    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 01-01-2013, 05:24 PM   #3781
t8rtot's Avatar
Trader Rating: 14 (94%+)
Originally Posted by b121774 View Post
aka diana?
Haha foam, the swype function on my phone doesn't airways cooperate.
Sfida
t8rtot is offline   Reply With Quote
Old 01-01-2013, 06:04 PM   #3782
tony montana's Avatar
Trader Rating: 65 (100%+)
JCI3348Y - JConcepts Mono 2.2 Rear Wheel w/12mm Hex so these will work with the rb6?
K.C. Guy. Team Xray - rc america
tony montana is offline   Reply With Quote
Old 01-01-2013, 06:06 PM   #3783
Trader Rating: 72 (100%+)
I use those but a serrated wheel nut is a must.
b121774 is offline   Reply With Quote
Old 01-01-2013, 06:07 PM   #3784
airways? guess it doesnt, lol
Old 01-01-2013, 06:08 PM   #3785
and these for the fronts? JConcepts Mono 2.2 Front Wheel w/12mm Hex (Yellow) (4) (B4.1/RB5)
[JCI3347Y]
Old 01-01-2013, 06:13 PM   #3786
[JCI3347Y]
Yes, I use the same on both my b4 and rb6
Old 01-01-2013, 06:18 PM   #3787
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Raising roll center would increase side bite, correct? Hmm
Incorrect. Raising the roll center increases roll resistance which provides less traction gain on that end of the car, whenever the car is rolling. Wider track = higher RC = less traction while rolling (throughout the corner).
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 01-01-2013, 07:22 PM   #3788
Default Spur/Pinion Questions
Based on the suggestion of some guys 10-20 pages back I am going to go with 69/34 (spur/pinion) in stock class.
Since Kyosho does not seem to make a 69 do you recommend I go Kimbrough or JC Silent Spur Gear? Other then buying Associate slipper pads is there anything else I need?
For a pinion gear... who do you recommend I go with?
Thanks everyone!
Kopanas is offline   Reply With Quote
Old 01-01-2013, 07:26 PM   #3789
gearing in stock is not always the same from motor to motor. I run a Reedy Sonic 17.5, endbell timed to the middle(pretty much MAXED) of the silver motor screw and am running 27/72. Seems to have the best balance of torque/rpm. Its a rocket. Thats in my b4 though but should be the same for the rb6
Old 01-01-2013, 07:54 PM   #3790
ByteStream's Avatar
Just picked one of these kits up for a little change of pace.
The track is indoor - clay - 70x40ft. I plan to run the kit box stock until I get a feel for it, then make adjustments/upgrades as necessary.
Couple of questions:
1. Mid vs. Rear - what are most people going with on this type of surface? I've seen indoor track setups running mid, but most clay tracks running rear. Going to be running Gold Barcodes front/rear as it is the popular choice at the track.
2. Gearing - 13.5 blinky/boosted gearing - Reedy 13.5 - what is a good starting point for both? Looking to pick up a range of pinons. 76T is the stock spur right? I have no problem tuning to temp, just looking for a start.
3. I've read some posts that mention getting the rear aluminum suspension holders, but I've seen narrow and wide .. what is the stock replacement?
Thanks in advance.
RCAmerica | Xray | Hudy | KO Propo | Hobbywing HWNA | R1Wurks | BSR Tires
5280 Raceway - www.5280raceway.com
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
ByteStream is offline   Reply With Quote
Old 01-01-2013, 08:24 PM   #3791
silvalis's Avatar
Trader Rating: 29 (100%+)
Thanks everyone!
kimborough. Just add slipper pads, K plates are fine.
I went 69/30 reedy sonic @ 40 deg endbell
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 01-01-2013, 08:35 PM   #3792
Mxer59's Avatar
Trader Rating: 114 (100%+)
Originally Posted by silvalis View Post
kimborough.
I really liked 72/31-30 with my Tekin gen2 30deg end bell
5ive T (Bartoline 28.5cc, Bartoline Pipe, Team Chase)
Futaba 4pls
Team Chase 2015
Rd. 2 TQ-1st--Rd. 3 3rd
Mxer59 is offline   Reply With Quote
Old 01-01-2013, 09:15 PM   #3793
lbckevin's Avatar
Trader Rating: 91 (99%+)
I gear 72/33 and my speed is great.
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 01-01-2013, 09:26 PM   #3794
mdowney's Avatar
Trader Rating: 21 (100%+)
Thanks everyone!
The JConcepts Sikent Speed spurs are nice because they're precision machined for perfect balance but I'm not convinced that this is much of a benefit to justify the added expense.
I run 69/31 with a Trinity D3.5 with timing maxed and I'm happy with it. But I've also switched to running the Avid Triad spur with Avid top shaft. They make a machined 69T spur as well. My car has never felt better but I'm no expert.
Just experiment with pinion sizes to find the feel you like best. Bigger pinion will give you more top end and will make your motor run a little hotter so be sure to temp it after a few laps.
Mike Downey
I try all of the RC kits and usually race at Tacoma RC Raceway
mdowney is offline   Reply With Quote
Old 01-01-2013, 10:02 PM   #3795
Troy Mckune's Avatar
Trader Rating: 38 (100%+)
[JCI3347Y]
Having come from a B4.1 to an RB6. I run the Jconcepts mono wheels. Both fronts and rears work well. The fronts have an almost identical offset but the wheels have a deeper hex in them. I have had them bind a little with the stock RB6 axles. I just run a Tamiya 1/2mm touring car spacer. I am now switching to the RB5 axles with hexes as most of the local team guys (Joe Pillars, Shuan Dunlap, and Andy Dibrino) have done. The rears have about a 1/2mm deeper offset. So if you do not space them the rear will be about 1mm narrower than with Kyosho wheels.
As far as stock motor gearing. I usually gear 33 or 34/72 using associated or now Avid triad gears. I run full timing on a D3.5.
Troy
Mckune Design / facebook page / RC America / XRAY / Lunsford Racing
Mckune Design is a custom manufacturer of CNC machined carbon fiber, G10, & composite laminate parts for RC, Aerospace, medical, and high tech industries.
Troy Mckune is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22955 Today 12:08 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
