    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 12-30-2012, 07:43 PM   #3736
jwood7's Avatar
Originally Posted by offroad dude View Post
Have anybody tried running the Associated VTS slipper and spur gear on their B6..
I run one on mine. Works real good especially on my rt5. Just have to do a little grinding and cutting on it to make it fit but it's pretty easy to do.
jwood7 is offline   Reply With Quote
Old 12-31-2012, 12:39 AM   #3737
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
Originally Posted by Gitsum View Post
Question......How does using the short, medium and long shock ends affect the handling of the car? I'm assuming it would be like limiting the shocks but correct me if I am wrong.
Its basically droop settings. Longer = more droop possibilities.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 12-31-2012, 04:50 AM   #3738
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
Ran the buggy for the first time yest. Holy steering! Was very aggressive. Needed a bit more rear grip, but didn't have the correct tires (slicks) for the track I was running. Made the most of it.
Spoke to the local sponsored guy who was tearing it up. He said He like 521-1RB5 arms on his...Anyone know what the diff are between these and the std RB6 arms?
kwiksi is offline   Reply With Quote
Old 12-31-2012, 05:55 AM   #3739
Trader Rating: 35 (100%+)
Default inserts
what tire inserts are people running with suburbs?
nazman01 is offline   Reply With Quote
Old 12-31-2012, 07:49 AM   #3740
eper's Avatar
Trader Rating: 14 (100%+)
those arms give up rear traction the stock arms have more imo. where i race people are running the 6 arms on the 5. its all preference
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 12-31-2012, 09:17 AM   #3741
eper's Avatar
some video of my car. it looks a little pushy here gonna have to see if i can tune that out http://www.youtube.com/watch?v=tzxzu...ature=youtu.be
new milford ct,
Old 12-31-2012, 02:06 PM   #3742
K_King's Avatar
Wear down your front tires more and you will have that push gone.
Old 12-31-2012, 02:10 PM   #3743
aloksatoor's Avatar
Trader Rating: 42 (100%+)
you mean slicks?
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 12-31-2012, 02:14 PM   #3744
K_King's Avatar
Originally Posted by aloksatoor View Post
you mean slicks?
Nope, I have run AKA Vektor and Rebars fronts in SS. They are push monsters to start, but if you break them down to where the pins are 50% or more worn down you will get steering out of them. Even Gold Barcodes work a lot better worn down vs new. The only tire I havent tried at Suburbs.
Old 12-31-2012, 02:17 PM   #3745
aloksatoor's Avatar
I have the new suburbs in m4, they are money out of the box with red aka foams. I just switch the rears these days depending on traction levels and water content on track. The rebars are too tall a tread for even rear tires and hard wearing so gave up on them.
Old 12-31-2012, 02:41 PM   #3746
t8rtot's Avatar
Trader Rating: 14 (94%+)
I had good success with rebars with aka red foam out of the box on medium-high traction and they definately get better a they wear.
I would say the better the dirt, the better aka shines
Sfida
t8rtot is offline   Reply With Quote
Old 12-31-2012, 03:47 PM   #3747
tony montana's Avatar
Trader Rating: 65 (100%+)
you guys running aka red foams front and rear?
K.C. Guy. Team Xray - rc america
tony montana is offline   Reply With Quote
Old 12-31-2012, 04:13 PM   #3748
K_King's Avatar
Yeah rebars are way too tall. I take them to the asphalt and burn them in. Sucks but it's the only way to get them good. Once you get the and on them are really good if you need forward bit. They just don't have much sidebite.
Old 12-31-2012, 04:27 PM   #3749
aloksatoor's Avatar
Yep. Except for the hot bodies tires I used to have. The carcass is a bit big for red akas to till out, so used jconcepts open cell foams.
Old 12-31-2012, 04:35 PM   #3750
t8rtot's Avatar
Yes front and rear AKA foam. I was worried about loss of traction like many have reported but the 6 is so aggressive. it is PERFECT and as the foam wears in it just gets better, just like the tires.
My track also gets ample traction so I'm never in need of more. I'd like to try JC, Proline, and Sweep at some point but the AKA's are the ticket for my setup and track
Sfida
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22953 Today 12:29 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
