    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 12-26-2012, 10:00 AM   #3616
aloksatoor's Avatar
Trader Rating: 42 (100%+)
yeah you should be good to go. The aluminum hinge pin holders are needed as well, get the strc ones if you want regular width or kyosho for wider. If you break your steering rack just order the exotek one.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 12-26-2012, 10:02 AM   #3617
t8rtot's Avatar
Trader Rating: 14 (94%+)
i have not needed the alum holders to date. the new RB6 stock ones are beefed up i'm not the best driver. i haven't seen one break locally out of the 4/5 we have running.
Sfida
t8rtot is offline   Reply With Quote
Old 12-26-2012, 10:07 AM   #3618
aloksatoor's Avatar
I broke em on my rb5 so insurance is always good! .
Old 12-26-2012, 10:19 AM   #3619
Nitronut3's Avatar
Send a message via AIM to Nitronut3
The rb6 ones are waaaayyy more beefed up than the rb5 ones.
Nate Jaskot
XRAY, RC America, KO Propo, Hudy, FX Engines, Nitropro, Rc addiction products , TeamSR, SmacTrac
Nitronut3 is offline   Reply With Quote
Old 12-26-2012, 10:44 AM   #3620
tony montana's Avatar
Trader Rating: 65 (100%+)
The only thing is I'm worried about is my viper vtx10 not fitting with the caps on the esc. I mean its brand new never been in a car yet and viper says no warranty if they are removed or changed
K.C. Guy. Team Xray - rc america
tony montana is offline   Reply With Quote
Old 12-26-2012, 10:58 AM   #3621
t8rtot's Avatar
there is enough room to only have the esc partially under the rear bulk head/ tower, my R10 is only halfway under it. there is plenty of room.
Sfida
Old 12-26-2012, 11:05 AM   #3622
Ok good. I'm sweating it since I saw the post on the previous page
Old 12-26-2012, 11:11 AM   #3623
t8rtot's Avatar
i'll post a picture when i get home later.
Sfida
Old 12-26-2012, 11:51 AM   #3624
fastestwon's Avatar
Trader Rating: 15 (94%+)
Default viper esc
here is my revention pro with power cap on top . if you are going to use shorty packs no problem
fastestwon is offline   Reply With Quote
Old 12-26-2012, 12:19 PM   #3625
t8rtot's Avatar
AND thats mid motor... in rear, we have an extra inch or inch 1/2..
Sfida
Old 12-26-2012, 01:12 PM   #3626
Weazsel's Avatar
Trader Rating: 57 (100%+)
Originally Posted by MrHistory View Post
I am trying a setup that calls for "Narrow blocks in rear hinge pins"
I started going through my car and parts bag. I'm totally confused because I have 2 blocks marked RF2. I assume the less beefy one is from the RB5...
Do I use the RF block and the narrow rear rear part? The narrow rear rear block is also less beefy and on the diagram it is greyed out indicating its not for this kit???
Someone please explain and maybe even tell me which parts in the diagram I should use.
Thx
RF block goes with the narrow block and RF2 goes with the wider block. As long as the front block says "RF" and the rear block is the shorter or narrower of the two you're good to go.
Originally Posted by Mxer59 View Post
Make sure to use beefer Rf2 or you'll be changing it out again mine broke not even hitting anything, for the rear I use the RB5 one in box as that's what a team Kyosho driver showed me to do along with no shim under the blocks
I hope you're not running your blocks based on thickness or "beefierness" are you?
The only thing I've broke on this car was the rear suspension block. This was a result of my rear tire hitting a concrete well that I shouldn't have hit at full speed. This is the only thing I've broken on my RB6 so far. You are securing a plastic block to a metal chassis, the plastic is going to give most likely every time. I'm running the gunmetal aluminum ones from the RB5 which are the same, problem solved. My SETUP calls for the Aluminum RF and Aluminum narrow block.
Part No. UMW512GM and UMW511GM
Originally Posted by KSimmonds View Post
*If* you have issues with breaking the rack snag the Exotek alum. version. They make the bellcranks as well. I haven't seen many racks break in my area though.
I read often that people "hear" that the rack breaks. There's about 15 people running RB6's at my local track and I haven't seen ONE person break it. Maybe it's different layouts and skill sets that factor in...
Michael Garramone
Serpent America l Desoto Racing l Pro-Line l Picco l Arrowmax l TQ Wire
Weazsel is offline   Reply With Quote
Old 12-26-2012, 01:19 PM   #3627
Default New layout...
I thought I would try some new stuff for the last race of the year...new electronics layout and shortie as well as some mods I picked up from here. I also used some titanium that I had from other cars and my RB6 with this setup weights 1595gr...not bad
And yes the esc WILL fit under the rear tower in RM configuration no matter which battery layout you use (my esc is ORCA btw)...I even managed to fit the capacitor behind the esc!
[IMG][/IMG]
nitroargi is offline   Reply With Quote
Old 12-26-2012, 01:55 PM   #3628
Trader Rating: 18 (100%+)
This is the same case here. My wife is now driving a 6 and she isn't exactly a precision driver just yet, but she hasn't broken anything with the car box stock. The only thing I broke was a rear camber plate and that was definitely my fault clipping a tube at the end of a very high speed straight and flipping 20 times right into the wall. I can't believe that's the only thing that broke...
KSimmonds is offline   Reply With Quote
Old 12-26-2012, 02:04 PM   #3629
Super Moderator
Trader Rating: 17 (100%+)
welcome to the Red Army!
This tempted me to get a RB6 and every time I peel someone on the track just scream FOR MOTHER RUSSIA from the driver's stand
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is online now   Reply With Quote
Old 12-26-2012, 02:21 PM   #3630
t8rtot's Avatar
do it! do it! do it! do it! do it! do it!
Sfida
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
