    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree25Likes
Old 01-08-2013, 05:39 PM   #4081
t8rtot's Avatar
Trader Rating: 14 (94%+)
I actually prefer developing the car myself, it stops us from being like the 1/8th associated guys adapting odd parts and modding an already prefect car
Sfida
t8rtot is offline   Reply With Quote
Old 01-08-2013, 05:51 PM   #4082
Modding will happen regardless its how new designs come about. I'm not saying to hop on here and give us the latest setup either but a few pointers here and there wouldn't hurt. I personally work alot so sometimes I don't get to race for like a month. When I do get the chance to toss the car down I have to deal with the mod guys. I refuse to run 17.5 and trying to jump on pace with the mod crew to try and not become traffic is rough. So a few pointers on what's the latest what has and has not worked from those that are paid to race I'm sure would be welcomed. I only bring this up because it seems this is the only brand that their drivers don't offer much input on the vehicles. Just my .02...if its too much kindly give it back as I am not rich
Gitsum is offline   Reply With Quote
Old 01-09-2013, 01:59 PM   #4083
Can someone explain with the different caster blocks will change on the car? I understand the different between the narrow and wide track, but I am unsure of the difference the 0, 2, & 4 and what each would do to car.
Bluehills315 is offline   Reply With Quote
Old 01-09-2013, 02:02 PM   #4084
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
0 adds nothing to caster on top of the kickup
2 adds +2 caster to the kickup
4 adds +4 caster to the kickup
So if you are running 25 caster on the kickup, 0 inserts give you 25 caster. 2s give you 27, etc.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 01-09-2013, 02:06 PM   #4085
K_King's Avatar
Trader Rating: 39 (100%+)
Send a message via AIM to K_King
More caster smooths the steering down. Less aggressive.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 01-09-2013, 02:17 PM   #4086
Thanks. Now a question to add to that. What will more caster do versus less? What effect does the kick up have versus the caster?
Assuming I understand correctly, it is possible to run 25 caster, 27, 29, 30, 32, &. 34? Or am I mistaken here?
Old 01-09-2013, 02:49 PM   #4087
Super Moderator
Actually, the inserts can be run backwards for even more combonations. You can actually have +2 or -2 from either the 25 kickup, or the 30... so lots of steps between 21 and 34.
Caster- Its all about tire contact patch and smooth driving. Caster provides two things a) camber change as the tire turns, and b) car will tend to track straighter as you drive
So if the car isn't leaning at ALL (very very slow speed turns), you get the most steering out of 0 caster. But if the car leans while you are turning, you end up with positive camber, which decreases tire patch. So to keep tire patch, caster induces camber as you turn the wheel. If you run too MUCH caster, you get too much camber introduced as you turn. So for example, 30 degrees of caster intruduces a lot camber as you turn. So if the car isn't leaning, you actually end up with less contact patch. But in the high speed sections of the track where the car is leaned all the way over, you end up with more contact patch.
So in general, you have the following
less caster (25) gives you more steering when driving slow (infield), and less steering in the high speed sections when the car is rolled over
more caster (30) gives you less steering when driving slow (infield) and more steering in the high speed sections when the car is rolled over
Kickup- Kickup is the term used for the angle the front suspension arms sit in relation to the flat chassis. If you understand "squat" or "anti-squat" at the rear of the car, this is the same thing, but at the opposite end of the car. As the car dives, the angle of the chassis is no longer parallel to the ground (it pitches, as it dives). So if you ran 0 kick up (arms flat), and the car pitched forward, there would be natural resistance in the angle of the arms. Weight would be transferred into the horizontally into the hinge pins, instead of up into the shocks, which means less weight transfer to the front. So more kickup means more weight transfer to the front of the car, off-throttle or braking. (a bit hard to explain, I need my hands)
- RCSpecialties -
Old 01-09-2013, 03:30 PM   #4088
asc6000's Avatar
Trader Rating: 15 (100%+)
The Capt explained your direct question. Based on your curiosity I thought you might like this thread too Tune With Camber Links
"you reach the limit, you touch the limit, then you pass the limit, now there is a new limit"
Ayrton Senna
asc6000 is offline   Reply With Quote
Old 01-09-2013, 04:17 PM   #4089
Phil Trotta's Avatar
I'm running rb6 in modified. I'm about to install a 1 mm limiter in rear shock can someone give me an overall shock lengthy or shock shaft length as a starting reference Also are u guys really playing with lengths for off power weight transfer?
Pillars has no rules........
PHIL TROTTA
Phil Trotta is offline   Reply With Quote
Old 01-09-2013, 08:14 PM   #4090
Super Moderator
Originally Posted by JACK HAMMER View Post
Also are u guys really playing with lengths for off power weight transfer?..
uhm.. I do. I fine tune droop all the time. I use it to tune weight transfer, as well as how the car rolls in the corners.
- RCSpecialties -
Old 01-10-2013, 07:29 AM   #4091
Trader Rating: 38 (100%+)
HELP? Panther slicks on Carpet. any feedback guys? running mid motor.
noworries is offline   Reply With Quote
Old 01-10-2013, 08:00 AM   #4092
t8rtot's Avatar
slicks? is that the best tire for the track? may be but i know alot of guys like the schumacher mini pins etc.. http://www.amainhobbies.com/product_...Tires-Yellow-2
secondly, i'd go straight to petit rc and look through the carpet setups, they should have a base setup to get you started and tweak from there.
lets see the car if you have it built up! good luck
Sfida
Old 01-10-2013, 08:05 AM   #4093
Thank you. Not done building yet. OMG love the shocks. Can't keep my hands off em.
Old 01-10-2013, 08:09 AM   #4094
Trader Rating: 18 (100%+)
If anybody is looking to own an RB6 a friend of mine is selling his here
Basically just ran for one race, the Novak race in Omaha last weekend.
Kyle Simmonds | RB6 | FS2SP | TKI3
KSimmonds is offline   Reply With Quote
Old 01-10-2013, 08:11 AM   #4095
t8rtot's Avatar
the entire car just shines of excellence, i told you they were the best.
i would recommend putting just a dab (and i mean just a dab) on the little black cap on the bottoms, i had 2 loosen and come off.
well good luck with the rest of build and we're here to answer any more questions!
Sfida
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22984 Yesterday 10:14 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15026 11-02-2017 04:19 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 09:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 05:30 PM
