    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree25Likes
Old 12-13-2012, 09:39 AM   #3331
sparkwraps's Avatar
Trader Rating: 34 (100%+)
Sweet! Looks great mounted up!
Originally Posted by BranVita View Post
New JC body painted up by Aflac Designs
| AFLAC Designs - Custom Airbrushing, in a hurry! | Jakes RC Pro Am - Topeka's Indoor Offroad Track! |
sparkwraps is offline   Reply With Quote
Old 12-13-2012, 09:41 AM   #3332
What shim is being used up front between the bulkhead and chassis? The .5 or ?
Gitsum is offline   Reply With Quote
Old 12-13-2012, 09:42 AM   #3333
John.C's Avatar
Trader Rating: 36 (100%+)
Originally Posted by Cpt.America View Post
Trying my damnest to not use the laughing out loud icon .
I think the ROTFLMAO emoticon would be more appropriate. I can laugh about it now but it sure wasn't funny last night when I discovered my bone headed mistake. I sat there for awhile just looking at the pieces in disbelief. So you think I'll see a 'night a day' difference between running 0 degree rear toe vs 3 degree? Good times!!!
- Middle River Hobbies - The Track -
John.C is offline   Reply With Quote
Old 12-13-2012, 09:55 AM   #3334
t8rtot's Avatar
Trader Rating: 14 (94%+)
i think alot of guys are not using one at all.
i've seen a few setup sheets using the .5
i'd be interested in hearing what exactly the adjustment does.
Sfida
t8rtot is offline   Reply With Quote
Old 12-13-2012, 10:03 AM   #3335
offroad dude's Avatar
Trader Rating: 25 (100%+)
I was wondering what is a good starting point for a Tekin 9.5 with the stock spur?
offroad dude is offline   Reply With Quote
Old 12-13-2012, 10:08 AM   #3336
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
I'm not sure, you may be the first guy to have done it! I can just see your expression on the driver stand now, the first day you drove the car....
"Man they weren't kidding.. this car is AGGRESSIVE!!!"
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 12-13-2012, 10:22 AM   #3337
ChadB.'s Avatar
Trader Rating: 21 (100%+)
How are most people spacing the front hubs? Inside or outside? I have mine on the outside and it is overly agressive.
Chad Burdick
*Mugen Seiki*Flashpoint Racing Products*Daves RC Track*
ChadB. is offline   Reply With Quote
Old 12-13-2012, 10:48 AM   #3338
Super Moderator
You mean the caster blocks? If you run the hole towards the inside, it will push the caster bock outside (wider track). If you run the hole towards the outside, it will push the caster block inside (skinnier track). Skinnier track will provide more steering, wider track less. That setting alone will not by itself make the car noticeably aggressive.
I run a wide front track to help tame some of the steering (box setting).
- RCSpecialties -
Old 12-13-2012, 11:03 AM   #3339
What up?'s Avatar
Trader Rating: 14 (100%+)
I have a buddy that just put one in and he is running 76/25 on a large indoor track but he was still testing. I would say start there and do the usuall temp after 2 minutes until you have it where you want it.
Josh Mitchell
Speedtechrc.com / Team Orion USA / Airtronics / Proline / Bartalone Racing / rcinsider.com / 818Designs
What up? is offline   Reply With Quote
Old 12-13-2012, 01:52 PM   #3340
Thanks, I put a 23 on there and it was a turd. I hell the motor didn't even get warn.. and I didn't feel like going to buy a hand full of pinions to try..
Old 12-13-2012, 06:21 PM   #3341
Energyzer's Avatar
Guys, i'm running full size lipos, with my ESC on top of the back battery holder. It's not the best place to put it since the wires touch the body, but i couldn't find any other place.
My question is: what's the difference in terms of feeling with the shorty or saddles instead of a full size batt? I know we get more steering with the batt forward mounted or the rear more planted with the batt mounted on the back, but aren't shorties and saddles a bit too light?
Cheers
Energyzer is offline   Reply With Quote
Old 12-13-2012, 07:08 PM   #3342
Mxer59's Avatar
Trader Rating: 114 (100%+)
Cheers
I love my Shortys in the car feels very nimble, I run mine towards rear car feels so planted and in control. I already have enough steering for my driving. I run a Tekin rs so its mounted in the little hole by tranny reciver fits perfectly in between my servo and batt mount.
5ive T (Bartoline 28.5cc, Bartoline Pipe, Team Chase)
Futaba 4pls
Team Chase 2015
Rd. 2 TQ-1st--Rd. 3 3rd
Mxer59 is offline   Reply With Quote
Old 12-13-2012, 07:10 PM   #3343
Mxer59's Avatar
Im running kit recommend setting and kit springs whats a good suspension setup? Right now im running 35fr 30rr.
Should I get stiffer springs?
Futaba 4pls
Team Chase 2015
Old 12-13-2012, 08:00 PM   #3344
ChadB.'s Avatar
Yes, the Castor block is what I am referring to. At the moment I have the front end wide and it is really aggressive. A bit to much. The reason I ask is because I want to tame the steering down so it isn't overly twitchy, so I was thinking of shortening the width. In the past with the RB5 when I have gone to a wider front end, it made the steering more aggressive.
Chad Burdick
Old 12-13-2012, 09:45 PM   #3345
K_King's Avatar
Trader Rating: 39 (100%+)
Send a message via AIM to K_King
Don't move the arms forward 2mm, move them 1.5x mm forward. At 2mm, the arms actually hit the chassis. Just barely, but they do. I have arms shimmed forward 1.5mm, and my hubs in the middle, and the car was a LOT better. didn't lose any steering, but the rear end was just a hair more planted on landings and on-throttle.
Hmm I will have to check that out, is it hitting at the pivot?
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22977 11-13-2017 05:09 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15026 11-02-2017 04:19 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 09:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 05:30 PM
