    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree16Likes
Old 01-03-2013, 11:14 PM   #3916
Phil Trotta's Avatar
Originally Posted by Cpt.America View Post
Run the stock length shock ends that come with the car. That of course is medium in front, and long in rear. If you want a little more (which maybe you might want in the front), just unscrew the eyelets a turn or so. In the rear, the long eyelets provide quite a bit of rear droop, which this car likes. It helps with rear traction in the corners. If you need a little less, run a limiter.
Why are you using a limiter rather than adjusting overall shock lengthy at the eyelet
Is it because of where the piston sits in the bore? Just curious
PHIL TROTTA
Phil Trotta is offline   Reply With Quote
Old 01-04-2013, 07:36 AM   #3917
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Because once the eyelet is screwed all the way down, you can't screw it down any farther (without damaging threads). You have better control over shortening your length at that point with a limiter, than with a much shorter eyelet. They both work, one is a much larger step than the other.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 01-04-2013, 10:32 AM   #3918
Looking for a mod setup that uses a full sized lipo. From all the ones I have seen they are all for short packs. Anyone have any info?
Gitsum is offline   Reply With Quote
Old 01-04-2013, 11:05 AM   #3919
aloksatoor's Avatar
Trader Rating: 42 (100%+)
http://www.kyoshoamerica.com/assets/...heet_Kohta.pdf
try this, I based mine when I was running a full pack off this.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 01-04-2013, 01:45 PM   #3920
SAMCRO's Avatar
Hey guys, I am looking to get an RB6 in the next few weeks. Can you tell me what springs/pistons come with the kit? I am looking to use one of the tebo setups as a starting point which called for pink front, red rear and 5 hole pistons.
Also, I am running a b4.1. How do you guys like the Rb6 compared to the b4.1?
SAMCRO is offline   Reply With Quote
Old 01-04-2013, 02:20 PM   #3921
joeymdz's Avatar
Send a message via MSN to joeymdz
it comes with pink front, red rear and 5 hole pistons so you're in luck!
RC Plus*McKune Designs*NW Hobbies*Premier RC Raceways*Daves Tracks
joeymdz is offline   Reply With Quote
Old 01-04-2013, 03:03 PM   #3922
SAMCRO's Avatar
That is great news. Any addons that I should buy when I get the kit? What about spare parts that frequently break?
Old 01-04-2013, 03:18 PM   #3923
Super Moderator
Here are the three parts I see break:
Rear upper Bulkhead (if you don't use set screws, and/or use the outer hole)
Rear plastic suspension hangers (i recommend the alu versions right off the bat, if funds allow)
Steering rack (i recommend an alu version right off the bat, if funds allow)
- RCSpecialties -
Old 01-04-2013, 03:26 PM   #3924
Moderator
Posvar's Avatar
Trader Rating: 462 (100%+)
Yep!
Having fun with my 9 year old and running Kyosho cars!
Posvar is offline   Reply With Quote
Old 01-04-2013, 03:34 PM   #3925
SAMCRO's Avatar
Thanks. I don't see a kyosho rack, but Exotek makes one. Is this the one you were referring to ? http://www.stormerhobbies.com/cgi-bi...&pn=EXO1258BLK
Old 01-04-2013, 03:36 PM   #3926
BranVita's Avatar
Trader Rating: 39 (100%+)
yup thats the one.
Branden V.
Kyosho Rb6 | Orion R10 Pro | SchuurSpeed 17.5 | Savox 1257
Kyosho SC-R SP | Orion R10 Pro | SchuurSpeed 17.5 | Savox 1258
BranVita is offline   Reply With Quote
Old 01-04-2013, 03:36 PM   #3927
SAMCRO's Avatar
Also, what is good starting setup? I was going with Tebo's from West Coast rc. Any thoughts?
Old 01-04-2013, 04:08 PM   #3928
Trader Rating: 77 (100%+)
There are better. Check out Dias set up from Kyosho site. Have to remember the Tebo set up was pre-release of the car.
TRF 418 - Team Powers 17.5, HobbyWing Stock Spec, Xpert servo
Xray T4 2016 - Trinity D4, HobbyWing Stock Spec, Ko Propo servo and radio
KustomRCGraphics.com (Best looking novice on the track)
goin2drt is offline   Reply With Quote
Old 01-04-2013, 05:45 PM   #3929
Super Moderator
Id avoid it. Pre-production car, pre-production chassis, rb5 rear arms, unusual surface conditions at west coast for that event, and I got to talk to him for a good 20 minutes about the car at that race, and I didn't get the feeling he was very comfortable with the setup, or even the car at that point. Frankly, im surprised it got posted at all.
- RCSpecialties -
Old 01-04-2013, 05:48 PM   #3930
Super Moderator
yeah... you can get it there, or directly from exotek. They have some other good bling there as well.
Speaking of which, any feedback on the alu shock posts? I still don't like the alu on alu idea... I don't want to wear the shock caps.
- RCSpecialties -
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22970 10-17-2017 05:10 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
