    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree25Likes
Old 01-13-2013, 02:23 AM   #4186
teeforb's Avatar
Trader Rating: 94 (100%+)
Send a message via Yahoo to teeforb
Originally Posted by Just1More View Post
I run my old B4 wheels for now, but Kyosho wheels are better quality. Fronts measure out the same, rear B4 Jconcepts wheels give you a 1mm narrower track width each side, so the car will be 2mm narrower in the rear only with JC B4 hex wheels. I plan on buying Kyosho wheels and sticking with those for the rigidity/quality and correct offset.
This is what I'm looking for. Thx
$$ Team High Budget $$
17.5 stock buggy fb page
https://www.facebook.com/groups/17.5stockbuggy/
teeforb is offline   Reply With Quote
Old 01-13-2013, 06:07 AM   #4187
Trader Rating: 38 (100%+)
Ball Diff vs Gear Diff: I would really appreciate all input. I run gear diff in my TC. For my RB6, any thoughts on going to gear? - am I correct that SCT gear diff will fit? thank you
noworries is offline   Reply With Quote
Old 01-13-2013, 08:34 AM   #4188
fastestwon's Avatar
Trader Rating: 15 (94%+)
you race on carpet correct ? when i used to race on carpet i always ran a ball diff as a matter of fact ball diff is usually the better choice . i will be running my car on a carpet track this coming Saturday . the only thing i will be changing is the shock oil 50 front and 40 rear i have a worn set of mc suburbs i will use .
yes the gear diff will fit if you want to use it .
fastestwon is offline   Reply With Quote
Old 01-13-2013, 08:36 AM   #4189
Trader Rating: 29 (100%+)
[QUOTE=Cpt.America;11669425]Nope.. different wheels. Stock Kyosho wheels are money.
If you use the hexes on the B4.1 you can use the same wheels. Or am I missing something?
Yzlvr is offline   Reply With Quote
Old 01-13-2013, 08:53 AM   #4190
fastestwon's Avatar
Default race video
still waiting to see some other RB6 cars in action ? where is all the youtube videos guys .
Old 01-13-2013, 09:18 AM   #4191
teeforb's Avatar
What parts are necessary upgrades?
Old 01-13-2013, 09:22 AM   #4192
Trader Rating: 74 (100%+)
Aluminum rear hubs and steering rack imo as they are the only things I have broken.
b121774 is offline   Reply With Quote
Old 01-13-2013, 09:27 AM   #4193
t8rtot's Avatar
Trader Rating: 14 (94%+)
Steering rack just in case, I wouldn't worry about hubs unless you have horrific crashing abilities or are racing in cold cold weather the rack is the only part I've broken that think needs the upgrade.
Go to Speedtech and look at the exotek parts.
Sfida
t8rtot is offline   Reply With Quote
Old 01-13-2013, 09:28 AM   #4194
teeforb's Avatar
Which spur does the kyosho uses? If it's own, what's the smaller size?
Old 01-13-2013, 09:29 AM   #4195
teeforb's Avatar
Anything else from exotex that requires upgrade? How are the stock shock towers?
Old 01-13-2013, 09:38 AM   #4196
teeforb's Avatar
Do all you guys chassis have imprints at the bottom rear? If so, what's the deal?
Old 01-13-2013, 09:43 AM   #4197
t8rtot's Avatar
I have the aluminum diff nut, steering rack and rear mount.. I have put on the rear mount yet however.
Stock spur is a 76.
The towers are fine and very few dented chassis have been reported.. If so, word is Kyo will replace it.
Sfida
Old 01-13-2013, 10:00 AM   #4198
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
If you are going to stick with the stock slipper setup, run Kimbrough B4 spur gears, and run the tan colored AE high torque pads.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 01-13-2013, 10:06 AM   #4199
teeforb's Avatar
Also, I am wanting to buy an almost new rb6. Pm me if someone has something.
Old 01-13-2013, 10:21 AM   #4200
umm winning's Avatar
@teeforb. Kyosho RB6
umm winning is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22984 Today 10:14 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15026 11-02-2017 04:19 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 09:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 05:30 PM
