    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree17Likes
Old 12-10-2012, 10:33 AM   #3271
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Originally Posted by x7tristan View Post
I haven't had the chance to run my RB6 yet, so I was wondering if anyone has had issues with wiring the battery connectors right over the receiver? I'm wondering if doing so will cause some interference.
Nothing should happen. Mines wired the same way. If your using analog receivers then might cause issues not with the 2.4 though. I see you are also running sweep tires, I like them the droids
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 12-10-2012, 12:43 PM   #3272
mdowney's Avatar
Trader Rating: 21 (100%+)
Originally Posted by goin2drt View Post
The other thing to note was the spur size. I have been running 76/21 and when I purchase my Triad I could not get the 76 so I had to go with 75. That took a little adjusting and I did not have time to get it perfect for me by the end of the night. I ended up at 76/23 but I still don't like it.
If you are running a 17.5 motor I would recommend gearing 69/31-32. Avid makes a 69T spur for the triad. Depending on your motor and the track layout you'll want to adjust the pinion. Smaller for more torque, which is generally better for more technical layouts with a lot of 180s and short run-ups to jumps.
If you're not running a Triad slipper you can just use an AE/Kimbrough spur with the AE slipper pads.
Mike Downey
I try all of the RC kits and usually race at Tacoma RC Raceway
mdowney is offline   Reply With Quote
Old 12-10-2012, 12:56 PM   #3273
Trader Rating: 77 (100%+)
Running 7.5 mod (reedy) motor. I was at 21/76 with the K slipper. Couldn't get a 76 triad so had to go to 75.
TRF 418 - Team Powers 17.5, HobbyWing Stock Spec, Xpert servo
Xray T4 2016 - Trinity D4, HobbyWing Stock Spec, Ko Propo servo and radio
KustomRCGraphics.com (Best looking novice on the track)
goin2drt is offline   Reply With Quote
Old 12-10-2012, 01:10 PM   #3274
John.C's Avatar
Trader Rating: 36 (100%+)
I ran my RB6 for the first time this past weekend. I thought it went well considering it was my first outing with a 2wd buggy. I did struggle with rear grip coming out of the corner (on throttle) which was a major downer. I made some setup changes to make it better but never got it to the point where the car was planted or comfortable to drive on throttle.
I plan on doing the following (in the order listed) to improve this area in my next outing.
1) Loosen the slipper clutch. I believe this was set to tight. The bench test, my front comes up at least 6-8 inches.
2) Run the gear diff with lighter oil (currently 2000cST, will go down to 1000cST)
3) Use the .5 degree rear hubs, move up to 1 degree (if needed)
4) Use the RF (narrow) suspension hangers.
5) Run longer wheel base (currently 1mm on both sides of the arms)
6) Run 0 degree caster
7) Move weight to the rear (Team Orion shortly LiPO to the rear position)
Initial and mid corner steering is great. I'm also happy with the on power steering. I just need to fix this snap oversteer that occurs the minute I touch the throttle. If there is anything I may have missed please let me know. BTW I'm the running 7.5T Team Orion VST motor with the R10 Pro at Throttle profile 2. Thanks guys!!!
- Middle River Hobbies - The Track -
John.C is offline   Reply With Quote
Old 12-10-2012, 01:28 PM   #3275
Trader Rating: 121 (99%+)
I bought a used rb5 WC, got it tore it down and completely went through and rebuilt the hole car including the diff. I used to race 1/10 buggy but it was many years ago. I got all my electronics put in turned it on everything seemed fine on the stand. Put it on the ground and its slipping like crazy. Got the nut on the slipper cranked down all the way and it doesn't help. Where did I go wrong???
skoalisbad4me is offline   Reply With Quote
Old 12-10-2012, 01:36 PM   #3276
aloksatoor's Avatar
Am I right in assuming you are using a gear diff? I would first try out the ball diff set as loose as possible without it slipping/barking. From then on tune the slipper after ball diff is to your liking.
Old 12-10-2012, 02:29 PM   #3277
Trader Rating: 14 (100%+)
Originally Posted by CanyonCarverR1 View Post
This was covered at length earlier in the thread if you want to read more.
Yes, the balls fit loosly in the shock until you tighten up the nut and expand the ball. Use an alum. nut and tighten it to the point where the shock stays on but doesn't bind. Works fine.
The Exotek shock stays are really nice and give consistent play...
flybyublue is offline   Reply With Quote
Old 12-10-2012, 02:31 PM   #3278
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
But they are aluminum on aluminum.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 12-10-2012, 02:46 PM   #3279
CanyonCarverR1's Avatar
+1
CanyonCarverR1 is offline   Reply With Quote
Old 12-10-2012, 03:04 PM   #3280
silvalis's Avatar
Trader Rating: 29 (100%+)
+2
I bought a pair to try anyway. Going to hit it with a teflon spray and see what happens. Probably bad.
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 12-10-2012, 04:24 PM   #3281
Trader Rating: 101 (99%+)
Originally Posted by AngryRog View Post
I am still considering making a switch from the B4.1 to the RB6. Aside from the quality of the car and the additional adjustment features, what can I expect from the feel/performance of the car compared to the B4.1? Given my limited skills, I am fairly comfortable with the AE.
This could be a significant change for me, as my daughter races buggy as well and she'll want one too.
About 1/2 the Expert & Sportsman Stock class drivers at WCRC are running the RB6 with great results... Feel free to ask anyone there about the buggy Rog... Everyone that now has an RB6 has either owned or raced a B4.1, 22 or DEX210 at one point or another. Everyone at the track is friendly and/or knowledgeable enough to give you good feedback!
~ Richard Watchorn ~
* Team Associated/Reedy Electronics * OCRC Raceway *
* Schelle Racing * CBuilt Designs * Complex Ink *
desertracerdad is offline   Reply With Quote
Old 12-10-2012, 05:18 PM   #3282
eper's Avatar
[QUOTE=AngryRog;11537491]I am still considering making a switch from the B4.1 to the RB6. Aside from the quality of the car and the additional adjustment features, what can I expect from the feel/performance of the car compared to the B4.1? Given my limited skills, I am fairly comfortable with the AE.
This could be a significant change for me, as my daughter races buggy as well and she'll want one too. [/QUOTE
have you ever gone from buggy to stadium truck? this buggy is easy to drive like a stadium truck but as agile as any buggy ever built. a guy at my local track tried the rb6 over the weekend after racing his b4.1 and said that the 6 is just silky smooth. ive run both and he b4.1 is a very agile and able buggy but the six is on pillows. it goes where you tell it to when you tell it to it just does it smoother..I've also driven just about every class out there and more brands and models then i can remember and this car is the best RC car i have ever driven. thats not me trying to sell you on the car that is my honest opinion of the car
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 12-10-2012, 05:20 PM   #3283
asc6000's Avatar
Trader Rating: 15 (100%+)
Originally Posted by silvalis View Post
+2
powdered graphite would work well there
"you reach the limit, you touch the limit, then you pass the limit, now there is a new limit"
Ayrton Senna
asc6000 is offline   Reply With Quote
Old 12-10-2012, 05:22 PM   #3284
aloksatoor's Avatar
@eper
I am going to try your setup for the shorty. Why did you jump to red front directly? How did the whites feel with shorty all the way front? I do like more steering than most, whether that makes me fast or not is another matter, does make me happier with my car . Just afraid reds will take away a lot more steering.
I have both white and red to try and thinking of going to white first.
Last week I found more speed with my current delta rc winter track running a full 300 gram lipo with pink/gold since the track is super rutted from 1/8 nitro and has fewer twisty bits than the summer tracks.
Old 12-10-2012, 05:57 PM   #3285
silvalis's Avatar
The stuff I have turns solid. Was hoping for a buildup/layer.
Graphite lube wouldn't work where I drive. Wet outdoor dirt.
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22971 Yesterday 08:14 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
