    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 01-11-2013, 02:38 AM   #4141
Originally Posted by Cpt.America View Post
If I were running a mid motor car on a VERY high traction track, like turf or carpet, I would have my car down as light as I could get it, with a shorty. Id be running right at 1499. Weight generates traction, and slows reaction. On carpet, where you tend to dial out traction with roll center changes, ride height, and tires.... you don't need the weight of the heavier pack. Run a heavy pack on loose outdoor dirt tracks to generate more grip, run a light battery on carpet to reduce grip.
You want to slow the reaction on high grip!
Problem with running low weight is keeping the nose down. So you'd mount the shorty up front, then you end up generating too much front end!
Saddles with no weight added seems to be the best setup for me so far. Have added up to 70g under the lipo, but took it out, as the car felt a little sluggish. With a shorty I found the car to be too light and unstable.
Xray XB4 | Kyosho RB6 | Kyosho Rudebits DB2
Chris-s is offline   Reply With Quote
Old 01-11-2013, 08:40 AM   #4142
Registered User
First Kyosho Hop up came out.
UMW701 - Aluminium Steering Plate.
No Pics yet.
oosh123 is offline   Reply With Quote
Old 01-11-2013, 09:19 AM   #4143
What is the differance between the narrow and wide rear arm holder?
Dale.0 is offline   Reply With Quote
Old 01-11-2013, 09:25 AM   #4144
offroad dude's Avatar
Trader Rating: 25 (100%+)
From my understanding the wide holders free up the car a little meaning less rear traction.
offroad dude is offline   Reply With Quote
Old 01-11-2013, 09:27 AM   #4145
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Track width, and roll center. Search this thread for more info, it's been discussed quite a bit. Hopefully we can take over post#1 on the thread so we can put all basic info in one place to have an easy place to guide repeat questions to.
In short, a wider track raises roll center, hindering roll, and therefor hinders traction gain on that end of the car. Narrower track has opposite affect.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 01-11-2013, 10:01 AM   #4146
TT_Vert's Avatar
Trader Rating: 68 (100%+)
Guys, a while back I had provided some stats of springs I've done. I got an RB5WC that comes w/ "kit" xgear springs in pink front and red rear. I tested them as there was confusion if the rates were the same. What I found was the pink kit fronts (3.053 lb/in) were signifgantly softer than my non kit xgear pink fronts (3.272 lb/in). Now for the red rears I do not have a non kit xgear to test but I do have a yellow xgear. See the attached document.
TT_Vert is offline   Reply With Quote
Old 01-11-2013, 10:07 AM   #4147
Super Moderator
FYI the springs that came on the RB5 WC weren't xgear springs, nor did they have colors.
- RCSpecialties -
Old 01-11-2013, 10:12 AM   #4148
TT_Vert's Avatar
Ok, I'm unsure what they are then. They have the same coating/coloring as my xgear. Did the RB6 come w/ the xgear then?
Dave
Old 01-11-2013, 10:19 AM   #4149
Super Moderator
Dave
yep...
their coating was similar, and unless my memory has started failing (which is likely!), there weren't colors on them. Do I have that wrong? anybody confirm?
- RCSpecialties -
Old 01-11-2013, 10:30 AM   #4150
Trader Rating: 101 (99%+)
RB5 SP2 WC: The kit FR springs had blue markings on them (mine and a few others I saw locally at least), no markings at all on Rr springs. I did feel that the WC's (blue) fronts, felt stiffer than the X-Gear pink springs I had previously. I use them as an option in between the X-Gear Pink & White fronts...
RB6: X-Gear Springs included in kit, Pink FR, Red RR (both have paint dabs on them)
~ Richard Watchorn ~
* Team Associated/Reedy Electronics * OCRC Raceway *
* Schelle Racing * CBuilt Designs * Complex Ink *
desertracerdad is offline   Reply With Quote
Old 01-11-2013, 10:32 AM   #4151
TT_Vert's Avatar
Well then I have no idea what I have. They came off a used RB5SPWC I got, They look like xgear springs and have pink/red marking on them.
Dave
Old 01-11-2013, 10:42 AM   #4152
Super Moderator
Dave
Those sound like run-of-the-mill Xgear springs. A lot of us WC drivers tossed the kit springs and bought new xgears for the car.
- RCSpecialties -
Old 01-11-2013, 10:49 AM   #4153
Moderator
Posvar's Avatar
Trader Rating: 461 (100%+)
Brandon,
Your request has been sent....waiting on reply.
Matt
Having fun with my 9 year old and running Kyosho cars!
Posvar is offline   Reply With Quote
Old 01-11-2013, 10:51 AM   #4154
Moderator
Posvar's Avatar
Thanks!!!!!!!
Old 01-11-2013, 10:56 AM   #4155
Super Moderator
Originally Posted by Posvar View Post
Brandon,
Matt
Thanks Matt... i think it will be helpful.
Totally random question but I want to make my avitar a kyosho logo and can't seem to figure it out. Lol.
Any thoughts from you avitar K specialists?
Matt
Ill make you one, PM me.
- RCSpecialties -
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
