    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 11-28-2012, 02:27 PM   #2971
lbckevin's Avatar
Trader Rating: 91 (99%+)
Originally Posted by flybyublue View Post
Do you know if WCRC will have these in stock today, or soon?
Yes, They arrived today.
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 11-28-2012, 02:38 PM   #2972
lbckevin's Avatar
Originally Posted by t0p_sh0tta View Post
Run an AE spur gear, and pick up AE's VTS.
Cheaper, and more readily available.
I have both the VTS and an Avid, albeit no in an RB6 (B4, SC10 and B44). They perform the same, but the Avid is considerably more expensive, and harder to source parts for. You're also limited on spur gear selection with the Avid. VTS sits inside the hexagonal recess in the spur, so you can mount it to any AE style spur.
I've found that the multiplate slippers help put the power down smoothly. A traditional slipper transfers power abruptly. It's either slip or grip. The VTS makes the transition smoother, so you can start putting the power down sooner. It helps keep the car from getting too squirrely on rutted up tracks as well.
I tried it and the VTS does not fit over the stock Kyosho top shaft.
Kevin Smith
Old 11-28-2012, 02:46 PM   #2973
CanyonCarverR1's Avatar
Originally Posted by Cpt.America View Post
Now all we need are swing shafts and axles! The pins in the swingshafts is where we need a boost to durability and longevity... the Kyosho diff is already flawless. Speaking of which, if you made the swing shaft pins REPLACIBLE... (the pins that spin the outdrives), I bet you would sell a set for every kyosho car out there.
+1
CanyonCarverR1 is offline   Reply With Quote
Old 11-28-2012, 02:53 PM   #2974
toast.'s Avatar
Trader Rating: 14 (100%+)
Where can you buy a LMR Electra wing other then UK
Originally Posted by mikeyscott View Post
LMR wing required then!
Small Tires:TA05 v2, M05-Pro, TT01, RC18's
Big Tires: SCT410, SSC "Slash" LCG, Mugen MBX6 eco SCT, RB5, RB6
toast. is offline   Reply With Quote
Old 11-28-2012, 03:14 PM   #2975
kdub's Avatar
Buying everything from scratch, the Triad parts are priced the same as B4 slipper parts. The VTS costs less as an upgrade if you've already purchased an AE slipper. The Triad is much lighter (about 10g) and is more compact. Because of the small diameter design, there is a handling difference on the track between a VTS and Triad and I found the Triad to give less wheelspin and better feel in corners and jumps. Not many people have had the extensive testing time that I have in running both mulit-plate setups in mod 2wd buggy. Running mod buggy with the Triad yielded the fastest, most consistent laps. As with any AVID product, if you buy a Triad and are not satisfied, you can return it to us for a refund.
Chief Engineer, Schelle Racing Innovations, SchelleRacing.com - Team Associated - Reedy - JConcepts - Sanwa - MIP - StickyKicksRC - UpGradeRC - Darkside Designs
kdub is offline   Reply With Quote
Old 11-28-2012, 03:31 PM   #2976
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Haha after my experience with the cougar no ways!! I had made a carbon fiber version of the wing that thing was too damn stiff everytime it flipped it would make a god awful noise.
I now cut the vertical wall between the two side fins as close to the wing surface as possible. Makes the side fins flex the most without tearing and the shock tower takes the max brunt of the impact. I am not so good a driver to notice the reduction in down force .
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 11-28-2012, 03:37 PM   #2977
t8rtot's Avatar
Trader Rating: 14 (94%+)
Picture?
Sfida
t8rtot is offline   Reply With Quote
Old 11-28-2012, 03:38 PM   #2978
Moderator
Posvar's Avatar
Trader Rating: 462 (100%+)
Is anyone currently running the Orion VTS lipo with weights? I have one on the way and wanted to see what the dialed set up is.
Having fun with my 9 year old and running Kyosho cars!
Posvar is offline   Reply With Quote
Old 11-28-2012, 03:45 PM   #2979
I thought Lee lined up a US distro, thought it was on liverc or something.
I would drop him an email, but he'll be heading to Argentina!
Use LMR on my DB1, FS2 and RB6. Spot on.
Schumacher - RW Racing - RudeBits - TORCH
mikeyscott is offline   Reply With Quote
Old 11-28-2012, 04:13 PM   #2980
cnelson3's Avatar
Trader Rating: 65 (100%+)
It's a pain in the ass but they can be replaced. I do it.
cnelson3 is offline   Reply With Quote
Old 11-28-2012, 04:14 PM   #2981
aloksatoor's Avatar
Originally Posted by t8rtot View Post
Picture?
for my cf wing?
Old 11-28-2012, 04:14 PM   #2982
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by fastestwon View Post
Any race video of your car ?
I think there was a Go-Pro out on the track that night for the main event, but I have no idea if the guy is going to make/post the vid anywhere. ill have to see.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 11-28-2012, 04:15 PM   #2983
Super Moderator
How do you do it? What replacement pin do you use? Info? links? details?
- RCSpecialties -
Old 11-28-2012, 04:16 PM   #2984
aloksatoor's Avatar
I have the hudy replacement tool for 1/8 scale pins 1.4mm i believe. Do you mod that tool? I would like to know as well and the correct part number on mcmaster or somwhere else that sells that pin.
Old 11-28-2012, 04:19 PM   #2985
Haven't been able to race for a month now :-(
Has anyone else ran their 6 with saddle packs ?
Lou Colmo/Tekno EB48.3, SL & SCT410.3/ Tekno R/C,Tekin / Reedy Batteries / Savox /AKA / Futaba 4PKs
Blaze R/C,St.Louis DirtBurners,SMAC Trac
X God is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22956 Today 04:13 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
