    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree25Likes
Old 01-10-2013, 08:53 AM   #4096
Trader Rating: 38 (100%+)
Originally Posted by t8rtot View Post
the entire car just shines of excellence, i told you they were the best.
i would recommend putting just a dab (and i mean just a dab) on the little black cap on the bottoms, i had 2 loosen and come off.
well good luck with the rest of build and we're here to answer any more questions!
Dab of blue loctite?
noworries is offline   Reply With Quote
Old 01-10-2013, 09:33 AM   #4097
Trader Rating: 91 (100%+)
Never use loctite on plastic, it will degrade it.
Just leave him alone, he knows what he's doing!
Eric Tomczyk is offline   Reply With Quote
Old 01-10-2013, 09:44 AM   #4098
Trader Rating: 74 (100%+)
The black cap and the piece it screws onto are aluminum
b121774 is offline   Reply With Quote
Old 01-10-2013, 10:07 AM   #4099
Kooz's Avatar
Believe he is referring to the lower shock cap....
Just ordered a set of GHEA (4) 1.3 pistons. Find it hard to believe the car can get any better for me with these, but figured why not!
LOL
Kooz is offline   Reply With Quote
Old 01-10-2013, 10:29 AM   #4100
t8rtot's Avatar
Trader Rating: 14 (94%+)
yes they're both aluminum.. http://www.speedtechhobbies.com/inde...roduct_id=1841
Sfida
t8rtot is offline   Reply With Quote
Old 01-10-2013, 11:03 AM   #4101
Sorry I thought you meant the shaft/end.
Old 01-10-2013, 11:13 AM   #4102
pekow91's Avatar
Trader Rating: 45 (100%+)
I just weighed my car for the first time last night and I am coming in at 1620g. I noticed that some of you guys mentioned your kits were around 1550g. I am a noob and I am not sure if 70 grams will make that much of a difference. I have made no attempts to put this thing on a diet. Do you guys have any easy fixes to reduce weight? I know this topic has been discussed before but I haven't found any posts for solutions. Here is my setup: Fantom shorty 4500mah, Orion Pro Esc (full length wires), Phantom 3.5 17.5T , savox 1258, airtronics receiver, mylaps, aluminum hubs, aluminum pinion gear.
Kyosho RB6 | Kyosho MP9 TKI3E | Xray XB4
pekow91 is offline   Reply With Quote
Old 01-10-2013, 11:29 AM   #4103
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
that's a heavy speedo, espeically with full length wires. A low pro servo will save about 10-12 grams.
When I moved from a full sized lipo to a shorty, and saved 100 grams, the performance difference on my high traction track was HUGE for 17.5... Felt like I went from a 21.5 to 13.5. 100 grams was dramatic, 70 grams will also feel significant.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 01-10-2013, 11:29 AM   #4104
aloksatoor's Avatar
Trader Rating: 42 (100%+)
you can reduce a lot of weight with a lighter motor (speed passion is the lightest I have), tires with thinner carcass like the tendroids from sweep with open cells, shorter wires titanium buckles, a light esc like tekin, or the juststock from hobbywing, plastic everything as far as possible. I don't really bother much since not that good a driver to exploit it so go with what I have.
Mine is at 1600 or so, hobbywing 120A, savox 1257, orion 6.5, IP shorty 4600, sanwa receiver, amb, titanium buckles, front m4 suburbs with aka red, rear ss impacts red aka inserts.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 01-10-2013, 11:52 AM   #4105
t8rtot's Avatar
that 4500mah batt may have something to do with it.. my shorties are 3800 and 4000
some guys have the LPF servos
Sfida
Old 01-10-2013, 11:57 AM   #4106
pekow91's Avatar
Thanks guys. The shorty ways the same as my 4000. Any recommendation on a LPF servo?
Old 01-10-2013, 12:02 PM   #4107
t8rtot's Avatar
don't own it but its numbers are ridiculous, and heard good things..
http://www.amainhobbies.com/product_...o-High-Voltage
if your not looking to drop another $120 for more power than you need, this will fit the bill perfectly..
http://www.amainhobbies.com/product_...tal-Gear-Servo
Sfida
Old 01-10-2013, 12:06 PM   #4108
aloksatoor's Avatar
go for the radiopost. I have the savox lo pro and its not a good idea without a servo saver. Stripped it on a light tap. I just go with the titanium geared ones now.
Old 01-10-2013, 12:06 PM   #4109
pekow91's Avatar
That first one weighs more than regular size one. Thanks for the help
Old 01-10-2013, 12:33 PM   #4110
fastestwon's Avatar
Trader Rating: 15 (94%+)
Default new proline bulldog
thought i would try one . just a rattle can job
Kyosho Ultima RB6 & RB6.6 Car Thread-imag0837.jpg   Kyosho Ultima RB6 & RB6.6 Car Thread-imag0836.jpg
fastestwon is offline   Reply With Quote
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15027 Yesterday 09:29 AM
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22984 11-21-2017 10:14 AM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 09:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 05:30 PM
