    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0°/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree25Likes
Old 01-06-2013, 09:25 PM   #4006
Well I have been running the car for a few weeks now and all I can say I wow! Didnt care much for the stock springs so I went to white front and gold rears and it's money.
Gitsum is offline   Reply With Quote
Old 01-06-2013, 09:32 PM   #4007
Suspended
How much money?
Pimp Formally Known as OG
PFKAOG is offline   Reply With Quote
Old 01-06-2013, 09:36 PM   #4008
Originally Posted by PFKAOG View Post
How much money?
Foo-fity way you of your budget!
Old 01-06-2013, 09:39 PM   #4009
Suspended
That's the homo price. I got the hook ups
Old 01-06-2013, 09:42 PM   #4010
Touché....
Old 01-06-2013, 09:49 PM   #4011
Trader Rating: 74 (100%+)
The standard bore velvets are pretty dam good to. I ran an scr with standard bores and when I switched to Bb's, didn't notice any difference. The new schumacher k1 has standard bores???? Here's
A pic of mine with the standards, only saved me 10 grams. My first weigh was with a reedy 60c shorty but the orion 90c is 10 grams heavier which I put infor the weigh after the shock change, totally cancelled it out. Bummer. Done with weight reduction till after I run it. Will report my b4/rb6 comparison after this weekend.
http://s963.beta.photobucket.com/use...02344.jpg.html
b121774 is offline   Reply With Quote
Old 01-06-2013, 11:41 PM   #4012
Jerad8's Avatar
Trader Rating: 104 (100%+)
So what shock seals are the best? I know there's several to choose from:
P3 Grooved Low Friction (orange)- KYOORG03XR
P3 Grooved O-Ring (clear)- KYOORG03X
Stock o-rings- KYOW5184-05
Jerad8 is offline   Reply With Quote
Old 01-06-2013, 11:56 PM   #4013
alana07's Avatar
Trader Rating: 52 (100%+)
Send a message via MSN to alana07
Originally Posted by b121774 View Post
Any tips for shaving weight for stock? I am 50 grams over and have done everything I could think of: titanium screws and ball studs, back to the plastic rear hubs, slipper eliminator, lightened pinion, delrin pivot balls.
I have a set of small bore velvets, thinking thats my next step.
shaving 50 grams off for stock racing? not to meant sarcastic here, but a single crash in a corner will throw whatever weight savings you had out the window.
没有最好,只有更好!!!
alana07 is offline   Reply With Quote
Old 01-07-2013, 12:37 AM   #4014
K_King's Avatar
Trader Rating: 39 (100%+)
Send a message via AIM to K_King
Clear is the smoothest, and they actually last a long time.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 01-07-2013, 04:30 AM   #4015
carcrusher46's Avatar
Trader Rating: 17 (100%+)
Either of the "grooved" x-rings work very well. Instead of having one contact point per o-ring like with a standard seal (in the middle), each o-ring has 2 contact points (top and bottom) so there is a much more consistent response overall and since the contact points themselves are smaller, the shocks stay super smooth and free.
Matt Stoltz
Thank you to my sponsors:
Team Associated - Reedy - JConcepts - Life Fast RC Paintworks
carcrusher46 is offline   Reply With Quote
Old 01-07-2013, 07:08 AM   #4016
Nitronut3's Avatar
Send a message via AIM to Nitronut3
Do we know if anyone makes a Ti screw kit yet for the 6? Gonna start trimming some weight out of my rb6 and zx5
Nate Jaskot
XRAY, RC America, KO Propo, Hudy, FX Engines, Nitropro, Rc addiction products , TeamSR, SmacTrac
Nitronut3 is offline   Reply With Quote
Old 01-07-2013, 07:23 AM   #4017
BranVita's Avatar
http://www.speedtechhobbies.com/inde...roduct_id=2825
Branden V.
Kyosho Rb6 | Orion R10 Pro | SchuurSpeed 17.5 | Savox 1257
Kyosho SC-R SP | Orion R10 Pro | SchuurSpeed 17.5 | Savox 1258
BranVita is offline   Reply With Quote
Old 01-07-2013, 07:38 AM   #4018
t8rtot's Avatar
Trader Rating: 14 (94%+)
so hold on.. you've been doing all of this weight reduction researching and you havent even run the car???
there is a table top at my local track's layout that (in stock) you can just barely make if you take the right line..
my car is definitely heavier than the b4's and Team Cs with all their goodies and i can make it and see myself making it more than other cars. it may just be that i'm the only one trying to pick up the .3-.5/sec that i gain from it but it can be done.. even if afterwords they came to make sure my car was still in blinky mode..
in short, run the car, be amazed and sell the Associated.
Sfida
t8rtot is offline   Reply With Quote
Old 01-07-2013, 07:54 AM   #4019
Trader Rating: 38 (100%+)
Default Stiffer Springs for Carpet?
Hi, please if I can get your feedback on this. For Carpet/mid motor. Stiffer springs front and rear? Stiffer than the "stock" springs? thanks. Don't want to spend $40+ if not needed.
noworries is offline   Reply With Quote
Old 01-07-2013, 08:11 AM   #4020
t8rtot's Avatar
go to petit rc and look at the RB6 "Carpet" setups, you'll need to go stiffer but you can save some $$$ by shopping at Speedtechrc.com.
good luck
Sfida
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15027 11-22-2017 09:29 AM
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22984 11-21-2017 10:14 AM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 09:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 05:30 PM
