    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 12-18-2012, 04:59 PM   #3481
ChadB.'s Avatar
Trader Rating: 21 (100%+)
Can anyone tell me what Cody Turner's current indoor setup is. Thanks!
Chad Burdick
*Mugen Seiki*Flashpoint Racing Products*9th Annual Timezone Grand Prix July 13th-16th 2017*Unique Air Design*TimezoneRacing*RoseCityScaleRacers* Daves RC Track
ChadB. is offline   Reply With Quote
Old 12-18-2012, 09:23 PM   #3482
B00t13g's Avatar
To anyone running avid 4x1.3 pistons. What oil/ springs are you running?
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 12-18-2012, 10:58 PM   #3483
OnRDPassion's Avatar
Trader Rating: 54 (100%+)
I tried these out with Losi 27.5 wt with gold springs in the rear and they worked pretty well at my local track. I however prefer the 2 1.6 x 2 1.1 avid pistons with that same oil / spring combination.
OnRDPassion is offline   Reply With Quote
Old 12-18-2012, 11:00 PM   #3484
B00t13g's Avatar
27.5 all around on both? I assume pink front gold rear? Any big features?
Mackenzie Meyercord
Old 12-19-2012, 05:20 AM   #3485
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
Another goodie from Exotek.
http://www.exotekracing.com/rb6-rear-camber-plate-rm/
kwiksi is offline   Reply With Quote
Old 12-19-2012, 05:47 AM   #3486
x7tristan's Avatar
i put my rb6 on setup stands and it looks like out of the box the rear toe is -3degrees, can anyone else confirm this?
And the only way to adjust the rear toe is with the optional aluminum rear hubs (no suspension holder inserts like the fs2 sp)?
TJ
DURANGO DESC410R
x7tristan is offline   Reply With Quote
Old 12-19-2012, 06:57 AM   #3487
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
Well, you could technically adjust it by using the RF and RF2 pivot blocks. I dont know what running a front RF2 and rear RF would leave you with though. We adjust the hubs, but the most I've run is .5
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 12-19-2012, 07:09 AM   #3488
eper's Avatar
Trader Rating: 14 (100%+)
if you run the different rf blocks to adjust toe you will get excess outdrive wear and the car will be unpredictable on corner entry and exit due to the angle change where the bone and the outdrive meet. best bet is to use the hubs. IMHO
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 12-19-2012, 10:33 AM   #3489
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Originally Posted by kwiksi View Post
looks very cool!! Gonna place a order from exotek for a few parts!
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 12-19-2012, 10:36 AM   #3490
MrHistory's Avatar
Can someone recommend a pinion gear size. I built the car box stock with stock slipper gear and will run 17.5 class on a medium size indoor clay track.
Irwin RC 1/8th Pan Car Specialists - www.irwinrc.com
SPM Competition, WRC Racing, MIP, Novarossi
MrHistory is offline   Reply With Quote
Old 12-19-2012, 10:46 AM   #3491
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
What motor?
How much end bell timing?
Blinky class?
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 12-19-2012, 11:13 AM   #3492
Sorry about that I should have been more clear on that. I am using the 27.5 in the rear with gold springs and in the front I am using 5 hole with losi 35 wt and pink springs. Overall that setup has seemed to be very balanced for me on the current high speed setup my track is running right now.
Old 12-19-2012, 11:43 AM   #3493
MrHistory's Avatar
we have a 17.5 open class so i will start with blinky but have the option for boost.
i will be using the orion pro esc and 17.5 motor combo. no motor timing mod.
thanks
Old 12-19-2012, 12:28 PM   #3494
Mxer59's Avatar
Trader Rating: 114 (100%+)
Looking for a gearing for 13.5 Orion VST paired with Orion R10 Esc I run AE spurs.
On my 17.5 I ran 72/31
5ive T (Bartoline 28.5cc, Bartoline Pipe, Team Chase)
Futaba 4pls
Team Chase 2015
Rd. 2 TQ-1st--Rd. 3 3rd
Mxer59 is offline   Reply With Quote
Old 12-19-2012, 12:35 PM   #3495
CanyonCarverR1's Avatar
thanks
To get proper gearing for 17.5 on a medium size indoor clay track, I installed a Kimbrow brand 69T spur for the Associated B4(must also use Assoc. slipper pads), and around 32T - 34T pinion.
CanyonCarverR1 is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
