    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 12-11-2012, 10:20 PM   #3301
fastestwon's Avatar
Trader Rating: 15 (94%+)
Originally Posted by Ctimrun View Post
I must be missing something as to why your going through all the trouble to use long ball cups cut off etc etc. My battery is setup like yours with the parts from the kit. The kit included parts to set it up just like that.
my bad i didn't realize that . when i first setup my car it was in RM using a long pack
fastestwon is offline   Reply With Quote
Old 12-12-2012, 12:36 AM   #3302
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
Originally Posted by cnelson3 View Post
the hinge pins that connect the toe blocks have a 2 mm spacer in front of the arms standard. King posted a set up sheet that showed that he put the 2mm spacer behind the arms on those hinge pins thereby moving the arms forward. Not talking about the hub placement at all. I'm interested in what this will do. I have a feeling about what is going to happen but i want to give it a shot.
It works the same as moving hubs forward, its just more of a direct adjustment, while the hub version is more of a tweak. You should see a pretty big change, more than moving just hubs forward. Forward biiiiiiiiite
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 12-12-2012, 02:34 AM   #3303
pli
Originally Posted by silvalis View Post
3) If you get aluminium rear suspension hangers, get the white delrin ball ends.
I've looked around but failed to figure out which white delrin ball ends you are referring to. Do you have a link or parts number for those?
Thanks a lot!
pli is offline   Reply With Quote
Old 12-12-2012, 03:35 AM   #3304
carcrusher46's Avatar
Trader Rating: 17 (100%+)
Thanks a lot!
LAW32 is the part number:
http://www.kyoshoamerica.com/SP-Susp...ZX_p_3690.html
Matt Stoltz
Thank you to my sponsors:
Team Associated - Reedy - JConcepts - Life Fast RC Paintworks
carcrusher46 is offline   Reply With Quote
Old 12-12-2012, 04:55 AM   #3305
B00t13g's Avatar
Ill be trying this today!!
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 12-12-2012, 07:15 AM   #3306
MrHistory's Avatar
Is this the Turnigy Battery you have?
http://www.hobbyking.com/hobbyking/s...dProduct=28647
Please let me know how it is. I was going to get an Orion shorty pack but dont know if it is worth the cost.
Irwin RC 1/8th Pan Car Specialists - www.irwinrc.com
SPM Competition, WRC Racing, MIP, Novarossi
MrHistory is offline   Reply With Quote
Old 12-12-2012, 07:44 AM   #3307
Mxer59's Avatar
Trader Rating: 114 (100%+)
I have two of these because the cost is so great, they work great for me always balance correctly plenty of power. The only con I have is the case if you push on side flexes a little, I wrapped some electric tape on both ends to keep it from splitting if it ever became a issue.
5ive T (Bartoline 28.5cc, Bartoline Pipe, Team Chase)
Futaba 4pls
Team Chase 2015
Rd. 2 TQ-1st--Rd. 3 3rd
Mxer59 is offline   Reply With Quote
Old 12-12-2012, 08:22 AM   #3308
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
So the RB6 is now better than ever... I made some small changes and put down some great consistent laps with it, enough to qualify in 2nd in the A-main and finish 2nd in the A-main at Team AE driver Scott Brown's Tacoma RC Raceway last night, where overall competition is top shelf, second to none. We had enough for a C main in 17.5 last night, and I just wanted to share with you our A-main qualifying grid... I can't say I have ever seen this close of racing at the club level EVER. The entire A-main field, from top to bottom, is separated by 7 seconds total, exactly 1 second per position. This is how tight and competitive the racing is at Tacoma.
Brian Autry was able to squeeze out a flawless run in qual #2 and just squeeze into the 20s by the skin of his wing... I hit ONE snag on back traffic that held me up for about a full second that put me into the #2 slot. After qual #1, we were .1 second apart in qualifying.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 12-12-2012, 09:16 AM   #3309
Super Moderator
Don't move the arms forward 2mm, move them 1.5x mm forward. At 2mm, the arms actually hit the chassis. Just barely, but they do. I have arms shimmed forward 1.5mm, and my hubs in the middle, and the car was a LOT better. didn't lose any steering, but the rear end was just a hair more planted on landings and on-throttle.
- RCSpecialties -
Old 12-12-2012, 10:13 AM   #3310
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Originally Posted by Cpt.America View Post
So the RB6 is now better than ever... I made some small changes and down some great consistent laps with it, enough to qualify in 2nd in the A-main and finish 2nd in the A-main at Team AE driver Scott Brown's Tacoma RC Raceway last night, where overall competition is top shelf, second to none. We had enough for a C main in 17.5 last night, and I just wanted to share with you our A-main qualifying grid... I can't say I have ever seen this close of racing at the club level EVER. The entire A-main field, from top to bottom, is separated by 7 seconds total, exactly 1 second per position. This is how tight and competitive the racing is at Tacoma.
wow thats a close match up! do you have the setup posted somewhere?
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 12-12-2012, 10:51 AM   #3311
Super Moderator
Nope, not yet... still a work in progress... have new pistons coming in the mail today, and just got my new Fantom shorty packs yesterday (ran them for the first time last night, and WOW)... so I want to nail down a solid setup before I post it. I just don't know the car well enough at this point. Don't want to send somebody down the wrong path.
- RCSpecialties -
Old 12-12-2012, 11:03 AM   #3312
What is better for high speed steering 25/0 or 30/0?
Gitsum is offline   Reply With Quote
Old 12-12-2012, 11:04 AM   #3313
aloksatoor's Avatar
Originally Posted by Gitsum View Post
What ism better for high speed steering 25/0 or 30/0?
I use 25 never touched that setting even in the 5.
Old 12-12-2012, 11:33 AM   #3314
fullsyzz's Avatar
Trader Rating: 102 (100%+)
I tried this flipping the steering rack trick I found on Petit/Oople and it made the car easier to drive for me.
fullsyzz is offline   Reply With Quote
Old 12-12-2012, 11:41 AM   #3315
Pics?
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22939 Today 01:36 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
