    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree25Likes
Old 12-07-2012, 08:26 AM   #3196
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Originally Posted by x7tristan View Post
what exactly are the differences between the two sets of blocks? are the changing the track width of the car?
Yes that is correct.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 12-07-2012, 08:36 AM   #3197
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by MrHistory View Post
When using aluminum rear hubs in RB5 rear arms, do I use a grub screw in the aluminum hub to secure to arm pin?
Always use the set screws. You don't want the hing pin rubbing/spinning in the aluminum hole, as alu on alu will wear quickly, and you will ruin the alu hubs. The set screw makes sure that all the hing pin rotation happens in the holes of the arm, instead of the hole in the hub.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 12-07-2012, 09:12 AM   #3198
pekow91's Avatar
Trader Rating: 45 (100%+)
Originally Posted by Cpt.America View Post
If you are running the aluminum rear suspension hangers... you are set. Every other piece on the car is only going to break if you do something you really shouldn't of done. Nothing else on the car is broken "over easily". The one piece you may want to toss in your bag anyway, is the rear upper bulkhead.
http://www.amainhobbies.com/product_...Upper-Bulkhead
Now, if you don't have access to parts at your track, I would also toss in a full set of arms, caster blocks, and front shock tower.
Sorry for being a noob but what is a rear hanger. Can you send me a link on amain?
Kyosho RB6 | Kyosho MP9 TKI3E | Xray XB4
pekow91 is offline   Reply With Quote
Old 12-07-2012, 09:52 AM   #3199
Trevor Williams's Avatar
Trader Rating: 195 (100%+)
they are the hinge pin blocks.....I posted a link on the previous page to the gunmetal versions.
RC10-B6d | RC10-B64d
SmacTrac
#WeAreAE #ReedyPower #AE4Life
Trevor Williams is offline   Reply With Quote
Old 12-07-2012, 09:57 AM   #3200
asc6000's Avatar
Trader Rating: 15 (100%+)
hangers / blocks / or suspension holders
all the same part just different terms which gets uber confusing, welcome to K cars, take lots of notes
part numbers a few posts back
Originally Posted by Trevor Williams
gunmetal narrow blocks:
kyoumw511
kyoumw512
gunmetal wide blocks:
kyoumw514
kyoumw515
Heres a search on one
http://www.amainhobbies.com/advanced...umw512&x=0&y=0
"you reach the limit, you touch the limit, then you pass the limit, now there is a new limit"
Ayrton Senna
asc6000 is offline   Reply With Quote
Old 12-07-2012, 10:18 AM   #3201
Super Moderator
It's ok that you have noob questions, we have all had them... but at least meet us half way and read a little bit. The part numbers are even posted on post#1 of this page (in a quote).
Suspension hangers are the rear pieces that hold the inner hingpin for the rear arms.
- RCSpecialties -
Old 12-07-2012, 10:35 AM   #3202
pekow91's Avatar
You are right and I usually try to read what has already been posted. The post above refereed to them as suspension blocks and I thought the hangers were something different. Anyway, I got it now and thanks for the info.
Old 12-07-2012, 10:39 AM   #3203
Super Moderator
aah i see, not a problem, and sorry for the confusion. (never hesitate to ask a question, that's what we are here for!) Kyosho calls them "suspension holders". They can also be called "pivot blocks" too.
- RCSpecialties -
Old 12-07-2012, 06:53 PM   #3204
MrHistory's Avatar
Thanks for the aluminum hub answer...
Im new to buggy and wondering if its the norm to run a chassis protector on the bottom of the car. I dont really want to be that fussy but I have read the whole thread and about the chassis problem. Just curious what the serious guys are doing and if the car works better or lasts longer with film.
thanks
Irwin RC 1/8th Pan Car Specialists - www.irwinrc.com
SPM Competition, WRC Racing, MIP, Novarossi
MrHistory is offline   Reply With Quote
Old 12-07-2012, 07:47 PM   #3205
toast.'s Avatar
Trader Rating: 14 (100%+)
Chassis problem was only on a couple of the RB6.
I dont think a 'protector' would keep it from happening if you had one of the few that had that problem.
Small Tires:TA05 v2, M05-Pro, TT01, RC18's
Big Tires: SCT410, SSC "Slash" LCG, Mugen MBX6 eco SCT, RB5, RB6
toast. is offline   Reply With Quote
Old 12-07-2012, 07:50 PM   #3206
B00t13g's Avatar
My chassis has been fine so far. Pretty sure mine was from the second batch of kits shipped over.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 12-07-2012, 08:10 PM   #3207
gelshocker's Avatar
Hey guys I got the Orion R10, is it a good fit or do I need to change out to thinner gauge wires, other mods? Thanks,
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 12-07-2012, 08:34 PM   #3208
B00t13g's Avatar
Mine fits fine with no mods. I will be changing to more flexible wires though to allow for a better fit.
Mackenzie Meyercord
Old 12-07-2012, 08:36 PM   #3209
silvalis's Avatar
Trader Rating: 29 (100%+)
thanks
It's not really an issue at all. I've run another half dozen meets and it's not like the back is about to fall off.
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 12-07-2012, 10:04 PM   #3210
MrHistory's Avatar
I noticed several of the bearing for the transmission have smashed in bearing shields. I switched out one from the MM bag, but one of the large diff bearings is pushed down into the housing and does not move as freely as the other one I have.
Should I remove the damaged shield and turn that side of the bearing to the inside of the transmission case?
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22979 Yesterday 10:09 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15026 11-02-2017 04:19 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 09:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 05:30 PM
