    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree18Likes
Old 01-13-2013, 05:33 PM   #4216
gelshocker's Avatar
Originally Posted by Cpt.America View Post
Already up and going...
Just wish to say thank you Captain for taking up the mantle, and also the powers at RCTech for truely thinking out of the box. Most 'first posts' become outdated and incorrect anyway, and I'll say half are simply for bragging rights! Thanks to the moderators for taking up the added responsibility of reviewing the opening post.
Now the respective b4 and 22 threads should follow suit. Look what we've created!
Cheers, skipper!
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 01-13-2013, 05:36 PM   #4217
Trader Rating: 72 (100%+)
I want to thank you as well for taking the time to do that. The 1st page is looking really good so far and I will definitely reference it when I need to do setup changes.
b121774 is offline   Reply With Quote
Old 01-13-2013, 05:42 PM   #4218
Moderator
Posvar's Avatar
Trader Rating: 462 (100%+)
So pumped it worked out! Congrats Brandon on the new gig!!!
Having fun with my 9 year old and running Kyosho cars!
Posvar is offline   Reply With Quote
Old 01-13-2013, 05:54 PM   #4219
mdowney's Avatar
Trader Rating: 21 (100%+)
Brandon -
Here are a few things to note on the first post:
- The rear upper bulkhead and steering rack have already been strengthened in a running change. I have both parts and they are more sturdy than the original run. I'll show you next time I see you at the track.
- You can run the ball stud fairly safely in the outside hole if you put grub screws in the two other holes AND use UMW508B, high-mount ball stud with a nut underneath. I've been running this config for a couple of weeks with no more failures.
- Kyosho is working on some new Alu parts. No details yet.
- Many racers prefer to run the Kyosho clear, grooved x-rings ORG03X in their shocks. Some use clear (softer, smoother but needs replacing more often) on the inside and an orange x-ring on the outside.
Another common question is gearing. Adding some notes on common gearing configurations to start with would be helpful. For example, with an Epic D3.5 17.5 I'm running 69T (Avid Triad) / 32T.
Mike Downey
I try all of the RC kits and usually race at Tacoma RC Raceway
mdowney is offline   Reply With Quote
Old 01-13-2013, 05:56 PM   #4220
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
You're welcome guys... there is already a ton of info up.. please send me a PM with suggestions, no need to clog the thread THanks mike, I will keep working.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 01-13-2013, 06:19 PM   #4221
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Originally Posted by mdowney View Post
Brandon -
Mike, can you post photos to show us what to look for on these revised parts? Thanks!
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 01-13-2013, 06:35 PM   #4222
BranVita's Avatar
Trader Rating: 39 (100%+)
+1
Branden V.
Kyosho Rb6 | Orion R10 Pro | SchuurSpeed 17.5 | Savox 1257
Kyosho SC-R SP | Orion R10 Pro | SchuurSpeed 17.5 | Savox 1258
BranVita is offline   Reply With Quote
Old 01-13-2013, 07:24 PM   #4223
umm winning's Avatar
He's not the seller.. he was just showing you the link. The chassis doesn't appear to be dented. (but don't pay 400 for a used one. My track just sold two NIB ones for $420 each)
Haha thanks for clearing that up. First page is looking good...
umm winning is offline   Reply With Quote
Old 01-13-2013, 07:28 PM   #4224
Just a FYI the stock plates will not work with AE spurs they are too large in diameter.
Gitsum is offline   Reply With Quote
Old 01-13-2013, 07:29 PM   #4225
Super Moderator
What plates?
- RCSpecialties -
Old 01-13-2013, 07:35 PM   #4226
Stock rb6 slipper plates are to large they will ride on the ridges that hold the AE pads on the AE spurs. Losi spurs and pads will work with stock Rb6 slipper plates.
Old 01-13-2013, 07:36 PM   #4227
Trader Rating: 18 (100%+)
Slipper plates. Run the AE slipper.
Ctimrun is offline   Reply With Quote
Old 01-13-2013, 07:37 PM   #4228
Super Moderator
All I run are spurs designed for the AE cars on my kyosho (have for a couple years) and have never had a problem. I do run the Kimbroughs though, not the AE branded spurs as I find them to be very out of round, and very noisy.
- RCSpecialties -
Old 01-13-2013, 07:40 PM   #4229
teeforb's Avatar
Trader Rating: 94 (100%+)
Send a message via Yahoo to teeforb
Can you post a link on both the pad and spur?
$$ Team High Budget $$
17.5 stock buggy fb page
https://www.facebook.com/groups/17.5stockbuggy/
teeforb is offline   Reply With Quote
Old 01-13-2013, 07:58 PM   #4230
I didn't try a kimbrough I tried using the AE vented plates since I have a pair and the top shaft was too large in diameter.
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22972 Yesterday 04:13 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
