    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 12-03-2012, 06:09 PM   #3091
Mxer59's Avatar
Trader Rating: 114 (100%+)
Originally Posted by abinder View Post
I'm currently running my 17.5 Tekin Gen2 at about 38 degrees of timing with a 28 pinion and 72 spur gear.
(I'm running it at WCRC.)
Allen
I'm at 20% end bell timing, I was running 72-34 on my b4.1 WC (not sure if gear ratios between both cars are different) but I want a little more bottem grunt for out of corner double. Med to low traction- with loose dirt top soil. Tire of choice is Jc goosebumps or pro Tazers
5ive T (Bartoline 28.5cc, Bartoline Pipe, Team Chase)
Futaba 4pls
Team Chase 2015
Rd. 2 TQ-1st--Rd. 3 3rd
Mxer59 is offline   Reply With Quote
Old 12-03-2012, 06:17 PM   #3092
lbckevin's Avatar
Trader Rating: 91 (99%+)
Mxer,
That gearing is fine...The biggest you can fit is a 33 pinion with an AE 72 spur without dremeling the motor plate. The motor timing is very low, turn it up to around 35 degrees and check your temps after a couple of minutes.
I run a Schuur Speed at 33/72 with 40 degrees of timing and its supa fast !!
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 12-03-2012, 06:20 PM   #3093
lbckevin's Avatar
The new Tekin Redline 2 motors are very fast ( read high rpm) and they need to be geared a little lower. 29/32 should be fine with 30 degrees of timing to be equivalent to most competitive stock motors.
Kevin Smith
Old 12-03-2012, 06:21 PM   #3094
lbckevin's Avatar
Originally Posted by silvalis View Post
Anyone got an opinion on tuning for heat using timing adjust vs regearing?
Also, is the finisher the only other body available so far? I'm still hanging for a non-cab forward body...
Proline is working on a body, but it is cab forward. You can run your old rb5 body with some trimming as well. All new bodies will be cab forward and have much better handling than the older bodies.
Kevin Smith
Old 12-03-2012, 06:21 PM   #3095
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Anyone got an opinion on tuning for heat using timing adjust vs regearing?..
You don't tune for heat.. you tune for lap times, WITH a temp limit.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 12-03-2012, 06:29 PM   #3096
lbckevin's Avatar
+1
Kevin Smith
Old 12-03-2012, 06:45 PM   #3097
Super Moderator
Let me clarify... sorry if i was a bit vague. Here is a prime example.. I will use myself.
I have my gearing set to THEE sweet spot for the gear I run, and my track. I run
Fantom Apex 17.5
12.5 HT rotor
maxed end bell timing
31/69
~120 after 8 minutes
The car is SUPER fast for a 17.5. It has the perfect balance of rip in the infield, and pulling speed down the straight. On COUNTLESS occasions, and at multple tracks (albeit similiar sized tracks). I have gone down to 30/69, and tried 32/69. Going up one tooth or down one tooth hurts my laptimes. Either I max out too early on the straight and loose my pulling power, or gearing up looses a bit too much of the infield rip that I need. So, since I am WAY under the heat limit, heat doesn't even come into play in my gearing. Gear UP until my motor is coming off at 160 (Gearing for heat), would certainly decrease performance on the race clock.
There is newer guy at my track who runs 17.5 SC, and was worried that his motor was coming off too cool.. so he geared up 2 extra teeth... and his lap times were no better at all... but he was coming off hotter. So where he gained on the straight, he was then losing in the infield on the tight sections of the track. It is a net loss.
Now, that doesn't mean that for YOU, and YOUR gear, and YOUR track... wont get the best lap times geared tall and up against the heat limit. That very well may be the case.
So gear for performance/lap times... as long as it is under the heat limit. If the best performance keeps you coming off the track at 180 degrees, you need to gear down to save on temp, and find another way to improve your lap times. (smoother throttle, smoother brake, better cornerspeed, etc).
Just my $.02! Hope that makes more sense.
- RCSpecialties -
Old 12-03-2012, 07:57 PM   #3098
silvalis's Avatar
Trader Rating: 29 (100%+)
Yes, this is how I currently gear too. However, I was toying with the idea of gearing slightly down and increasing timing for more top end rpm, or vice versa - gearing slightly up, then decreasing timing for slightly more torque (although I suspect the torque gains here would be less than regearing). It would potentially be a more fine tuning than gearing up/down (even though this is fine enough).
Alternatively, what I want to think about is why your timing is maxed out.
This is all stemming from me being stupid, blowing up my Ion3 and putting in a Xerun 17.5 locked timing I had sitting around, which came off @5m cold @69/34. Waiting for new reedy motor...
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 12-03-2012, 08:17 PM   #3099
Super Moderator
in some regards, how tall or short you gear your motor is kind of synonymous with how much endbell timing you run. I get similar results (less torque, more top end) by gearing up OR turning up the end bell timing. Some motors seem to run better geared taller with less timing, some run better geared lower, with MORE timing. The Fantom APEX loves the endbell timing, which is where the top end comes from. I fine tune the motor's response from there, with gearing. It's give and take with both settings.
- RCSpecialties -
Old 12-04-2012, 12:53 PM   #3100
Super Moderator
So how many guys have moved from heavier full sized lipos, to lighter or shorty lipos? I have been running my Fantom 6500 65c Lipos in this car since day 1, and as fantastic as the car is, it just "felt" too heavy on the track.
This last weekend I decided to run shorties for the day, and MAN what a difference! I did some weighing, and with my 6500s, the car was 200 grams over weight with a full sized BLS351 servo. With the a shorty, I was only 100 grams over weight and it made all the difference in the world. Car was snappier, responded better in all regards (throttle, braking, and turning), and it made a noticeable difference in lap times, first time on the track. I ran the shorty dead smack in the middle of where the full sized pack sat to keep the F to R weight bias about the same... worked perfect.
I can't see me ever going back to a heavy ~300gram pack ever again in this car. Im going to stick with the ~200. Needless to say, I immediately put an order in for a pair of Fantom 4500 shorties. Can't wait to get more track time in the newer lighter set up. -YMMV
- RCSpecialties -
Old 12-04-2012, 12:58 PM   #3101
Trader Rating: 62 (100%+)
I like mine with shorties too.
sipaboy is offline   Reply With Quote
Old 12-04-2012, 01:43 PM   #3102
fastestwon's Avatar
Trader Rating: 15 (94%+)
i have been running shorty packs pretty much from day one . i tried the long battery once just to see . short packs way better
fastestwon is offline   Reply With Quote
Old 12-04-2012, 02:46 PM   #3103
t8rtot's Avatar
Trader Rating: 14 (94%+)
has anyone put on the exotek shock post? any issues with metal/metal contact? pictures?
Sfida
t8rtot is offline   Reply With Quote
Old 12-04-2012, 03:16 PM   #3104
lbckevin's Avatar
I also have run the short pack in mine. All of the Kyosho drivers at West Coast are all running the shorty.
Kevin Smith
Old 12-04-2012, 08:23 PM   #3105
x7tristan's Avatar
Default New to RB6
Hey guys I'm having trouble understanding how all the tuning shims and inserts work. Is there a simple chart like the one for the FS2, that explains how the suspension shims/inserts affect the kick up/anti squat/rear toe?
TJ
DURANGO DESC410R
x7tristan is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22957 09-22-2017 12:16 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Gayosaka
