    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 12-05-2012, 09:19 PM   #3151
Trader Rating: 62 (100%+)
Originally Posted by B00t13g View Post
Has anyone tried running the narrow rear setup on medium bite? I keep breaking rf2s and the aluminum one is back ordered. Everyone local is having the same issue.
They had the alloy rf2 at speedtechrc. Priced lower too.
sipaboy is offline   Reply With Quote
Old 12-05-2012, 09:34 PM   #3152
B00t13g's Avatar
They were out of stock, as was a main.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 12-05-2012, 09:41 PM   #3153
x7tristan's Avatar
Originally Posted by eper View Post
i think yeti covered it pretty well. i personally wouldnt use any of those settings though. the car is plenty agressive with more stock settings and all your settings seem to be to make it more aggressive. i did see you write that your coming over from a 210 though right?
Thanks guys for the tips.
What's the wide suspension holders do? What's everyone runningfor a medium clay track, wide or regular?
TJ
DURANGO DESC410R
x7tristan is offline   Reply With Quote
Old 12-05-2012, 09:55 PM   #3154
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
I run the narrows... car is already so aggressive, at this point at least for me, the wide rear hangers aren't needed. Rear traction is more predictable with the narrow hangers.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 12-05-2012, 10:58 PM   #3155
B00t13g's Avatar
Interesting. I'll try the plastic narrows ones tomorrow and if they work out ill snag the aluminum.
Mackenzie Meyercord
Old 12-06-2012, 02:19 AM   #3156
rokitman's Avatar
Trader Rating: 128 (100%+)
you can find them on ebayas well. Take about 7-10 days to get them, I believe is how long mine took.
rokitman is offline   Reply With Quote
Old 12-06-2012, 03:40 AM   #3157
carcrusher46's Avatar
Trader Rating: 17 (100%+)
Originally Posted by RodneyB View Post
This reminds me. Is there a part number for the thicker RF2 plastic suspension block that comes with the kit? The one that comes with the UM508C tree is the older RF2 with the thin edges. Try putting one of those on and you will be replacing it every few races if your track has any sizable jumps at all. Kyosho must have found that out and beefed it up, but how do you buy it? Am I missing something?
Randy - I believe the part number you're looking for is UM726. It's specified as a mid-motor part, but the bubble callout 132 in the manual points to this number in the parts list rather than UM508C, which would be for the old thinner toe blocks. The image on the page should show you that the part you're looking for is on the right side of the tree.
http://www.kyoshoamerica.com/Sus-Hol...r_p_11159.html
I had to do some digging myself to figure it out - I remember that the RF2 block was the only piece from that tree that I used in the build.
Matt Stoltz
Thank you to my sponsors:
Team Associated - Reedy - JConcepts - Life Fast RC Paintworks
carcrusher46 is offline   Reply With Quote
Old 12-06-2012, 03:52 AM   #3158
mdowney's Avatar
Trader Rating: 21 (100%+)
Cody Turner and a few of the other team drivers have switched to running narrow blocks.
Mike Downey
I try all of the RC kits and usually race at Tacoma RC Raceway
mdowney is offline   Reply With Quote
Old 12-06-2012, 04:12 AM   #3159
fastestwon's Avatar
Trader Rating: 15 (94%+)
those parts are for only MM as it uses the 18mm screws that go right up into the rear bulkhead and the one on the right goes on the rear front .
fastestwon is offline   Reply With Quote
Old 12-06-2012, 04:41 AM   #3160
Energyzer's Avatar
So how many guys have moved from heavier full sized lipos, to lighter or shorty lipos? I have been running my Fantom 6500 65c Lipos in this car since day 1, and as fantastic as the car is, it just "felt" too heavy on the track.
This last weekend I decided to run shorties for the day, and MAN what a difference! I did some weighing, and with my 6500s, the car was 200 grams over weight with a full sized BLS351 servo. With the a shorty, I was only 100 grams over weight and it made all the difference in the world. Car was snappier, responded better in all regards (throttle, braking, and turning), and it made a noticeable difference in lap times, first time on the track. I ran the shorty dead smack in the middle of where the full sized pack sat to keep the F to R weight bias about the same... worked perfect.
I can't see me ever going back to a heavy ~300gram pack ever again in this car. Im going to stick with the ~200. Needless to say, I immediately put an order in for a pair of Fantom 4500 shorties. Can't wait to get more track time in the newer lighter set up. -YMMV
Are saddles like shorties? I've been running GenAce full size pack since day 1... Looking for the Orion's saddles (either 5500 or the 4500 ones i don't know yet) if they are worth the money.
Energyzer is offline   Reply With Quote
Old 12-06-2012, 05:54 AM   #3161
underway's Avatar
Trader Rating: 48 (100%+)
What is the difference between the blocks on the track?
underway is offline   Reply With Quote
Old 12-06-2012, 08:07 AM   #3162
OnRDPassion's Avatar
Trader Rating: 54 (100%+)
So I just put the triad in my car. I run stock also so keep that in mind. I liked the overall feel of the slipper and it seemed to be much more consistent than the ae pads with spur gear I was using. I have yet to try it out in mod, but I think I will be doing that in the next couple of weeks.
Overall if the swap out was just simple kit without having to buy the new top shaft for the car, I would say definitely get it! But since you need to buy a new top shaft for it, it's somewhat questionable. Maybe I will notice more of a difference in modified when I start playing with it.
In regards to the pistons AVID makes I would have to say I like them quite a bit. Very smooth and when changing out between the the 4 hole 1.6 and 1.1 to the two hole 1.6 from the stock pistons it seemed to settle the car down quite a bit and actually seemed like it helped it to jump slighting better. I did manage to get a couple sub 21s in practice but in my qualifiers I was a little all over the place, as my concentration really wasn't there for some reason.
OnRDPassion is offline   Reply With Quote
Old 12-06-2012, 08:18 AM   #3163
asc6000's Avatar
Trader Rating: 15 (100%+)
no. Saddles are in between weight and size. Which you choose to run is about the weight and ability to move it in the battery box for tuning. Iv'e used all three, saddles only because I have them sitting around for the ZX.
If I ran blinky 17.5 I'd tune for the shorty. For open I'd use full size stick for weight/traction.
"you reach the limit, you touch the limit, then you pass the limit, now there is a new limit"
Ayrton Senna
asc6000 is offline   Reply With Quote
Old 12-06-2012, 08:45 AM   #3164
Originally Posted by lbckevin View Post
I love my stock body all painted up...
Nice!!!!!!!!!!
(Did you paint that yourself Kevin or did Josh paint it?)
Allen
abinder is offline   Reply With Quote
Old 12-06-2012, 09:04 AM   #3165
fastestwon's Avatar
Default shock pistons
has anyone other then me even tried the kyosho 6 hole pistons 1.25mm . i run them front and rear they are super smooth and the car works awesome .
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
