    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree17Likes
Old 12-18-2012, 12:25 AM   #3466
K_King's Avatar
Trader Rating: 39 (100%+)
Send a message via AIM to K_King
Make sure to check your outdrives :P
http://farm9.staticflickr.com/8074/8...641d6b57_b.jpg
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 12-18-2012, 04:52 AM   #3467
Lonestar's Avatar
if you flip the diff to have the wear in the off-throttle position, you're degrading the off-throttle handling...
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 12-18-2012, 04:52 AM   #3468
Lonestar's Avatar
WOW
Old 12-18-2012, 05:59 AM   #3469
that's what mine looked like......
Did you see my "possible" solution a couple pages ago????
R
RonBegeot is offline   Reply With Quote
Old 12-18-2012, 06:59 AM   #3470
aloksatoor's Avatar
Trader Rating: 42 (100%+)
R
right mine dont look that bad at all on really high grip indoor clay. My arms are not shimmed tight, about ~0.3 mm play back and forth on the hinge pin holders and not much on the hub for the rear arms.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 12-18-2012, 07:20 AM   #3471
K_King's Avatar
I have had two set of outdrives actually chip and chunk away on the breaking side in the last two weeks. Never have had this happen in three years of owning 6 different kyosho buggies. After 2 packs the third set had paint chips missing already so several "100%" team drivers looked at my setup and suggested my rear arms were shimmed too tight. The thought was the dogbone had no play in its angle and was slamming the outdrive too directly.
Hope this suggestion helps as this was beyond a normal "wear item" fo sure.
R
I have some play on my arms. I've talked to a few guys and they think Tisza material issue where it's either too soft or the pins are too hard.
Old 12-18-2012, 07:41 AM   #3472
Well I don't think the pins are to hard as they get flat spots quickly. But diff out drives chipped on my zx5 fs2sp first race day. Replaced them with a spare set and its been a year and no chips...
Tom87 is offline   Reply With Quote
Old 12-18-2012, 07:47 AM   #3473
t8rtot's Avatar
Trader Rating: 14 (94%+)
I know kyosho has had am issue with these on there 8th scales with over hardening them.
They seem to fix it with the next batch. I'm running stock and have not had an issue
Sfida
t8rtot is offline   Reply With Quote
Old 12-18-2012, 07:53 AM   #3474
t0p_sh0tta's Avatar
Trader Rating: 35 (100%+)
On all of my K cars (RT5, RB5 and SC) the stock outdrives wore very quickly. The replacements always seemed to hold up forever though.
I've met some of the strangest people while playing with my toy cars...
t0p_sh0tta is offline   Reply With Quote
Old 12-18-2012, 08:02 AM   #3475
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
R
I don't want other readers to be confused.. but out drives worn that badly need to go in the garbage. (they should of been in the garbage a LOOONG time ago).
I was recommending swapping around the diff and swing shafts per-emptivly to smooth out wear on both sides. Once the wear mark even STARTS to get a notch, they are due for replacement.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 12-18-2012, 08:13 AM   #3476
fullsyzz's Avatar
Trader Rating: 103 (100%+)
Mine look like that too. Lame.
fullsyzz is offline   Reply With Quote
Old 12-18-2012, 03:46 PM   #3477
MrHistory's Avatar
for the outdrives and cvds, do you guys use grease? Specifically which kind?
Some nitro onroad racers only use bearing oil and apply it each run as it does not gather dirt.
Please inform.
Irwin RC 1/8th Pan Car Specialists - www.irwinrc.com
SPM Competition, WRC Racing, MIP, Novarossi
MrHistory is offline   Reply With Quote
Old 12-18-2012, 04:09 PM   #3478
asc6000's Avatar
Trader Rating: 15 (100%+)
Please inform.
In the "joint" itself very little grease and generally the "kit" stuff. No grease is typically used in the slots of the drives or on the pins however I have seen it done. It takes a ton of driving to wear out pins it's not a concern to me. Chipping Iv'e had was not wear related.
"you reach the limit, you touch the limit, then you pass the limit, now there is a new limit"
Ayrton Senna
asc6000 is offline   Reply With Quote
Old 12-18-2012, 04:28 PM   #3479
eper's Avatar
Trader Rating: 14 (100%+)
i never had a premature wear problem with the outdrives or the pins or the cvds in any of my k cars. i also run my cars more then the average person. the only thing i ever use to lubricate my cvds and out drives is mothers California gold car wax. it keeps things moving freely and tends to not collect alot of dirt. i just apply it reassemble the parts and let the excess spin off by itself. the only outdrives that i have chipped are the fronts on my 4wd when i over flex the arm do to a ruff landing and pop out a bone.
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 12-18-2012, 04:45 PM   #3480
Super Moderator
Outdrives and swingshaft pins have always worn really FAST for me on my K cars... They wear 2 or 3 times faster than my AE cars.
- RCSpecialties -
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22970 10-17-2017 05:10 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
