    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 12-04-2012, 09:44 PM   #3106
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
Originally Posted by x7tristan View Post
Hey guys I'm having trouble understanding how all the tuning shims and inserts work. Is there a simple chart like the one for the FS2, that explains how the suspension shims/inserts affect the kick up/anti squat/rear toe?
AFAIK you cant affect the rear toe with shims, only new hubs.
Toe, if you add shims to the rear, you take away Anti Squat. If you add it to the front of the pivot you add. .5mm shim = 1 degree adjustment.
Inserts are just for caster, more caster = less steering. The inside and outside options adjust the track width of the car, which can make it react faster or slower depending on your shock setup.
The other shims on the ballstuds affect roll.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 12-04-2012, 10:25 PM   #3107
toast.'s Avatar
Trader Rating: 14 (100%+)
Which shorty are you running?
Had my RB6 at WCRC Tuesday and it felt really good except it seemed heavy on the jumps.
Originally Posted by lbckevin View Post
I also have run the short pack in mine. All of the Kyosho drivers at West Coast are all running the shorty.
Small Tires:TA05 v2, M05-Pro, TT01, RC18's
Big Tires: SCT410, SSC "Slash" LCG, Mugen MBX6 eco SCT, RB5, RB6
toast. is offline   Reply With Quote
Old 12-04-2012, 11:07 PM   #3108
Trader Rating: 27 (100%+)
Revtech double deuce is the best is say or the orion. I got the revtech the other day and will not put a full size pack in it ever again.
Kyosho, Lunsford Racing, Express Motorsports, Dibrino Designs.
C_Money is offline   Reply With Quote
Old 12-05-2012, 12:35 AM   #3109
Pro-Line 2012 BullDog for RB6 rocks!
See more details here
nitroargi is offline   Reply With Quote
Old 12-05-2012, 03:06 AM   #3110
I'm assuming those are Proline wheels....
Gitsum is offline   Reply With Quote
Old 12-05-2012, 05:21 AM   #3111
eper's Avatar
it would be easier to tell us whats in the car and what you are trying to achieve. also i always say the bast way to understand what a change does is spend the time making 1 change at a time and feeling it for yourself
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 12-05-2012, 06:08 AM   #3112
x7tristan's Avatar
I haven't built the car yet. I was going through the manual beforehand and noticed the possible shims/inserts.
For starters lets say I wanted 20deg caster, 1.5 anti-squat, 2.5deg rear toe, what would I do?
TJ
DURANGO DESC410R
x7tristan is offline   Reply With Quote
Old 12-05-2012, 07:09 AM   #3113
fastestwon's Avatar
Trader Rating: 15 (94%+)
Default Avid Triad top shaft and slipper clutch
i finally installed mine and will be testing Saturday. we have no racing but practice . by just somewhat tuning on my carpet it feels way better then the stock one that comes with the car.
fastestwon is offline   Reply With Quote
Old 12-05-2012, 09:03 AM   #3114
Electrolabs's Avatar
Hi everyone,
Just to let you know, I broke my steering rack and installed the aluminum exotek and after pretty severe crash I broke the stock steering cranks. Replaced them with the exotek aluminum and steering is much more precise due to no flex.
I highly recommend both exotek steering rack and cranks, best upgrade so far.
[Kyosho Ultima RB6 - Team Orion - LRP] - [Kyosho Inferno MP9 TKI3 - Werks] - [Futaba]
Electrolabs is offline   Reply With Quote
Old 12-05-2012, 09:24 AM   #3115
fastestwon's Avatar
Originally Posted by Electrolabs View Post
Hi everyone,
the next part to break would be the steering knuckles or the servo it's self .
Old 12-05-2012, 09:29 AM   #3116
Outtacontrol58's Avatar
Trader Rating: 91 (98%+)
Send a message via AIM to Outtacontrol58
Has anyone switched from a tlr22 to the rb6? I'm wondering if its worth the switch, I also have a 22sct.
Outtacontrol58 is offline   Reply With Quote
Old 12-05-2012, 09:56 AM   #3117
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Favor to ask!
Anybody with a grams scale that is running exotec products on their 6. Possible to weigh them against the stock pieces?
Aluminum steering rack pieces and plastic steering rack pieces?
Carbon Fiber the front shock tower and plastic front shock tower?
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 12-05-2012, 10:00 AM   #3118
Super Moderator
Nah.. next thing would probably be the servo horn stripping around the servo.
- RCSpecialties -
Old 12-05-2012, 10:09 AM   #3119
aloksatoor's Avatar
Trader Rating: 42 (100%+)
I just threw up a little. Its like carrying a backpack on itself behind the cab.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 12-05-2012, 10:10 AM   #3120
Trader Rating: 137 (100%+)
If you have a decent servo that shouldn't happen.
TLR 22T 3.0, TLR 22-4 2.0 , TLR 22 4.0 X2, 22SCT 3.0, Tekno SCT 4X4, Tekno EB48.4, Hobbywing, Futaba, LRH Hobbies, Spektrum Servos, iCharger.
jpcopeland1 is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22957 Today 12:16 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
