    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree25Likes
Old 01-02-2013, 02:37 PM   #3826
aloksatoor's Avatar
Trader Rating: 42 (100%+)
I buy jconcepts wings (dex210 hi clearance) in bulk and trim them to the lowest possible cut line more flex that way- this for racing. For practice still use original k wing, the cracks havent been growing and wings holding fine now
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 01-02-2013, 03:10 PM   #3827
Yeti AS3's Avatar
Trader Rating: 77 (100%+)
My fix for the rear camber block was this...first I cut 2.5mm carbon fiber plate in the shape of the oval area where the ball studs mount. Drill all the holes with a .098 drill. Rough up the cf and bottom of the bulkhead ball stud area. Align the holes up and glue the cf to the bottom, clamp and let cure. Tap all holes through with an m3 tap. Put a set screw through the inside hole to tie cf and bulkhead together and your ball stud on the middle or outer hole. Use a stud long enough to extend into cf. It is rock solid! A buddy flipped my car and got blasted in the straight, it broke the camber link lol. The link was in the outer hole too.
Hot Bodies D413
AE B5m
Haigh Designz -Custom Airbrushing
Leisure Hours Hobby and Raceway!!
Yeti AS3 is offline   Reply With Quote
Old 01-02-2013, 03:39 PM   #3828
Trader Rating: 18 (100%+)
I've read that this car is a "little heavy" which IMO is a bit of an understatement. Mine with Exotek steering rack and arms, Kyosho aluminum rear hubs, Kyosho aluminum rear suspension mounts, radiopost servo, Orion R10 Pro ESC, Airtronics RX-471, Fantom shorty pack, Fantom 17.5 motor, and barcodes front and rear comes it at 1585 grams. I have already cut my wires as short as possible, with the exception of the servo and transponder because I have not yet finalized the position of the receiver or transponder. I also weighed my current battery position/hold down setup versus the stock plastic stuff and I am a few grams lighter (didn't originally go with this battery setup for weight). For guys running mod it may not matter a whole lot, but for those of us running stock I think we would benefit greatly from shaving some weight.
Besides milling out the chassis and titanium bits, anyone have any thoughts or ideas?
EDIT: added photo of current setup....
Ctimrun is offline   Reply With Quote
Old 01-02-2013, 03:52 PM   #3829
Originally Posted by Ctimrun View Post
I've read that this car is a "little heavy" which IMO is a bit of an understatement. Mine with Exotek steering rack and arms, Kyosho aluminum rear hubs, Kyosho aluminum rear suspension mounts, radiopost servo, Orion R10 Pro ESC, Airtronics RX-471, Fantom shorty pack, Fantom 17.5 motor, and barcodes front and rear comes it at 1585 grams. For guys running mod it may not matter a whole lot, but for those of us running stock I think we would benefit greatly from shaving some weight.
Keep an eye on RudeBits as I saw a nice prototype chassis recently
Due to be tested soon and first comment was you yanks running blinky class etc....
Schumacher - RW Racing - RudeBits - TORCH
mikeyscott is offline   Reply With Quote
Old 01-02-2013, 04:31 PM   #3830
Do I get commission ?
Xray XB4 | Kyosho RB6 | Kyosho Rudebits DB2
Chris-s is offline   Reply With Quote
Old 01-02-2013, 04:37 PM   #3831
Moderator
Posvar's Avatar
Trader Rating: 462 (100%+)
Lol
Having fun with my 9 year old and running Kyosho cars!
Posvar is offline   Reply With Quote
Old 01-02-2013, 04:41 PM   #3832
ByteStream's Avatar
Who makes those battery holders and brace?
RCAmerica | Xray | Hudy | KO Propo | Hobbywing HWNA | R1Wurks | BSR Tires
5280 Raceway - www.5280raceway.com
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
ByteStream is offline   Reply With Quote
Old 01-02-2013, 04:49 PM   #3833
Battery posts and strap are Kyosho parts. The battery braces are diggity designs. I slotted the mounting holes on the braces a bit so I could use the closest mounting position and spread them apart slightly to prevent having to spread to the next mounting hole and using foam.
Old 01-02-2013, 05:20 PM   #3834
You tempted mate? I'm sure Uncle Tony will look after ...
Old 01-02-2013, 05:45 PM   #3835
ByteStream's Avatar
Happen to know the part number for the carbon strap?
Did you cut down the stap at all?
Old 01-02-2013, 06:07 PM   #3836
TT_Vert's Avatar
Trader Rating: 69 (100%+)
Does anyone know if the big bore upper shock eyelet (not the cap just the plastic insert that the upper screw goes though) is the same as the small bore? I'm looking to go to a big bore on my zx5 but the shocks are from an RB6 which has the longer top shock cap so I'd have to switch them and would like to use my small bore zx5 upper caps if possible. I know they are a different part number but I'm wondering if that is just because the spring cup that is included is the bigger diameter for the big bores.
Dave
TT_Vert is offline   Reply With Quote
Old 01-02-2013, 06:12 PM   #3837
Part number is KYOUMW503 and ya I cut it.
Old 01-02-2013, 06:23 PM   #3838
t8rtot's Avatar
Trader Rating: 14 (94%+)
Less weight would be nice, however indoors, my blinky 17.5 out accelerates and out corners the b4s and Team Cs (plastic chassis cars). I understand the benefits of lower weight but if your running a strong batteries and good motor you're at no disadvantage.
Sfida
t8rtot is offline   Reply With Quote
Old 01-02-2013, 07:14 PM   #3839
MrHistory's Avatar
milling the chassis starts to change what was intended by the designer. i notice many top drivers dont add the pretty stuff like aluminum steering parts and carbon fiber battery mounts. it seems that at least some of these things just add weight and the point in stock is to make the car light and not have it built like a tank. what is the weight of your battery mount assembly and big thumb screws vs the plastic stock assembly with 2 tiny clips?
you can save weight by using a low profile servo, get a titanium screw kit (speedtech rc), ti pins and balls. use TQ 13gauge thin wall wires...
Irwin RC 1/8th Pan Car Specialists - www.irwinrc.com
SPM Competition, WRC Racing, MIP, Novarossi
MrHistory is offline   Reply With Quote
Old 01-02-2013, 07:21 PM   #3840
Didn't write the weights down but all my battery setup parts are lighter than the stock stuff I was using. Not by much but by a few grams.
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22977 11-13-2017 05:09 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15026 11-02-2017 04:19 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 09:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 05:30 PM
