    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 12-25-2012, 11:44 AM   #3601
Mxer59's Avatar
Trader Rating: 114 (100%+)
Make sure to use beefer Rf2 or you'll be changing it out again mine broke not even hitting anything, for the rear I use the RB5 one in box as that's what a team Kyosho driver showed me to do along with no shim under the blocks
Originally Posted by MrHistory View Post
I am trying a setup that calls for "Narrow blocks in rear hinge pins"
I started going through my car and parts bag. I'm totally confused because I have 2 blocks marked RF2. I assume the less beefy one is from the RB5...
Do I use the RF block and the narrow rear rear part? The narrow rear rear block is also less beefy and on the diagram it is greyed out indicating its not for this kit???
Someone please explain and maybe even tell me which parts in the diagram I should use.
Thx
5ive T (Bartoline 28.5cc, Bartoline Pipe, Team Chase)
Futaba 4pls
Team Chase 2015
Rd. 2 TQ-1st--Rd. 3 3rd
Mxer59 is offline   Reply With Quote
Old 12-25-2012, 11:55 AM   #3602
RodneyB's Avatar
The original RF is fine if you want to go narrow. It is not thin like the original RF2.
Kyosho America; Peak Racing; Grandview Hobbies; CRCRC
CRCRC club administrator
Kyosho RB6, Kyosho ZX6, Kyosho SC6, Kyosho MP9e TKI
RodneyB is offline   Reply With Quote
Old 12-25-2012, 12:45 PM   #3603
jwood7's Avatar
Originally Posted by toast. View Post
Looking at replacing my RSXResponse (65.6g) with a RSXone 10 (51.0g), so that i can use the Response in a touring car.
Is the RSXone 10 a good choice?
It's a good servo but IMO its a bit underpowered running throu the esc. I made the jumper and run mine at 7.4 and it's much better
jwood7 is offline   Reply With Quote
Old 12-25-2012, 02:45 PM   #3604
MrHistory's Avatar
Thanks Guys.
I will use the RF block, and the narrower rear block in the bag. This part is not labelled with a part# in the RB6 manual. I guess this is what you are calling the RB5 RR part?
Irwin RC 1/8th Pan Car Specialists - www.irwinrc.com
SPM Competition, WRC Racing, MIP, Novarossi
MrHistory is offline   Reply With Quote
Old 12-25-2012, 03:19 PM   #3605
tony montana's Avatar
Trader Rating: 65 (100%+)
ok still thinking about the rb6 and the b4. Biggest reason Im still thinking is I dont believe my local track carries kyosho parts but carries tons of associated parts. Thats the reason I keep asking about durablity, meaning I will have to order every thing basically online.
K.C. Guy. Team Xray - rc america
tony montana is offline   Reply With Quote
Old 12-25-2012, 04:03 PM   #3606
Trader Rating: 18 (100%+)
Durability on the car is good. I wouldn't hesitate to get one even if my local track didn't carry Kyosho stuff. In fact, so far all they carry is arms for the RB6, so with some careful planning and purchasing of typical spares you should be all set. Of course there is always a chance you might break something you can't get without ordering..... It's a risk I am willing to take
Ctimrun is offline   Reply With Quote
Old 12-25-2012, 04:10 PM   #3607
What I have broken and how....top plate sent it off a huge triple easily 8tt of air and 25 ft wide. Colliding with a sc in the air. Front spindle same jump over shot by a few feet landed on left front wheel. So basically all the weight of the car hit it. Turnbuckles I have snapped 2 replaced them with the larger 22 turnbuckles. A rf block but it was because I used the thin one. Replaced it with the stock thicker one and have had no problems. Rear arm going full wood down the straight and caught a pipe coupler. Any arm would have broken....durability I give it an A+ as I'm very hard on my cars and run mod so everything hits faster and harder.
Gitsum is offline   Reply With Quote
Old 12-25-2012, 05:00 PM   #3608
t8rtot's Avatar
Trader Rating: 14 (94%+)
Durability is really a none issue. Even if you have parts at your LHS should still have a few basic parts on hand, do that but still won't need them.
I don't know if any shop with in 100mi that carries a kyo part or car. And there are more RB5/6s than Losi's which our lhs has plenty of stock for.
Sfida
t8rtot is offline   Reply With Quote
Old 12-25-2012, 05:19 PM   #3609
305M3's Avatar
Trader Rating: 40 (100%+)
What I've broken (all hard crashes or someone crashing hard into me):
Front bearing carrier (my fault - pipe hanger on front straight)
Rear hinge pin holder, RF2 (my fault - pipe hanger on front straight)
Rear hub (as* clown wiped me out on front straight)
I own Kyosho for 1/8 nitro bug and trug + the RB6. I have a ton of parts that I fortunately/unfortunately have stocked up...
305M3 is offline   Reply With Quote
Old 12-25-2012, 07:38 PM   #3610
Any issues fitting a viper vtx10 in the car?
Old 12-25-2012, 07:46 PM   #3611
t8rtot's Avatar
I have an r10 which is similar in size not an issue.
Go to petit rc and you'll see a ton of different installs.
Sfida
Old 12-26-2012, 01:13 AM   #3612
silvalis's Avatar
Trader Rating: 29 (100%+)
If you plan on jamming it underneath the bulkhead in RM, you'll need to remove the caps. Unless it's a BE.
I removed mine (vtx10, black caps) and put one of those narrow 4X cap sets from HW on, stuck it on the chassis between the battery and the plastic sideguard. Unfortunately I'm on holiday and don't have a pic for you. Black caps version will only fit partially under. I ran it like that for a few months, no issues, changed it anyway. Silver caps should fit further underneath, but not fully.
I haven't broken anything on my buggy yet. Cleaned someone up as they drove onto the middle of the straight from the side, no breakages. Done a few cartwheels, haven't broken the rear hubs yet. Still haven't broken the steering plate like everyone else seems to have done...
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 12-26-2012, 09:53 AM   #3613
Well I just ordered the rb6 hope I made the rightdecision. Also ordered a spare steering rack thing as I hear its a weak part
Old 12-26-2012, 09:55 AM   #3614
*If* you have issues with breaking the rack snag the Exotek alum. version. They make the bellcranks as well. I haven't seen many racks break in my area though.
KSimmonds is offline   Reply With Quote
Old 12-26-2012, 09:58 AM   #3615
t8rtot's Avatar
you made the best decision! welcome to the Red Army!
we're all here for whatever questions you may have.
Sfida
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22957 09-22-2017 12:16 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
