    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 12-08-2012, 11:10 AM   #3226
t8rtot's Avatar
Trader Rating: 14 (94%+)
They'll settle as you run them.
It's the car at running weight? Everything installed?
Sfida
t8rtot is offline   Reply With Quote
Old 12-08-2012, 11:20 AM   #3227
Trader Rating: 37 (100%+)
I looked and didnt see a specific answer.
What from my RB5 SP2 spares is worth keeping to use with the RB6?
Nexus is offline   Reply With Quote
Old 12-08-2012, 11:31 AM   #3228
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by Ctimrun View Post
Sitting here getting my 6 all set up and with the gold rear springs and shock collars all the way up my ride height is way over 24 I want to run. Any ideas?
Wrong shock ends (too short) will push the spring cup too high... and therefor, the spring too high.. (or you aren't at running weight)
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 12-08-2012, 11:34 AM   #3229
Super Moderator
Gearbox gears
Diff
anything for the shocks
rear hubs
hing pins (I think)
motor guard
suspension hangers
axles and swingshafts
bearings
- RCSpecialties -
Old 12-08-2012, 12:12 PM   #3230
Trader Rating: 18 (100%+)
I followed the Jason Dias setup. The distance between the ball end and the shock cartridge is 27.5mm, I've got the long ball ends on the rear shocks, and I'm at running weight. Odd
Ctimrun is offline   Reply With Quote
Old 12-08-2012, 12:16 PM   #3231
Super Moderator
27mm is the length of the showing shock shaft. is that how you measured it?
- RCSpecialties -
Old 12-08-2012, 12:22 PM   #3232
Super Moderator
well.. almost 27
- RCSpecialties -
Old 12-08-2012, 12:39 PM   #3233
no no.. 27mm is the length of the showing shock shaft. The distace between the TOP of the shock end, and the cartridge. I run 27mm exactly, with the long shock ends. Your overall length is about 20mm too short.
(i just read your post again.. maybe you are describing the same thing?)
Ya were saying the same thing. I am using a caliper to measure the distance between the top of the shock end and the cartridge and I have 27.5mm. I can't get the ride height below 30mm when it is setup like this, and this is with everything installed. I even threw on an extra shorty pack and the lowest I can get it is 28mm......
I also have to add that I had heard what great quality the Kyosho stuff is, and I have to agree, but their quality control as far as packing the kit (at least mine) was terrible.
I opened bag #5 to build the shocks and I had exactly 1 (yes one) O-ring to build all four shocks with. I had to drive for about three hours all over So-Cal to track down all the proper O-rings to get them built. When I got home I realized their little plastic shock cartridge tightening tool was also missing. I went through every bag, dug through my entire build trash can, took everything off my hobby room floor just in case I dropped it and it mysteriously rolled (even though its not round) and it never turned up.
Needless to say I am not thrilled about how this kit has gone together, I hope I have a better experience driving it than building it.
Old 12-08-2012, 12:41 PM   #3234
Super Moderator
lets see some pictures of the car... sounds like something is a miss. Did you buy truck springs instead of Buggy springs? Lets measure the length of the unloaded spring.
EDIT. Springs are 73mm
- RCSpecialties -
Old 12-08-2012, 02:48 PM   #3235
silvalis's Avatar
Trader Rating: 29 (100%+)
Originally Posted by fastestwon View Post
only if you don't know how to setup the car . my car works great in all conditions . here is my car on a low to med grip indoor clay track . my car is TQ in MM in the second spot is another RB6 in RM and in the fifth spot is an RB6 in MM as well the rest of the cars are AE and one TLR 22 in seventh spot . since i switched to MM the car has only gotten better. everyone has their own preference . good luck in however you decide to go .
http://www.youtube.com/watch?v=ZnT4owyK6Z0
I wish my track was like your 'low to med' grip. You'd consider mine ice...
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 12-08-2012, 02:49 PM   #3236
skidooracer's Avatar
Trader Rating: 25 (100%+)
hey guys just ran my new rb6 for the first time lastnight!! i love it, im wondering what pistons you guys are running i got the stock pistions and pinkf 35f goldr 30r on the oils and it just seems soft
skidooracer is offline   Reply With Quote
Old 12-08-2012, 02:50 PM   #3237
asc6000's Avatar
Trader Rating: 15 (100%+)
unlikely but....
did you bleed your shocks completely ?
"you reach the limit, you touch the limit, then you pass the limit, now there is a new limit"
Ayrton Senna
asc6000 is offline   Reply With Quote
Old 12-08-2012, 02:57 PM   #3238
yes i bled them completly
Old 12-08-2012, 04:51 PM   #3239
Originally Posted by pete48 View Post
Is anyone running a full size stick pack in the mid-motor config? I just don't see how the battery is held in place on the motor side. The instructions only show to install the front battery mount. Seems as if this thing is going to slide all over the place.
ANYONE??????? My battery slides back and forth . The instructions show no provisions to hold it for/aft. Running stick pack and MM. Thanks!
pete48 is offline   Reply With Quote
Old 12-08-2012, 05:00 PM   #3240
lbckevin's Avatar
Trader Rating: 89 (99%+)
use the included foam to tighten up the gap.
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
