    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 12-26-2012, 02:46 PM   #3631
silvalis's Avatar
Trader Rating: 29 (100%+)
Originally Posted by tony montana View Post
Ok good. I'm sweating it since I saw the post on the previous page
If you leave the caps on, it won't fit fully under. Meaning there will be maybe a 7mm gap between the esc and the base of the shock tower. There's no issue really. I ran my VTX10 black cap like this for a couple of months.
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 12-26-2012, 02:49 PM   #3632
Mxer59's Avatar
Trader Rating: 114 (100%+)
What are the part numbers for the alum hinge pin holders that's stock setup for rb6?
No I'm not running mine based off thickness I was told which one to use by a team driver and he referred to it as the beefer one, I installed the smaller one the first time and it did not last the first heat race. The other day I cased a triple broke my rear hinge pin holder and sheered the hinge pin in half along with the right a arm. It's a great car but I have had trouble with broken parts (inner hinge pin, outer houlder, inner holder, front hinge pin brace, & rear arm) I know I'm not the best driver but I've only wrecked it twice, but my track is really beat up right now and is lined with heavy duty schedule 40 3in pipe that does not give, so the car I believe holds up pretty good.
5ive T (Bartoline 28.5cc, Bartoline Pipe, Team Chase)
Futaba 4pls
Team Chase 2015
Rd. 2 TQ-1st--Rd. 3 3rd
Mxer59 is offline   Reply With Quote
Old 12-26-2012, 03:17 PM   #3633
tony montana's Avatar
Trader Rating: 65 (100%+)
so anyone have a link to some indoor setup sheets that are not mid motor? I like running shortys in my 22, how do they seem to work in this car? Still enough rear traction? I will have my rb6 tomorrow evening and will start the build tomorrow as well. First race will be Jan 5th with the car
K.C. Guy. Team Xray - rc america
tony montana is offline   Reply With Quote
Old 12-26-2012, 04:24 PM   #3634
t8rtot's Avatar
Trader Rating: 14 (94%+)
Check out petit rc there are 15-20 on there.
No issue with rear traction.
Sfida
t8rtot is offline   Reply With Quote
Old 12-26-2012, 04:25 PM   #3635
Yeti AS3's Avatar
Trader Rating: 77 (100%+)
http://www.petitrc.com/setup/kyosho/...UltimaRB6.html
Hot Bodies D413
AE B5m
Haigh Designz -Custom Airbrushing
Leisure Hours Hobby and Raceway!!
Yeti AS3 is offline   Reply With Quote
Old 12-26-2012, 04:30 PM   #3636
thanks for all the help so far. Now Im adding spares to my shopping cart now. However I noticed that there isnt many parts at amain and absolute compared to the rb5 parts listed. Do the rb5 and the 6 share some parts? Such as rear axles, shocks and springs and the tranny gears?
Old 12-26-2012, 04:42 PM   #3637
silvalis's Avatar
rear axles are the same, diff is the same, springs are the same (xgear), shock bodies and caps are different, tranny gears are different.
Old 12-26-2012, 04:44 PM   #3638
cool thanks. Anything I need to keep a look out for while doing the build?
Old 12-26-2012, 04:59 PM   #3639
silvalis's Avatar
1) don't mount the steering plate upside down
2) remember to chop the corners off the top front bulkhead as shown.
Old 12-26-2012, 05:27 PM   #3640
also what type of wheel does the 6 use? Same style as the rb5?
Old 12-26-2012, 05:29 PM   #3641
asc6000's Avatar
Trader Rating: 15 (100%+)
same
"you reach the limit, you touch the limit, then you pass the limit, now there is a new limit"
Ayrton Senna
asc6000 is offline   Reply With Quote
Old 12-26-2012, 10:23 PM   #3642
Coach Townsend's Avatar
What is the part number for the shock ends. I
need the longer and middle ones
JESUS CHRIST, KYOSHO AMERICA, BYRON FUEL, PEAK RACING, ORION
Did forget to mention my JOB!!!DAMN THEM TOO!!!
Coach Townsend is offline   Reply With Quote
Old 12-27-2012, 08:49 AM   #3643
t8rtot's Avatar
i know some of you guys think of them as a Basher company for Traxxas products, but STRC just rolled out a nice set of hopups for the car. most notably the rear hub combos for $69.99 at the bottom of the page.
so if you can't wait for Exotek and/or don't want to pay premo for the Kyo parts here you go
http://www.teamstrc.com/index.php?ro...tegory&path=93
Sfida
Old 12-27-2012, 09:12 AM   #3644
offroad dude's Avatar
Trader Rating: 25 (100%+)
Thats actually a great price! Wow
offroad dude is offline   Reply With Quote
Old 12-27-2012, 10:12 AM   #3645
skrichter's Avatar
Send a message via AIM to skrichter
delete
LiveRC.com | Dirt Heaven Hobby & Raceway
skrichter is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
JAE
