    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 01-05-2013, 03:53 PM   #3961
t8rtot's Avatar
Trader Rating: 14 (94%+)
Originally Posted by evolution03 View Post
Any specific reason why ? Do they last longer or do others just not work well with Kyosho ?
Ceramics are harder and smoother on the surface causing them not to grab and you to tighten it down more.
Carbides allow you to loosen your diff, and the stock KYO or BFAST parts will last quit a long time and stay smooth
Sfida
t8rtot is offline   Reply With Quote
Old 01-05-2013, 04:24 PM   #3962
tony montana's Avatar
Trader Rating: 65 (100%+)
agreed the stock diff is butter smooth. I did notice the other day that the trannys in the other cars made much more noise than the rb6. I could barely hear my rb6 go by the drivers stand
K.C. Guy. Team Xray - rc america
tony montana is offline   Reply With Quote
Old 01-05-2013, 04:56 PM   #3963
cnelson3's Avatar
Originally Posted by ChadBlanton View Post
...you like it? Seems like a good weight savings being aluminum vs. steel and obviously the heat sink is a good thing too.
steel?.. I have one on my sc-r and it's considerably more flexible than the one on my rb6. I don't often recommend against a company that makes stuff for kyosho's but in this one case, i would personally recommend spending the money and a good kyosho motor plate.
cnelson3 is offline   Reply With Quote
Old 01-05-2013, 05:08 PM   #3964
Old 01-05-2013, 05:13 PM   #3965
Energyzer's Avatar
Guys, which Rear Susp. holders are the narrow ones? Gun metal.
Edit: Do you have what it seems to me like excessive play on the rear arms? I think it comes from the little metal pieces that capture the hinge pins into the susp holders... What do you think?
Energyzer is offline   Reply With Quote
Old 01-05-2013, 06:39 PM   #3966
silvalis's Avatar
Trader Rating: 29 (100%+)
It's on the setup sheet.
http://www.petitrc.com/setup/kyosho/...SetupSheet.pdf
Forward-back play at the suspension mount pins? Nope. Check that you're using the correct suspension mounts (either RF or RF2). Mine wiggles maybe 1/4 of a mm
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 01-05-2013, 07:22 PM   #3967
B00t13g's Avatar
I shimmed the play out. Nice and snug with no binding.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 01-05-2013, 07:36 PM   #3968
Energyzer's Avatar
I'm using the RF which is the narrow one right? I think it's the only one that came on the kit.
I'll try to shim it. Mine wiggles almost 1mm, which is too much i think!
Old 01-05-2013, 09:19 PM   #3969
Anyone else care to weigh in on this? (st rc motor plates)? I was about to buy one, but maybe I guess I won't..
ChadBlanton is offline   Reply With Quote
Old 01-05-2013, 09:36 PM   #3970
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Originally Posted by fastestwon View Post
i have one on my car
I have one on my rb5. Work great mesh is quiet as well. Just got the machined for the 6 because it matches the gm parts.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 01-05-2013, 09:52 PM   #3971
silvalis's Avatar
kit comes with both narrow RF and wide RF2. If you followed the manual, you'd have put RF2 wide on.
Old 01-05-2013, 11:32 PM   #3972
I asked this question in the TLR 22 thread and no one had an answer, I am hoping maybe someone more familiar with Kyosho products will know.
Can I use Kyosho big bore shocks on a 22 buggy as a direct replacement?
Any help would be greatly appreciated..........
Medicinal Coma is offline   Reply With Quote
Old 01-05-2013, 11:35 PM   #3973
BranVita's Avatar
Trader Rating: 39 (100%+)
Shocks? You should be able to. Maybe a couple spacer adjustments here and there... But Im preety sure if you can use these on a B4.1, you can use them on a 22
Branden V.
Kyosho Rb6 | Orion R10 Pro | SchuurSpeed 17.5 | Savox 1257
Kyosho SC-R SP | Orion R10 Pro | SchuurSpeed 17.5 | Savox 1258
BranVita is offline   Reply With Quote
Old 01-05-2013, 11:39 PM   #3974
BranVita's Avatar
Just installed Stainless Steel Screws throughout the car. Not sure if it made it lighter, but it sure does look better lol
Branden V.
Old 01-06-2013, 12:03 AM   #3975
cnelson3's Avatar
The look is awesome. Good share.
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22956 Today 04:13 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
