    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 12-14-2012, 09:15 AM   #3361
Kooz's Avatar
Originally Posted by BranVita View Post
Anyone else running chassis protectors on the 6?
If you are, what are you guys using?
Scotchrap 51 tape - 20 mils
Bought a 4" X 100ft. roll on eBay for just over $30 shipped. Thats about .33 cents a wrap. Last forever! LOL
I also made a template file of the chassis and had it laser cut out of aluminum for a useable template. That way I can just stick it on the aluminum template and cut it out with an exacto then transfer. Allot easier then using the mounted chassis to cut it out.
Last edited by Kooz; 12-14-2012 at 12:36 PM. Reason: Changed Scotchrap 50 to 51... My bad! :(
Kooz is offline   Reply With Quote
Old 12-14-2012, 09:19 AM   #3362
cheROK1212's Avatar
...hold my 'stones.
cheROK1212 is offline   Reply With Quote
Old 12-14-2012, 09:30 AM   #3363
Hi guys...
I got the new Triad slipper to try and I noticed that the included spurs are 81 and 84...I run an ORCA 8.5 motor which I prefer overgeared (23/76)...should I order the optional Avid 75 spur or use 81 with a really bigger pinion???
I mean I could probably get the final drive ratio more or less the same (24/81!!!) but the balance of the car will be different...
nitroargi is offline   Reply With Quote
Old 12-14-2012, 09:41 AM   #3364
Trader Rating: 24 (100%+)
I run a carpet track occasionally that requires chassis protectors. I have had quite a bit of success with mine. I get 5-10 races out of them before I change to a different design. I had a decal made out the same material for20+ races on the bottom of my sct truck that i just recently changed out because I went with a new color. Feel free to pm if your interested in some.
goodhews is offline   Reply With Quote
Old 12-14-2012, 10:15 AM   #3365
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by Kooz View Post
Scotchrap 50 tape - 20 mils
That's what I use, works flawlessly and is painfully cheap. SUPER durable, and can be restuck dozens of times. As a matter of fact, I just pealed off the very first one I cut for my RB6 build... it was still perfectly fine too. Iv used the same roll for all my cars (and my wife's) over the last 2 years, and the roll still looks unused.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 12-14-2012, 10:37 AM   #3366
Fusiongraphix's Avatar
Trader Rating: 41 (100%+)
it just depends on if you want to go plain black or if you want to get a matching design! anything works.
I just wanted to throw out the options of what i can do. of course a printed / contoured cut one is going to be more money. The RC industry is "ALOT" about looks and a matching chassis protector that works is a pretty cool attention getter.
just depends on if you want to spend the extra money. you get what you pay for.
I'll post pics of my RB6 later tonight when I have some time.
Fusion Graphix, LLC
www.FusionGraphix.com
Fusiongraphix is offline   Reply With Quote
Old 12-14-2012, 10:49 AM   #3367
TT_Vert's Avatar
Trader Rating: 68 (100%+)
WHere are you guys finding that 20 mil unprinted scotchrap in 4"? I only see a quantity of 4 and 12 in 10mil .
ThankS
Dave
TT_Vert is offline   Reply With Quote
Old 12-14-2012, 11:28 AM   #3368
aloksatoor's Avatar
Trader Rating: 42 (100%+)
ThankS
Dave
amazon
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 12-14-2012, 11:37 AM   #3369
TT_Vert's Avatar
Originally Posted by aloksatoor View Post
amazon
All I see there is 10 mil in the 4" thickness in 50 and 51. Not sure what I'm missing here.
Dave
Old 12-14-2012, 11:50 AM   #3370
Jerad8's Avatar
Trader Rating: 104 (100%+)
Dave
It appears Scotchrap 50 is 10mil thick and Scotchrap 51 is 20mil thick. So for 4"x 100' of Scotchrap 51 un-printed 20mil thick for about $57 on Amazon: http://www.amazon.com/3M-Scotchrap-A.../dp/B005YSMZBA
Let me know if anyone knows where to find it cheaper.
Jerad8 is offline   Reply With Quote
Old 12-14-2012, 12:34 PM   #3371
Kooz's Avatar
ThankS
Dave
This is a screen shot of the auction where I got mine a couple of weeks ago...
Old 12-14-2012, 04:40 PM   #3372
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
So after running Durango stuff for a year...can't decide between the RB6 and the Cougar SVR.... What's this buggy like compared to the others out there?
Does it come with carbide diff balls?
What are the weak parts on the buggy?
kwiksi is offline   Reply With Quote
Old 12-14-2012, 05:02 PM   #3373
fastestwon's Avatar
Trader Rating: 15 (94%+)
yes carbide diff balls the only weak part is the driver the car is solid
fastestwon is offline   Reply With Quote
Old 12-14-2012, 05:05 PM   #3374
aloksatoor's Avatar
You get what you pay for. Get the rb6 . Still have schumacher stuff but I prefer everything in the kyosho , I mean everything(the rb5 in some ways was lacking compared to the svr).
Chassis - svr cheap stamped aluminum easily dented mine on the sv2, rb6 - machined 7075 which hardly scratches
Shocks - no comparison box stock k shocks are better than others with all the bells and whistles
Fit and finish - about equal with schumacher being more brittle
Diff - pain in @$$ to build the schumacher but comparable to the kyosho when done right
Wheels - schumacher still has the old style pin wheels and bearings up front
Old 12-14-2012, 05:28 PM   #3375
Super Moderator
There is nothing on/in the SVR that is better than the RB6... That being said, the SVR (and schumacher stuff in general) is fantastic, so is overall schumacher fit, finish and quality. The shumacher diff isn't as nice as the tried and true kyosho, but the shocks are really close.
The main difference between the two will be local support and parts. If you are looking for which car would have the edge, I am guessing you can expect a bit of a bias opinion on this thread.
The only parts on the RB6 (or 5, for that matter) That are a must have for durability reasons, are aluminum rear suspension hangers. Everything else on the car is absolutely top shelf.
(edit, there is one thing that is far better with schumacher.. Manual and bag packaging for the build. Schumacher is #1 there)
- RCSpecialties -
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22957 09-22-2017 12:16 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
