    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree25Likes
Old 01-06-2013, 03:05 PM   #3991
K_King's Avatar
Trader Rating: 39 (100%+)
Send a message via AIM to K_King
You want to go fast in stock? Make you have a GOOD PUNCHY battery, and a good motor.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 01-06-2013, 03:08 PM   #3992
Trader Rating: 74 (100%+)
Originally Posted by Troy Mckune View Post
STOP!
Your making me crazy. One of the best things about this car is the big bore shocks. Kyosho shocks are so incredibly good.
The extreme focus on shaving weight is misguided. Work on driving, car setup, motor/battery/gearing, and tires. If you think shaving another 50 grams will make you the fastest your wrong.
My $.02
Chill out bro, I run a rb6 in mod and 1 b4.1 in stock. The b4.1 I have to ad weight to it to get it minimum. Just picked up another rb6 to try in stock cause I love it in mod. haven't even ran it yet.
Weight is an issue to clear a triple on the track I run at. Only 2-3 guys can clear that jump. Can save a whole second on a lap and I can barely clear it with the b4.1 now. 17.5 is a very large competitive class there so want to be prepared. Would rather deal with the weight issue before next saturday instead of ON Saturday.
b121774 is offline   Reply With Quote
Old 01-06-2013, 05:04 PM   #3993
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
STOP!
My $.02
Troy.
Dialing in a car, including weight, and working on driving/setup/tires etc.. are NOT mutually exclusive. Your post insinuates that in order to have/do one, you have to give up the other, and that just isn't the case. You can do both, and both have value to your lap times. Fine tuning your weight is one of the best / most significant things you can change on your setup. Weight affects acceleration, nimbleness, braking, and traction. When traction is low, more weight generates more grip, possibly helping lap times. On tracks like mine, where traction is VERY high, too much weight generates too much traction, and you have issues with traction rolling, which DEVASTATES lap times... the lighter the better. 50 grams makes a huge difference.
Nobody is doing any "Extreme focusing".. whatever that is... were just chatting on a forum, that's it. Relax a little.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 01-06-2013, 05:59 PM   #3994
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Just imagine if they came out with a plastic chassis as an option.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 01-06-2013, 06:02 PM   #3995
Super Moderator
would be a great tuning option for lower traction tracks!
- RCSpecialties -
Old 01-06-2013, 06:09 PM   #3996
t8rtot's Avatar
Trader Rating: 14 (94%+)
Take out the side guard screws and the chassis twists like pretzel
Sfida
t8rtot is offline   Reply With Quote
Old 01-06-2013, 06:12 PM   #3997
gelshocker's Avatar
Looking at Tebo's car I think he filed off the gutter walls.
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 01-06-2013, 06:45 PM   #3998
Super Moderator
Iv run my car with all combinations of screws in the side pods.... even with no screws, the car still doesn't flex much. If you can twist your car's chassis like a pretzel, you have a unique chassis.
- RCSpecialties -
Old 01-06-2013, 07:27 PM   #3999
joeymdz's Avatar
Send a message via MSN to joeymdz
If you want a "lighter" chassis then you should ask troy.. He has the tooling to make it happen! Hint hint buddy!!!
And to me 50 grams isn't that much in offroad world compared to onroad. I had a 22 since they came out and Im a new daddy to an rb6. Yes its chunky but love the way it drives compared to the losi. Plus having the pro kyosho guys locally sure does help for set up and setting the bar
RC Plus*McKune Designs*NW Hobbies*Premier RC Raceways*Daves Tracks
joeymdz is offline   Reply With Quote
Old 01-06-2013, 07:54 PM   #4000
eper's Avatar
Trader Rating: 14 (100%+)
id say he did that for a little weight savings and to stick his electronics better. he runs mod for one so weight isnt an issue. a light car isnt the only answer out there. weight adds stability. stability = easier to drive easier to drive = less mistakes. less mistakes = more wins. so theres one triple you cant clear! dont tune for 1 specific section of track. but in the end its your car so have at it. let me know when your selling your heavy shocks
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 01-06-2013, 08:10 PM   #4001
t8rtot's Avatar
In you're hands no, however you should be able to feel a significant difference on track with and without screws.
Sfida
Old 01-06-2013, 08:11 PM   #4002
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Anyone have part numbers for the long shock ends? I got one pack from amain but its not as long as the ones that cam with my kit.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 01-06-2013, 08:49 PM   #4003
Troy Mckune's Avatar
Trader Rating: 38 (100%+)
I understand the discussion. I just think removing the big bore shocks to shave 10 or so grams is little extreme.
The RB6 is a bit on the heavy side of the minimum weight. So I understand the urge to shave weight. I just think when you start to sacrifice durability and/or performance for what you think you will gain in weight savings you are going to far. You could also go for a lighter ESC, 16ga wire, aluminum turnbuckles, or mill your chassis. All of these would shave weight but at what cost?
I think your time and money are better spent focusing on getting better as a driver, setup (other than the last 50 grams), better batteries and motor, and tires.
A couple of weeks ago I was running stock buggy at Top Gear in Portland. I TQ'd and my fast laps were 13.9 seconds. That night I let Andy Dibrino drive my car. Within a couple of laps he was turning 13.5 second laps. 4 tenths just because he is a better driver.
Mckune Design / facebook page / RC America / XRAY / Lunsford Racing
Mckune Design is a custom manufacturer of CNC machined carbon fiber, G10, & composite laminate parts for RC, Aerospace, medical, and high tech industries.
Troy Mckune is offline   Reply With Quote
Old 01-06-2013, 09:02 PM   #4004
joeymdz's Avatar
You didn't do a 13.9.... It was more of a 14.9!! Haha
Old 01-06-2013, 09:23 PM   #4005
savageboy69's Avatar
Trader Rating: 88 (100%+)
i agree, one of the key buying points for kyosho is there shocks, you get rid of em yes you save weight but what does it do for your handling? and personally i think 50g of weight can be easily compensated for to make the tripple you speak of by adjusting motor timing correctly, geared corectly and of course setup, 4hole pistons will give you more pop off of a jump compared to 5 hole too by the way
Xray|Rc America|Hudy|FX engines|Tekin|SOR graphics|LFR|Ogio|SRT servos|
XB8 2016
XB8-E 2016
XB4 2017
savageboy69 is offline   Reply With Quote
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15027 Yesterday 09:29 AM
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22984 11-21-2017 10:14 AM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 09:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 05:30 PM
