Kyosho Ultima RB6 & RB6.6 Car Thread >
Like Tree172Likes
    Hide Wikipost
R/C Tech ForumsThread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0°/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Old 01-14-2013, 06:22 AM
  #4246
Nitronut3's Avatar
Originally Posted by K_King
Anyone try the 521-1 arms vs stock extensively?
Thats all that i have ran since i built the kit. I have tried to run the 6 rear arms but they make the car feel too locked in. THe -1 arms let the rear end rotate a little more off power. Me and another kid in St.Louis have come to the conclusion that if the track gets slick out, run the 6arms, if not, run the -1
Nitronut3 is offline
Old 01-14-2013, 06:54 AM
  #4247
t8rtot's Avatar
Trader Rating: 14 (94%+)
Originally Posted by silvalis
I'd like to know further: For anyone who uses the exotek steering parts and have previously broken the steering plate, have they broken anything else yet? Like ripped the ballstud out of the steering hubs?
i have the Exotek rack, it tightened up the feel of the steering and i haven't broken anything else.
i wouldn't recommend going all aluminum in steering dept but if you want some added security, and dont have the updated plastic part, add the exotek rack.
t8rtot is offline
Old 01-14-2013, 06:56 AM
  #4248
t8rtot's Avatar
is this with the wide or narrow rear hangers and any additional toe on the hubs? also what kind of surface?
t8rtot is offline
Old 01-14-2013, 08:05 AM
  #4249
Every place i have looked is out of stock on Aluminum rear hubs. Are they in stock anywhere?
Dale.0 is offline
Old 01-14-2013, 08:11 AM
  #4250
Moderator
Posvar's Avatar
Trader Rating: 470 (100%+)
What degree are you looking for? Pm me....
Posvar is offline
Old 01-14-2013, 09:31 AM
  #4251
0 degree
Dale.0 is offline
Old 01-14-2013, 09:32 AM
  #4252
Cpt.America's Avatar
Trader Rating: 52 (100%+)
0 degree
FYI, I find the stock plastic 0 degree hubs to work just great.
Cpt.America is offline
Old 01-14-2013, 09:37 AM
  #4253
R/C Tech Elite Member
Trevor Williams's Avatar
Trader Rating: 207 (100%+)
guys that went from the rb5 sp2/wc to the rb6......what are your thoughts? I have a chance to get a rb6 but my rb5 is really dialed right now, soooo??
Trevor Williams is offline
Old 01-14-2013, 09:57 AM
  #4254
If the wallet allows, i wouldn't hesitate. I think the car is better in all regards. The BIGGEST difference to me, is how much better the car jumps and lands. Just night and day better than the rb5.
That being said.. the RB5 is still a fantastic car.
I still have my 5 (need to sell it). I planned on keeping the roller around until I was SURE the 6 was going to be better enough to keep it.... and for me, it certainly is.
Old 01-14-2013, 10:01 AM
  #4255
Doesnt the aluminum hubs have a second set of holes for the ball stud?
Dale.0 is offline
Old 01-14-2013, 10:07 AM
  #4256
yep, 4 instead of 2... nice, but certainly not necessary. Outer hole on the stock hubs will be just right anyway. The best benefit is actually the larger more durable outer bearing... but bearings are only a buck, and they don't really go out anyway. What im saying is, don't worry about it too much. Not in stock in a store right now? Well, go back in a month and look. no biggy.
Old 01-14-2013, 10:38 AM
  #4257
My 10 year old son drives his new RB6
http://www.youtube.com/watch?v=HLtyXz-aUbw
TopAs is offline
Old 01-14-2013, 11:12 AM
  #4258
t8rtot's Avatar
the kid can wheel. must be proud. the 6 looks good as well.
t8rtot is offline
Old 01-14-2013, 11:56 AM
  #4259
x100000
Old 01-14-2013, 12:33 PM
  #4260
Nitronut3's Avatar
Wide hangars with .5 hubs.
The choice of tire here is a Green barcode V1 and green barcode fronts shaved t o a little under half pin.
