    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree18Likes
Old 01-02-2013, 06:37 PM   #3841
Applesauce's Avatar
Trader Rating: 14 (100%+)
Hey Guys does the SP motor plate fit the 6?
Applesauce is offline   Reply With Quote
Old 01-02-2013, 06:47 PM   #3842
asc6000's Avatar
Trader Rating: 15 (100%+)
Originally Posted by t8rtot View Post
Less weight would be nice, however indoors, my blinky 17.5 out accelerates and out corners the b4s and Team Cs (plastic chassis cars). I understand the benefits of lower weight but if your running a strong batteries and good motor you're at no disadvantage.
Totally with you on this one. BITD I had an RC10 highly modified foam chassis car that was so light it was difficult to tune but it was FAST in stock. But that was 27turns and 7.2volts. Lipos and brushless changed the weight game. However you could easily find small gains all over the place, like the ends of that diggity strap, alu nuts instead of steel, the case for the capacitors, the antenae holder you don't use, all those little things will take of some grams and clean up the look of the car. Even if it is a waste of time performance wise it will still be fun to do and your car will be unique.
"you reach the limit, you touch the limit, then you pass the limit, now there is a new limit"
Ayrton Senna
asc6000 is offline   Reply With Quote
Old 01-02-2013, 07:11 PM   #3843
Trader Rating: 18 (100%+)
I am sure you have seen this but even with the power of today's batts and mod motors the pro guys are trying to save weight as well over the stock setup. Again I think shaving some weight would be very beneficial for stock class racers to get some more advantage. Of course any advantage is dependent on having a perfect or near perfect run!
Pic of Tebo's milled chassis. Look like he even shaved some of the plastic side braces as well.....
Ctimrun is offline   Reply With Quote
Old 01-02-2013, 07:17 PM   #3844
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
When was this pic taken? I question because I thought someone posted he was running initial prototype parts still. I could be wrong though.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 01-02-2013, 07:22 PM   #3845
Not sure when it was taken, just saw it on live rc. It's very possible this was before production was finalized....
Old 01-02-2013, 08:06 PM   #3846
That's an old photo, from the super nats at west coast before the car was released.
Tom87 is offline   Reply With Quote
Old 01-02-2013, 09:14 PM   #3847
MrHistory's Avatar
I saw those milled sections too and when i looked at my kit i recall seeing the same milling but its all anodized so i think they milled his chassis after the anodizing. I think its the same milling in the kit?
does anyone know how much weight is save with the ti screws, ti pins, and ti balls
Irwin RC 1/8th Pan Car Specialists - www.irwinrc.com
SPM Competition, WRC Racing, MIP, Novarossi
MrHistory is offline   Reply With Quote
Old 01-02-2013, 09:41 PM   #3848
Would love to know but whatever it is it will no doubt come at a hefty price!
Old 01-02-2013, 10:36 PM   #3849
Question on suspension holders -- I'm using 0* hubs. I'm assuming the rear toe is the same whether I use wide or narrow suspension hangers (-3*)? Besides changing hubs, what if I go with the wide front and narrow rear suspension holders? This should give me less rear toe-in, correct? I have not heard of anyone mixing the wide with the narrow holders on here, so what would be the negatives? Can someone please straighten me out?
flybyublue is offline   Reply With Quote
Old 01-02-2013, 11:07 PM   #3850
Old 01-02-2013, 11:46 PM   #3851
Yeti AS3's Avatar
Trader Rating: 77 (100%+)
I believe a wide rear holder and narrow front is 4.5 rear toe. Narrow rear and wide front is 1.5 toe.
Hot Bodies D413
AE B5m
Haigh Designz -Custom Airbrushing
Leisure Hours Hobby and Raceway!!
Yeti AS3 is offline   Reply With Quote
Old 01-03-2013, 12:33 AM   #3852
Originally Posted by mikeyscott View Post
You tempted mate? I'm sure Uncle Tony will look after ...
RB6 is good as it is with proper motors in there!
Xray XB4 | Kyosho RB6 | Kyosho Rudebits DB2
Chris-s is offline   Reply With Quote
Old 01-03-2013, 12:34 AM   #3853
I am interested in trying Kyosho big bore springs on my 22, I currently run Losi red springs in the front and white Losi springs in the rear. Could someone please help me with a Kyosho equivilant....... I was thinking Pink fronts and White rears?
Thank you very much for any input, it is greatly appreciated
Medicinal Coma is offline   Reply With Quote
Old 01-03-2013, 05:26 AM   #3854
mizzle's Avatar
I noticed my rb6 steering does not go to full lock to the right just wondering if iam missing something ? Do you think they are milling chassis for weight or for flex?
I.R.H.-
mizzle is offline   Reply With Quote
Old 01-03-2013, 05:48 AM   #3855
Nitronut3's Avatar
Send a message via AIM to Nitronut3
Did you trim the front bulkhead like it shows in the instructions?
Nate Jaskot
XRAY, RC America, KO Propo, Hudy, FX Engines, Nitropro, Rc addiction products , TeamSR, SmacTrac
Nitronut3 is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22972 Today 04:13 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
