    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree15Likes
Old 12-02-2012, 06:12 PM   #3061
Mxer59's Avatar
Trader Rating: 114 (100%+)
What are you guys running for gearing in 17.5 in rear motor
I have a Gen2 Tekin motor
5ive T (Bartoline 28.5cc, Bartoline Pipe, Team Chase)
Futaba 4pls
Team Chase 2015
Rd. 2 TQ-1st--Rd. 3 3rd
Mxer59 is offline   Reply With Quote
Old 12-02-2012, 06:32 PM   #3062
B00t13g's Avatar
Originally Posted by t8rtot View Post
Best pricing at speedtechrc
I always forget to mention them. They have great prices and great customer service. Just made an order with them actually.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 12-02-2012, 06:44 PM   #3063
skidooracer's Avatar
Trader Rating: 25 (100%+)
thanks guys, i jus got my car and i havnt run it yet but jus being prepared i made the switch from AE....
skidooracer is offline   Reply With Quote
Old 12-02-2012, 07:33 PM   #3064
CanyonCarverR1's Avatar
Originally Posted by Posvar View Post
Has anyone used the orion wts lipo with weights? I am interested to hear feedback if so.
Matt
I've been using them, but mostly with no weights. I did try some weight towards the rear of the car when I was trying to correct something. I have since removed the weight and corrected the problem with suspension changes. I think the weights aren't needed, and are just a band-aid to a handling problem, but I like having them in my box just in case I start bleeding
CanyonCarverR1 is offline   Reply With Quote
Old 12-02-2012, 07:57 PM   #3065
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Originally Posted by Mxer59 View Post
I got that notchy feeling out of my tranny, thanks for all who replied with help.
Are there any must need upgrades for this car?
Replace the ballstuds that are not long in length when it comes to threads. Pickup some of the longer ones. The short ones can be found in the front caster block and someplace else (memory is failing me right now). Otherwise, they tend to pull out.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 12-02-2012, 08:09 PM   #3066
fastestwon's Avatar
Trader Rating: 15 (94%+)
Default PDF file of race
check it out
fastestwon is offline   Reply With Quote
Old 12-02-2012, 08:25 PM   #3067
silvalis's Avatar
Trader Rating: 29 (100%+)
I was running 34/69 on a Fantom Ion3, until I did something dumb. Used a kimborough associated spur as per what Cpt keeps saying.
I've got an avid triad and a reedy incoming. Going to start at around 30/69 or 72 then go up.
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 12-02-2012, 09:54 PM   #3068
Mxer59's Avatar
What weight oils are you guys running on stock setup?
Futaba 4pls
Team Chase 2015
Old 12-03-2012, 06:02 AM   #3069
eper's Avatar
Trader Rating: 14 (100%+)
the only upgrade this car needs is a endless supply of charged batteries so you can keep turning laps
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 12-03-2012, 06:06 AM   #3070
Mxer59's Avatar
well can't wait to get her on the track, was curious as oil weights to run? On my b4.1 big bores I did 30-27.5
Futaba 4pls
Team Chase 2015
Old 12-03-2012, 07:52 AM   #3071
Trader Rating: 55 (100%+)
Jamison R is offline   Reply With Quote
Old 12-03-2012, 08:28 AM   #3072
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Too many variables to give you the "sweet spot" on gearing. How much endbell timing you are running, how heavy your car is, what rotor you are running, and how large your track is can vary your timing by quite a bit... and the gen2 tekin motor is probably going to be about your least popular motor at this point considering it's so new. I don't know a single person running one at either of my tracks. Having said that, here is where I run. With this combination, the 31/69 is the sweet spot. 30 is slower, and so is 32. It can also vary motor to motor of the same model. (although probably not much).
Fantom APEX 17.5
Fantom 4500 shorty lipo
endbell timing maxed
12.5 HT rotor
31/69
Car is blistering fast for a 17.5. This weekends race I ran a fast lap of 14.4... Mod fast lap for the night was 14.3 in a b4.1
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 12-03-2012, 08:30 AM   #3073
Super Moderator
Originally Posted by silvalis View Post
I was running 34/69 on a Fantom Ion3, until I did something dumb. Used a kimborough associated spur as per what Cpt keeps saying..
Is there a problem?
- RCSpecialties -
Old 12-03-2012, 08:32 AM   #3074
t8rtot's Avatar
Trader Rating: 14 (94%+)
I think he's stating his choice in spur, to each that gearing. per your recommendation
Sfida
t8rtot is offline   Reply With Quote
Old 12-03-2012, 08:40 AM   #3075
Super Moderator
aahh.. at first I read it as he was saying something dumb happened because he used my recommendation I see now.
- RCSpecialties -
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22967 Yesterday 06:47 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
