    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree25Likes
Old 01-10-2013, 04:52 PM   #4126
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by Energyzer View Post
Just need to know if these GenAce saddles fit in with the setup i mentioned. Hope i was clear enough so you can understand!
Thanks everyone
I think you are going to have a hard time finding guys running saddle packs, as they are the heaviest type of battery pack, and the car is already over-weight. Unless you find a guy running the car on a very very loose track, most will be running lighter short packs, and maybe some stick packs.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 01-10-2013, 05:17 PM   #4127
savageboy69's Avatar
Trader Rating: 88 (100%+)
you sure saddles are the heaviest pack? my sadlles are 260g, stick pack is 310g and shorty is 190g, i run outdoors so for me i thought saddles would be a good compromise, first big race of the year is feb 8th, ill report what i find
Xray|Rc America|Hudy|FX engines|Tekin|SOR graphics|LFR|Ogio|SRT servos|
XB8 2016
XB8-E 2016
XB4 2017
savageboy69 is offline   Reply With Quote
Old 01-10-2013, 05:56 PM   #4128
Energyzer's Avatar
Hey Captain
We usually run on high traction carpets, with small jumps. The tracks are veeeeery smooth. Do you think i would be better off with a shorty than saddles?
I only tried full size lipos so far, and been doing my setups with that...
Kyosho Inferno MP9 TKi3 | Novarossi BTTA
Kyosho Ultima RB6 | Nosram electrics
Energyzer is offline   Reply With Quote
Old 01-10-2013, 06:02 PM   #4129
asc6000's Avatar
Trader Rating: 15 (100%+)
the only real reason to run saddles is that you simply already have them
"you reach the limit, you touch the limit, then you pass the limit, now there is a new limit"
Ayrton Senna
asc6000 is offline   Reply With Quote
Old 01-10-2013, 06:05 PM   #4130
no thats not the only reason to run them, the fact that they are lighter than a full pack but heavier than a shorty makes them a nice tuning option and a good in between choice , especially if you run outdoors
XB8 2016
XB8-E 2016
XB4 2017
Old 01-10-2013, 06:38 PM   #4131
Z00M's Avatar
I run saddles in rear motor configuration. I prefer it to the full size stick pack. I don't own any shorties so can't comment.
My blog: http://mikesrc.wordpress.com
XRAY XB4
## NOSRAM ## XRAY ## KO ##
www.nbhc.com.au - www.teamxray.com
Z00M is offline   Reply With Quote
Old 01-10-2013, 08:49 PM   #4132
Originally Posted by pekow91 View Post
I just weighed my car for the first time last night and I am coming in at 1620g. I noticed that some of you guys mentioned your kits were around 1550g. I am a noob and I am not sure if 70 grams will make that much of a difference. I have made no attempts to put this thing on a diet. Do you guys have any easy fixes to reduce weight? I know this topic has been discussed before but I haven't found any posts for solutions. Here is my setup: Fantom shorty 4500mah, Orion Pro Esc (full length wires), Phantom 3.5 17.5T , savox 1258, airtronics receiver, mylaps, aluminum hubs, aluminum pinion gear.
I pulled about 30grams of wet clay off my car after running my heat last night. Just another thought for weight loss! 😯 This is offroad, just sayin...
flybyublue is offline   Reply With Quote
Old 01-10-2013, 09:26 PM   #4133
How does this thread still not have an informational first post? I've got probably over 20pages bookmarked from this thread alone.
HalfManHalfGod is offline   Reply With Quote
Old 01-10-2013, 09:45 PM   #4134
Super Moderator
Were working on it.
- RCSpecialties -
Old 01-10-2013, 09:45 PM   #4135
Super Moderator
It's what iv been told... but I could be wrong! Are you weighing same brand, and same mah?
- RCSpecialties -
Old 01-10-2013, 09:59 PM   #4136
i guess i should rephrase that, i run murfdogg lipos, and for what he offers the saddles are in the middle as far as weight, the stick is 5500 mah, saddle pack is 4600mah and i think the shorty was around 5000mah, an easy way to cut weight is run a lower mah battery, honestly a 4000 mah will prolly get you a 6 min main with plenty of room to spare, after 6 minutes with my 4600 im still around 7.9v so its not using much
XB8 2016
XB8-E 2016
XB4 2017
Old 01-10-2013, 10:11 PM   #4137
Super Moderator
Yep.. there ya go. If you compared mah to mah, i bet your saddles would be heavier. Its because the saddles have more wire, more plugs, and more case. Probably not much, but 10 or 15 grams anyway. Iv never measured direct mah to mah from the same manufacturer, but that is where I would put my money.
- RCSpecialties -
Old 01-10-2013, 10:13 PM   #4138
Super Moderator
Hey Captain
If I were running a mid motor car on a VERY high traction track, like turf or carpet, I would have my car down as light as I could get it, with a shorty. Id be running right at 1499. Weight generates traction, and slows reaction. On carpet, where you tend to dial out traction with roll center changes, ride height, and tires.... you don't need the weight of the heavier pack. Run a heavy pack on loose outdoor dirt tracks to generate more grip, run a light battery on carpet to reduce grip.
- RCSpecialties -
Old 01-11-2013, 02:27 AM   #4139
Just1More's Avatar
Quick pic of the night I finished it. Has a RB5 type battery hold down now, and yes those are lunsford TI shock mounts made for the SC10/B4, they fit great if you don't mind the nuts being a standard size
Mark Clark
RB6
B44.1
TC6.1
Just1More is offline   Reply With Quote
Old 01-11-2013, 03:09 AM   #4140
t8rtot's Avatar
Trader Rating: 14 (94%+)
That is what you'd think however most carpet setups, in the uk for example they run quite a bit of additional weight.
Sfida
t8rtot is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22984 Yesterday 10:14 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15026 11-02-2017 04:19 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 09:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 05:30 PM
