    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree18Likes
Old 01-04-2013, 11:16 PM   #3946
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Thanks for the info/effort... Can't believe the alu rear upper bulkhead is the same weight as the plastic piece!
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 01-04-2013, 11:22 PM   #3947
Trader Rating: 18 (100%+)
I was surprised too but when I started looking at the two closely Exotek did a great job shaving/eliminating material wherever they could. Still 2 grams over Exotek's claim of 10 grams, at least according to this scale which has been very accurate for us in the past....
Ctimrun is offline   Reply With Quote
Old 01-04-2013, 11:25 PM   #3948
BranVita's Avatar
Trader Rating: 39 (100%+)
Quick question, but wouldnt going to the Alu. Rear brace somewhat change the handling affect by stiffening up the rear?
Branden V.
Kyosho Rb6 | Orion R10 Pro | SchuurSpeed 17.5 | Savox 1257
Kyosho SC-R SP | Orion R10 Pro | SchuurSpeed 17.5 | Savox 1258
BranVita is offline   Reply With Quote
Old 01-04-2013, 11:38 PM   #3949
Super Moderator
Nah... I don't think.there is any noticeable flex in the plastic piece.
- RCSpecialties -
Old 01-04-2013, 11:43 PM   #3950
Super Moderator
Originally Posted by Just1More View Post
Just bought a new RB6 and starting the build. I know this has been asked before, but anything I should pay particular attention to when building, or adjust from the manual setup? Not necessarily asking which aftermarket parts i should buy, just what should be adjusted or done perfectly when building the car? I have experience with building race kits, so I won't overlook the obvious(I hope). Thanks
I'll hook you up with the info tomorrow at the track.
- RCSpecialties -
Old 01-05-2013, 12:23 AM   #3951
Just1More's Avatar
Sounds good. Does the Rb6 come with ceramic diff balls? I have a new set for a B4(thrust and main), will they fit?
Mark Clark
RB6
B44.1
TC6.1
Just1More is offline   Reply With Quote
Old 01-05-2013, 01:16 AM   #3952
TT_Vert's Avatar
Trader Rating: 68 (100%+)
This is what I've got thus far. I am not posting my avid spring rates quite yet as I've changed my testing procedure since these results. These are average of 3 tests at both .50" and 1.0". My new procedure is very repeatable. My "independant test" data is from the petit spring chart of independant tests. Note how close in rate the Yellow and Pink Xgear rears are? They are supposed to be the softest and nearly the stiffest springs they provide.
Originally Posted by skrichter View Post
I will be curious to see your findings vs. this spring chart. Yes, the KYO springs are quite a bit different than the advertised rate (according to this chart).
http://www.petitrc.com/reglages/BuggyBigBoreSpring.pdf
TT_Vert is offline   Reply With Quote
Old 01-05-2013, 07:18 AM   #3953
Trader Rating: 101 (99%+)
Originally Posted by ben73 View Post
hi guys
are these the correct parts to put the "old" rb5 front axles on the RB6?
KYOLAW30GM Kyosho Aluminum Clamping Wheel Hubs Gunmetal
KYOUM506 Kyosho Front Wheel Shafts
Yes, those are correct.
~ Richard Watchorn ~
* Team Associated/Reedy Electronics * OCRC Raceway *
* Schelle Racing * CBuilt Designs * Complex Ink *
desertracerdad is offline   Reply With Quote
Old 01-05-2013, 09:39 AM   #3954
Super Moderator
Always carbides in kyosho diffs.
- RCSpecialties -
Old 01-05-2013, 11:11 AM   #3955
fastestwon's Avatar
Trader Rating: 15 (94%+)
Default here is the latest race video
i would like to see some race videos from all you guys
http://youtu.be/YFFXRg1ZVjU
fastestwon is offline   Reply With Quote
Old 01-05-2013, 01:12 PM   #3956
Moderator
Posvar's Avatar
Trader Rating: 462 (100%+)
Me too!
Having fun with my 9 year old and running Kyosho cars!
Posvar is offline   Reply With Quote
Old 01-05-2013, 01:56 PM   #3957
anyone tried the STRC milled motor plates? They look good and are only 12 bucks ...
ChadBlanton is offline   Reply With Quote
Old 01-05-2013, 01:57 PM   #3958
fastestwon's Avatar
i have one on my car
Old 01-05-2013, 02:27 PM   #3959
Any specific reason why ? Do they last longer or do others just not work well with Kyosho ?
evolution03 is offline   Reply With Quote
Old 01-05-2013, 02:31 PM   #3960
...you like it? Seems like a good weight savings being aluminum vs. steel and obviously the heat sink is a good thing too.
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22972 Today 04:13 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
