    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 12-08-2012, 09:36 PM   #3241
fastestwon's Avatar
Trader Rating: 15 (94%+)
Default Avid Triad top shaft and slipper clutch
just got back from practice first time running the avid system . defiantly smoother then the stock system can really come on the throttle a lot harder . on the speed control adjustment for punch before i was only able to run at 4 and now i can run at 9 with the speed passion revention pro . i turned the fastest laps from any class . my fastest lap was 15.6 my ave laps were 16.3 . most racers were turning anywhere from 16.8 as their fastest and their ave laps were around 18.0 and higher . i would say the avid system is a must have.
fastestwon is offline   Reply With Quote
Old 12-08-2012, 10:15 PM   #3242
Trader Rating: 18 (100%+)
Originally Posted by Cpt.America View Post
lets see some pictures of the car... sounds like something is a miss. Did you buy truck springs instead of Buggy springs? Lets measure the length of the unloaded spring.
EDIT. Springs are 73mm
Unfortunately the wife took our camera out of state so I have no way to take a picture. My gold springs are 73mm long, but seem to be very stiff. Without changing anything else but the gold springs to the kit red springs the car almost bottomed out. After adjusting the shock collars appropriately I got the ride height where I want it.
Ctimrun is offline   Reply With Quote
Old 12-08-2012, 10:20 PM   #3243
silvalis's Avatar
Trader Rating: 29 (100%+)
If you can turn the punch up and hit the throttle harder, doesn't this just mean it slips more?
Sounds to me like you've either got a bad set or the wrong spring altogether. Do you still have the kyosho bag that says the part no?
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 12-08-2012, 10:29 PM   #3244
fastestwon's Avatar
no.... it just don't break loose with very little slip. were as the stock system is very inconsistent with adjustment .
Old 12-08-2012, 10:45 PM   #3245
As you were typing this I was out in the side yard digging through our trash can with a flashlight to find the tag for the springs. Part number is XGS034. Looking for part numbers....
EDIT: If I am looking at this right XGS034 are truck springs and the buggy springs are XGS013. Looks like CA was on the right track, even though these are also 73mm long just like the buggy springs. I think they just have a different wind.
Old 12-09-2012, 07:40 AM   #3246
Im just getting in to running 1/10th scale. What servos are you guys running in your rb6 ? All my servos are for my 1/8 scale cars im sure they will be over powered.
evolution03 is offline   Reply With Quote
Old 12-09-2012, 07:47 AM   #3247
Spektrum 6040 in mine.
Old 12-09-2012, 08:39 AM   #3248
CanyonCarverR1's Avatar
Are you running that in Mod or 17.5?
I run 17.5 and am wondering if it will help or am I just adding more rotating mass. I run on a med/high traction indoor clay track.
I guess my question is; is this helpful for 17.5? Or just mod?
Your thoughts please?
CanyonCarverR1 is offline   Reply With Quote
Old 12-09-2012, 09:50 AM   #3249
jwood7's Avatar
IMO its a waste of money for 17.5. I ran stock at spectrum with a slipper iliminator and 64 pitch gears with no problems. But if ur having problems with wheel spin and putting the power down then it's a good option. I run the ae setup in my mod car and I think it does help.
jwood7 is offline   Reply With Quote
Old 12-09-2012, 10:36 AM   #3250
fastestwon's Avatar
i practiced with 17.5 blinky 13.5 blinky and 10.5 worked great with all three . the only difference between the three is 17.5 slips less then 13.5 and 13.5 less then 10.5 . the adjustment really didn't change but the fastest was the 13.5 on the given layout . the avid system was warm not hot and it is nice and quite running... true gears very nice gear mesh. that was running till the battery lipo cut off.
Old 12-09-2012, 10:39 AM   #3251
Autocratic's Avatar
Trader Rating: 26 (100%+)
What's the biggest advantage to running 64p gearing?
Thanks to my sponsors for 2015!
XFactory RC | Proline Racing | Fantom Racing | Avid RC | Speed Passion USA | Factory1 | Hy-Traction Juice | Mike's Hobby Shop
Autocratic is offline   Reply With Quote
Old 12-09-2012, 12:24 PM   #3252
Mxer59's Avatar
Trader Rating: 114 (100%+)
I went up to a new track and after running this car two days of prac...... Why did I wait so long I feel very connected to the car very quick. I had a few issues at first where it felt slow of the bottem Tekin Rs and gen2 17.5 "blinky" I went in my Hotwire messed with when the throttle comes on a little bit sooner this car is a rocket I had ppl asking what I did to the car cause from my first two runs then switched the setting and the car was night and day different I had ppl accusing me of running boost . The tracks average fast laps are 15'6 I broke into a 14'4 overall very happy with this car!
Will Kyosho realese a 2wd SCT version of this car?
5ive T (Bartoline 28.5cc, Bartoline Pipe, Team Chase)
Futaba 4pls
Team Chase 2015
Rd. 2 TQ-1st--Rd. 3 3rd
Mxer59 is offline   Reply With Quote
Old 12-09-2012, 12:42 PM   #3253
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
Hey guys I've been tweaking on my car here at SDRC. Still going to work on a few things on the front end, but so far this feels pretty good.
https://dl.dropbox.com/u/18166464/Ke...DRC%20Base.pdf
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 12-09-2012, 12:42 PM   #3254
fastestwon's Avatar
Default scr sp
i have sold mine . awaiting on the new one to be released
Old 12-09-2012, 02:11 PM   #3255
cnelson3's Avatar
Trader Rating: 65 (100%+)
Do u really have the 2mm spaced behind the arms on the toe block hinge pins? I was thinking about going back 1mm to see how it would respond.
cnelson3 is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22943 Yesterday 07:07 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
