to pick it up, but i DO have a couple packages on the way... not sure if it's yours. Im really really excited though!
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 01-15-2013, 08:13 AM   #4318
Moderator
Posvar's Avatar
Trader Rating: 462 (100%+)
Brandon, thanks for all your work so far! Looks good.
Having fun with my 9 year old and running Kyosho cars!
Posvar is offline   Reply With Quote
Old 01-15-2013, 08:34 AM   #4319
Maybe this has already been posted, but i could not find it. What effect does running the castor block in the "in" or "out" position have.
Dale.0 is offline   Reply With Quote
Old 01-15-2013, 08:39 AM   #4320
Super Moderator
it either widens or shortens the front track width. Shorter track width for more steering, wider for less.
- RCSpecialties -
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22970 10-17-2017 05:10 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
