    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree17Likes
Old 01-02-2013, 09:00 AM   #3811
Originally Posted by KSimmonds View Post
I've always used the method shown in this video.
many thanks!
ChadBlanton is offline   Reply With Quote
Old 01-02-2013, 09:49 AM   #3812
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
The only piece I have broken is the rear camber plate (where the rear inner ball stud attaches). I have seen this piece broken on 3 separate cars (and yes- all 3 were using the set screws on either side of the ball stud), so that might be a good part to carry as a spare as well. I have since installed the exotek aluminum version.
That piece is called the upper rear bulkhead, and there is a design issue where the thickness of the plastic which the ballstud threads through, is too thin. From what I have heard is that there was already a running mold change on that part, and its thicker now, however I haven't confirmed with my own eyes.
Having said that, it would be worth knowing how much heavier the alu piece is. The car is already over weight, and I myself wouldn't want to add any more.
The only people I have seen break this part, were all running the outer hole where there is the least amount of supporting material. Running the middle hole with both supporting set screws seems to be pretty solid
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 01-02-2013, 09:56 AM   #3813
t8rtot's Avatar
Trader Rating: 14 (94%+)
this ^^ BUT keep the bleeder hole facing up!
putting the piston in first (at your desired rebound) is key
Sfida
t8rtot is offline   Reply With Quote
Old 01-02-2013, 10:07 AM   #3814
Trader Rating: 18 (100%+)
I didn't actually weigh the 2 pieces when I replaced it, but the way the Exotek part is constructed I can't believe it's heavy enough to impact performance in a negative way.
I only run mod so weight hasn't been a large factor in my thinking, but I can certainly understand that being something to consider in the stock class.
Kyle Simmonds | RB6 | FS2SP | TKI3
KSimmonds is offline   Reply With Quote
Old 01-02-2013, 10:09 AM   #3815
I do mine exactly like the video shows- even keeping the groove toward the bottom once the cartridge is almost all the way in. These are still emulsion shocks so air is going to be a component in the end.
Old 01-02-2013, 10:27 AM   #3816
Super Moderator
Weight affects more than just acceleration... It affects all aspects of handling, including direction changing and braking. The car is already heavy, and it all adds up.
- RCSpecialties -
Old 01-02-2013, 10:31 AM   #3817
I certainly agree with that. I'm extremely happy with the way my car handles as I have it set up for the tracks in my area. Next time I rebuild, I'll weigh the stock piece with the set screws vs. the Exotek part and post my findings. (unless someone beats me to it!)
Old 01-02-2013, 10:42 AM   #3818
While I can't confirm the weight of 10 grams listed on the Exotek site for their piece is accurate, this is what my scale shows for the stock piece with all 4 set screws on either side of where the ball stud would mount.
Old 01-02-2013, 10:49 AM   #3819
Super Moderator
interesting
- RCSpecialties -
Old 01-02-2013, 10:55 AM   #3820
aloksatoor's Avatar
Trader Rating: 42 (100%+)
nice! I ran 4 caster in fronts and now I like it more than before!! The high speed on power steering is INSANE!! Makes me think im driving my 1/8 nitro buggy hehehe. What antisquat are people running? I asked before as well but dint get any replies. The setup sheets don't mention it right?
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 01-02-2013, 11:08 AM   #3821
pekow91's Avatar
Trader Rating: 45 (100%+)
That's good to know. I have gone through at least 2 different bulkheads (with the set screws in) and I just ordered the Exotek one.
Kyosho RB6 | Kyosho MP9 TKI3E | Xray XB4
pekow91 is offline   Reply With Quote
Old 01-02-2013, 12:14 PM   #3822
t8rtot's Avatar
we forget that it being aluminum or any metal doesn't automatically make it heavier. most often they can make the parts smaller (or with less reinforcement) because the material is stronger...
Sfida
Old 01-02-2013, 01:22 PM   #3823
Trader Rating: 38 (100%+)
Default Mid Motor RB6
Any thoughts out there that a mid Motor drives similar to what a TC does? I have yrs in TC but completely new to RB6 and have yet to drive it. thank you
noworries is offline   Reply With Quote
Old 01-02-2013, 01:34 PM   #3824
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
The only thing I would be worried about is now you are making that end of the car more rigid which may cause traction issues. Which might be good or bad depending on what type of track you run on, Yes/No?
Curious, how much are you trimming the wings down? I guess I am looking at the stock wing that came with the kit if you haven't changed it out already.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 01-02-2013, 01:37 PM   #3825
Super Moderator
Kraig's Avatar
I haven't run mid motor but remember you have a 2wd vehicle versus a 4wd vehicle and they would drive different.
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22971 10-20-2017 08:14 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
