    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree17Likes
Old 12-09-2012, 03:00 PM   #3256
K_King's Avatar
Trader Rating: 39 (100%+)
Send a message via AIM to K_King
Originally Posted by cnelson3 View Post
Do u really have the 2mm spaced behind the arms on the toe block hinge pins? I was thinking about going back 1mm to see how it would respond.
Yes I've run them in front and it was good also. On our current layout we have a lot of 180s so I pushed them forward.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 12-09-2012, 03:49 PM   #3257
cnelson3's Avatar
Trader Rating: 65 (100%+)
Originally Posted by K_King View Post
Yes I've run them behind and it was good also. On our current layout we havens lot of 180s so I pushed them forward.
Exactly why I was thinking about moving the arms forward. I race on a tight 180 styled track. Good to know. Thanks.
cnelson3 is offline   Reply With Quote
Old 12-09-2012, 03:57 PM   #3258
Are you guys putting the 2mm spacers behind the rear hanger? Hinge pin?
Sponsers: Schumacher, Santiam Hobbies, Fantom Racing, Racing-cars.com, Flawless RC, Discountrcstore.com
Theroc is offline   Reply With Quote
Old 12-09-2012, 05:34 PM   #3259
cnelson3's Avatar
I haven't yet but king has and he likes it. i'll post my results when i try it.
Old 12-09-2012, 05:58 PM   #3260
drstrangelove's Avatar
Hey bro, welcome. I just got started too. 1/8 servo are find and I'm using them too.
Originally Posted by evolution03 View Post
Im just getting in to running 1/10th scale. What servos are you guys running in your rb6 ? All my servos are for my 1/8 scale cars im sure they will be over powered.
Accepting sponsors who need to test their products durability :)
drstrangelove is offline   Reply With Quote
Old 12-09-2012, 07:25 PM   #3261
C,
Behind the rear hub? I dont know how a 2mm would fit behind the rear hangers.
Thanks,
Rocky
Old 12-09-2012, 07:55 PM   #3262
cnelson3's Avatar
C,
Thanks,
Rocky
the hinge pins that connect the toe blocks have a 2 mm spacer in front of the arms standard. King posted a set up sheet that showed that he put the 2mm spacer behind the arms on those hinge pins thereby moving the arms forward. Not talking about the hub placement at all. I'm interested in what this will do. I have a feeling about what is going to happen but i want to give it a shot.
Old 12-09-2012, 10:57 PM   #3263
Got it! Thanks! long weekend
Rocky
Old 12-10-2012, 05:53 AM   #3264
Trader Rating: 77 (100%+)
Well I tried the new Triad slipper yesterday. While I was at it i rebuilt the diff. Man I have been struggling with diffs lately. They just don't hold up and I figured I was doing something wrong in the build/break in process.
I had Cody Turner help me and, teach me and make sure I was doing everything right. What a difference. The whole night the car ran great with really good consistency. I am not all that good but a the Triad is nice because it seems to stay adjusted and consistent throughout each race and the entire night.
Having a dialed and adjusted diff and slipper makes all the difference in the world especially for a sportsman.
Thanks to Cody. He is the real deal and Kyosho should feel lucky to have him representing their brand.
TRF 418 - Team Powers 17.5, HobbyWing Stock Spec, Xpert servo
Xray T4 2016 - Trinity D4, HobbyWing Stock Spec, Ko Propo servo and radio
KustomRCGraphics.com (Best looking novice on the track)
goin2drt is offline   Reply With Quote
Old 12-10-2012, 07:11 AM   #3265
The other thing to note was the spur size. I have been running 76/21 and when I purchase my Triad I could not get the 76 so I had to go with 75. That took a little adjusting and I did not have time to get it perfect for me by the end of the night. I ended up at 76/23 but I still don't like it.
Old 12-10-2012, 07:57 AM   #3266
x7tristan's Avatar
Default 5.8 Shock Ball
It seems like the 5.8 shock ball that goes in to the shock caps fit a little loose in the shock cap holes. Are there shock balls that actually fit/snap in to the shock cap holes?
TJ
DURANGO DESC410R
x7tristan is offline   Reply With Quote
Old 12-10-2012, 09:01 AM   #3267
AngryRog's Avatar
Trader Rating: 20 (100%+)
I am still considering making a switch from the B4.1 to the RB6. Aside from the quality of the car and the additional adjustment features, what can I expect from the feel/performance of the car compared to the B4.1? Given my limited skills, I am fairly comfortable with the AE.
This could be a significant change for me, as my daughter races buggy as well and she'll want one too.
Anger, K-Speed, Mini Mafia, NitroHouse.com
M03.1, M05v2 Pro, M05v2-R, M07, FF03-R, TA05v2, TRF419X, Roche P12
AngryRog is offline   Reply With Quote
Old 12-10-2012, 09:24 AM   #3268
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
There are no words
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 12-10-2012, 09:27 AM   #3269
CanyonCarverR1's Avatar
This was covered at length earlier in the thread if you want to read more.
Yes, the balls fit loosly in the shock until you tighten up the nut and expand the ball. Use an alum. nut and tighten it to the point where the shock stays on but doesn't bind. Works fine.
CanyonCarverR1 is offline   Reply With Quote
Old 12-10-2012, 10:11 AM   #3270
x7tristan's Avatar
Default Receiver Interference?
I haven't had the chance to run my RB6 yet, so I was wondering if anyone has had issues with wiring the battery connectors right over the receiver? I'm wondering if doing so will cause some interference.
TJ
DURANGO DESC410R
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22970 10-17-2017 05:10 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 5 (1 members and 4 guests)
bonzo915
